Toyota Reveals All-New Prius
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Danny, Jan 12, 2009.
  1. nameless dude
    nameless dude New Member
    77
    Sydney
    Really, sounds great. But can you tell me what the SRU is?
    But I'm still a little dissapointed with the power. After all, everyone was expecting 160hp.
  2. Tideland Prius
    16,549
    We weren't expecting 160hp. It was a last minute rumour.
  3. nameless dude
    77
    Sydney
  4. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Re: Gen III Prius
    Shifter closeup
    Same shifter, different position. It simply moves from the dash down to the centre console. Looks like it's momentary as before (i.e. you push it to a position to select a mode, then it returns to the 'dead' position when you release it). A compromise between being more agreeable for current owners, and more acceptable to prospective new owners, I suspect.
    It was reportedly quite easy to knock when feeling for audio controls - Art's Automotive detail a problem report.
  5. JSH
    JSH Senior Member
    2,605
    140
    PDX
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    There were also rumors of a turbo, and anywhere from 60 to 100 mpg. All industry speculation, and unless it comes directly from Toyota, should be taken w/ a grain of salt. Anything after that is left to interpretation.
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
  8. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    I feel like the solar paneled moonroof is a bit of overkill ... needless cost practically or at least not worth the money ... I mean really, open up the windows when it's hot for a few seconds and the hottest air is gone.
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    the HUD is recessed so therefore covered. you would have to be pretty far north (like me) for sunlight to be an issue, and that would only occur in summer in late evening. (sun sets at 10 PM here in middle of summer)
    as far as clarity, its primarily symbolized. if you dont have issues seeing the dash now, you wont with this one either. the HUD (dash) is much bigger and still has brightness controls for personal settings
  10. HTMLSpinnr
    5,341
    920
    251
    I'm going to disagree. In Phoenix when it's 118°F outside, parking in the sun yields a heat soaked car of 140°F+ and a heat soaked A/C condenser. If we can keep the interior at "anbient", and give the A/C the 3 minute head start, that's a bit better for the HV battery and the occupants. I'm also interested in keeping temps lower to minimize dash warping that I experienced w/ the 2004.
    Even w/ Heat Shields (I still have the one I won here for my 2004), the interior temp w/ cracked windows and one shade exceed outside temps.
  11. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i remember it very well and am reminded of it every time i look at the picture (autographed by the Prius chief design engineer) of the development stage which includes the above along with 2 clay model interims and the final design
  12. qbee42
    3,079
    Where we live this is true. It's pretty nifty, but not "needed" here. That's why it's an option. If you don't need it or want it, don't get it.
    One of the things Toyota was very clear about is that the Prius is their technology flagship. You expect to see new and over-the-top features available on a new Prius. Eventually some of them work their way into other vehicles.
  13. HTMLSpinnr
    5,341
    920
    251
    In fact, looking at the headlights alone, it looks like the second clay model, no?
  14. fredthepostman
    422
    boothwyn pa
    I agree about the cost of a solar moon roof being to expensive . Do you think its possible they would offer the moon roof without the solar panels? I like the open feeling a moon roof gives.
  15. qbee42
    3,079
    Toyota has not released package information. We know about three pre-release packages, but that is all. Only one of the three pre-release packages has a moonroof, and that comes bundled with the PV panel and remote A/C.
  16. Husker4theSpurs
    656
    128
    Papillion, Nebraska
    Yet, almost all of the country ISN'T like Phoenix in the summer ... and a lot of people would like a sunroof but not if it costs THAT much more solely b/c of the solar panels ... all being said, no one knows the cost of that particular option.
  17. qbee42
    3,079
    Exactly, and we don't know if the PV panel will be bundled with the moonroof on all of the moonroof packages. All we know for now is what is on the pre-release packages.
  18. Tideland Prius
    16,549
    See, this keeps the interior cool BEFORE you enter the car. In fact, it keeps it cool WHILE the car is parked. Hence, it makes it easier to cool down the interior faster (whether you use the window method or not, the starting temperature is cooler). It'll put less strain on the A/C and hence the HV battery.
  19. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Below shows the Iconic Prius setup. MG2 moves along with the wheels.
    This one shows MG2 torque being multiply with a second planetary gear-set (Speed Reduction Unit). Notice: The ring gear is grounded so it will not move.
  20. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Although I love the new Prius and can't wait to get my own, I'm disappointed about one thing. The steering wheel. It's dangerous. The top entire 180 degrees has ZERO steric hindrance. VERY dangerous! At the ten o'clock and two o'clock positions, there should be two protuberances to add steric hindrance while gripping the wheel. Otherwise, the driver's hands can easily slip on the wheel (especially in dry weather, when skin is dry).
    Here is the steering wheel from the Corolla, Matrix, Celica - tried and true Toyota safety standard for more than the past decade:
    I am including this just in case it's difficult to see the protuberances in the image above.
    MOST other auto manufacturers have these notches on their steering wheels. BMW, Mercedes, Lexus, Porsche, and many, many more. I don't know why Toyota would not include such an important safety feature. :confused:
