What did we learn from the Chief Engineer?
Discussion in 'Gen 3 Prius Main Forum' started by windstrings, Jan 13, 2009.
  1. MSantos
    MSantos EcoAccelerometry
    588
    257
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    OK, here are a few details from part two of the interview with Mr. Akihiko Otsuka:
    Cheers;
    MSantos
  2. Fibb222
    Fibb222 New Member
    1,499
    99
    This may seem like a dumb question but does anybody know for sure that the 2010 Prius will allow the driver to engage in gliding by pressing down slightly on the accelerator?
    I don't know why this is assume to be a "for sure" with any car besides the 1 and 2G.
    Sometimes on this site, people "talk" about gliding in hypothetical cars (EVs even) and I'm doubtful about the possibility or necessity.
    I wouldn't be surprised of course if the 3G had the capability to glide, but really, isn't being able to glide a lucky fluke - something somebody discovered by accident, not something that Toyota intended or even recognized at first.
    We know pulse and gliding works to improve mileage so I wonder if the 3G engineers somehow incorporated gliding into the software/design of the eco mode so drivers wouldn't have to do it manually?
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Eco if anything would be less sensitive enough to allow us to find that glide sweet spot. Otherwise, there's always shifting to Neutral ;-)
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
  5. donee
    donee New Member
    2,956
    198
    Chicagoland
    I WOULD I WOULD. Especially when its -18 F (like yesterday morning)
    Sunroof is a SEE ME SEE ME add on favored for those who would like their faces clearly seen as they drive around in their status symbol. It adds weight high on the chasis and reduces structural rigidity. A better solution would be round port-hole like vents spaced around like lightening holes. Ala Space Ship One. Also, more secure.
  6. donee
    donee New Member
    2,956
    198
    Chicagoland
    Remember your basic auto-mechanics here. The thermostat valve has a bypass arrangement. SO, when its closed the water still flows, but back to the engine, and not to the radiator (and then back to the engine). This takes care of the hot spot issue mentioned in the other response.
  7. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Fibb,
    I doubt Toyota did not know about the glide mode. One of the project cars that led to the Prius, mentioned in the "Prius the Car that Shook the World" was code named COASTER.
  8. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Oh man, what a cheap shot! And untrue.
    We sunroof fans prefer the fresh air, the openness, the view of the sky and suggestion of unlimited possibilities ("the sky's the limit") that a sunroof offers.
    We don't buy a sunroof in order to be seen. (Although some may think that they look better with overhead lighting.) :rolleyes:
  9. Tideland Prius
    16,549
    10-20% with ECO button and using the Hybrid System Indicator to help you...
    Depending on which method you're using (he's probably using the US mpg), that'll net you up to 60mpg off the 50mpg combined cycle.
  10. darelldd
    6,059
    389
    Northern CA
    I am RIGHT there with you, bruceha. Would so much rather see technology going into practical/FE considerations - instead of moon roof and solar roof. But then I'm rarely the "target audience" in anything I do!
  11. qbee42
    3,079
    Except when buying Spandex.
  12. darelldd
    6,059
    389
    Northern CA
    I saw Boo in all kinds of different lighting. I can confirm that the moon roof lighting probably won't help. :D
  13. windstrings
    6,280
    378
    Central Texas
    I was wondering why his name was "Boo"
  14. darelldd
    6,059
    389
    Northern CA
    Actually... Pearl Izumi has moved things around a bit, and I've gone from being a perfect size M to something between M and L. And of course there IS nothing bewteen M and L.
    Maybe I just need to order the salad more often.
  15. qbee42
    3,079
    Or get stronger Spandex. :eek:
