Dealer says lithium battery available in November
Discussion in 'Gen 3 Prius Main Forum' started by Soylent, Jan 15, 2009.
  1. Soylent
    Soylent The v isn't a station wagon! It's just big boned
    443
    Fort Lauderdale, Florida
    2013 Prius v wagon
    I just heard this at a Toyota dealer. Fact or Fiction?
    He also said the 2010 goes on sale in March.
  2. qbee42
    3,079
    The head of Toyota USA and the Prius Chief Engineer stated that the Gen III Prius will use the same battery as the Gen II. The battery has been repackaged, and they are getting a little more power out of it, but it is still NiMH.
  3. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    Looks like the first one to dealers in middle May or early June.
  4. Soylent
    443
    2013 Prius v wagon
    Well, if people knew lithium was going to come out in November, nobody would buy a Prius until then. So Toyota wouldn't make that public information. So... who knows?
  5. Soylent
    443
    2013 Prius v wagon
  6. qbee42
    3,079
  7. JSH
    JSH Senior Member
    2,605
    140
    PDX
    The plug-in Lithium Prius are for fleet sales only. It is part of Toyota's research into PHEV's. If I remember correctly they are building 500 worldwide.
  8. darelldd
    6,059
    389
    Northern CA
    Yup. About 150 should come to the US. They will NOT be on the retail market until... well, nobody knows.
  9. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Even when the Plug-In is available, the plan is to offer the Lithium Ion battery in the plug-in and keep the NiMH in the standard Prius. There was a strong hint that by the time they would replace the NiMH with the Lithium Ion battery they would be ready to launch an even more advanced technology.
  10. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    sure they will Danny, by 2015 we will all have onboard fission power plants (remember "back to the future", 'mr. fusion'?) :) only j/k
    I do wish they moved along a little faster though
    Mitch
  11. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    That doesn't surprise me much. There is very little advantage to Li-ion over NimH in a standard hybrid. Panasonic EVs NimH cells are pretty impressive. They put out a lot more Amps per Amp hour than most Li-ion would survive. We know output can be over 100A on full acceleration, from a 6.5Ah battery. Thats a routine 15C+ discharge! Many Li-ion are happiest around 3C, some can do 10C for short bursts. Li-ion will cut weight per Wh in half, but as the Prius battery modules only weigh ~60lbs, that wouldn't buy much of anything. Makes it hard to justify the 2x cost increase. You could also double the battery capacity for the same weight, but now you've 4x'd the cost, and the effect on mileage will probably still be negligible. The DOE ran a first gen Prius to 160k miles and found that even though its older style batteries were down to almost 50% capacity, there was no noticible impact on mileage. Similarly early gen2 hackers figured out how to put a second stock pack in a Prius, doubling the battery capacity and also got almost no improvement in mileage. The mileage performance of a standard HEV is just not that strong a function of battery size provided the battery capacity is much greater than the amount of energy stored/released in a standard deceleration/acceleration event, which in the prius case it is.
    I know most folks on here know this, as its been discussed a lot, but I think it bears repeating from time to time as there is a common public perception that Li-ion is vastly superior in all things and some kind of magic answer to all our problems. Li-ion becomes much more important for PHEVs, as battery size and weight becomes more of an issue. Larger NimH are also not available due to the Cobasys patent coverage, and building a PHEV pack out of smaller NimH cells get prohibitively expensive and complicated.
    Rob
  12. Fibb222
    Fibb222 New Member
    1,499
    99
    Rechargable Zinc-Air if I'm not mistaken...
  13. darelldd
    6,059
    389
    Northern CA
    That's what I'm talkin' about.
  14. Tideland Prius
    16,551
    Sounds good to me but I'd like to get a Prius before it becomes as expensive as a Lexus =P
