2010 Features and Impressions
Discussion in 'Gen 3 Prius Main Forum' started by Tideland Prius, Jan 15, 2009.
  1. Tideland Prius
    16,445
    I thought I'd list the small little details that made it to the 2010 Prius that might not be obvious at first so I'll be leaving stuff out like the LED headlights and solar panels cause those are the big ticket items
    • Power window switches are illuminated at all positions
    • Express up/down function with jam-protection for all 4 windows
    • Auto-Open power moonroof with two stage opening
    • Ambient lighting (LED shone from above)
    • Felt pads at the base of all 4 door handles/grips
    • Bluetooth Audio available
    • Rear seat headrests flip forward (either for folding the rear seat or for increase rearward visibility)
    • No sound deadening material in rear wheel well
    • Front footwell lighting (amber/orange colour)
    • All 3 blanks on the driver's side solved - manual headlight adjustment (Europe only), solar panel A/C and headlight washer
    • Navigation is still DVD-based (HS250h and Euro versions get HDD)
    • Outside mirror still folds fairly flush with the body and still folds both ways
    • Rear SKS lock button is next to the rear hatch release button
    • Windshield washer nozzles hidden beneath hood
    • Lower glovebox no longer felt-lined and loses a shelf
    • Upper glovebox loses shelf
    • Taillight now LED
    • Underfloor and side underfloor bins still remain but are now fully connected
    • Shifter movement is shortened
    • Navigation system includes traffic
    • Plasmacluster ionizer filter standard
    • Europe still gets a button dimmer switch rather than rotary
    • Front door pockets only the size of a bottle
    • Misty Grey is the only two-tone interior option
    • No mention of Safety Connect even though the cars were equipped with an SOS button
    • Cupholders still not adjustable
    • VSC not VDIM
    • Rear windows completely drop into the door panel
    • Rear hatch has both left and right pull-down cavities
    • Spare tyre is still painted yellow
    • Tool kit now in the spare tyre compartment rather than in the underfloor bin/box
    • Hood still held up by prop rod, not struts
    • 15" rim has a wheel cover and it's a full cover not a ring
    • Wing mirrors appear to have greater surface area
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Only the tail light is LED. The turn, license plate, and reverse lights are still incandescent.
    Safety Connect won't be available until Fall 2009.
    Some of mine (may be previously covered):
    • Doors auto-unlock when shifting into park, and presumably lock when in motion.
    • Removing the key from the car (out of SKS range) while on pops up a message on the upper MDF noting that the key is out of range.
    • Oil filter is now in a different location, possibly the right rear corner (based on cut-away view)
    • The front/rear emblem does not glow - it was just the lighting from above.
    • Hazard light switch is momentary vs. depressed/unpressed (cycled).
    • DRL's are similar to other current Toyota models now - amber and dedicated in the front facia.
    • Entering the options menu for the upper MFD involves a series of pressing and holding or quick pressing the wheel mounted DISP button.
    • Light touch on the wheel buttons light up in front of the MDF, but a full depress is still required to activate the function.
    • Same warning beep used to warn that the key is missing when the door is closed, but the car is in an "on" state.
    • For cars equipped w/ entry lighting, the front doors have the glowing PRIUS logo, but the rear doors do not.
    • Rear cargo area is slightly wider at the wheel wells thanks to the redesigned battery vent.
    • Although the engine is belt-less, the crankshaft pulley is retained.
    • Although the MAP DVD is up in the dash, the NAV ECU still lives under the driver's (left) seat. There is an open plug w/ a yet to be determined function.
    • Both the NAV ECU and amplifier seemed to have clipped down covers, no more easier access to the NAV ECU.
    • I couldn't find the rear seat floor heat vents.
    • Under the passenger seat, there's a pop-up panel to reveal the frame VIN number.
    • The dash texture has been revised, as spotted in several photos.
    • The same sweeping/articulating wiper design has been retained.
    • Both the MAP DVD and 4 disc changer are accessible under the NAV screen
    • The same finger dance is used to access the service menus on the NAV MFD, however some of the options have changed within the menu itself. Holding display will reset the MFD back to "normal". The radio is still silenced during the service menu display.
    • The clock is displayed within the MFD, though still apparently set by hand. A time zone and DST offset can be chosen, which may suggest that GPS may be used to set if avaialble. Was hard to say as I had to set the clock in the one car I was testing and we were indoors which blocked the GPS signal.
    • Power door lock mechanisms "sound" newer.
    • Parking brake pedal surface appears smaller than previous.
    • Despite the size, map lights are not activated by pressing the lens, rather separate switches.
    • Fuel filler requires screwing in again, but the clicking is single click vs. racheting. Fuel door release location is unchanged and cable operated.
    I'm sure others could note more fine details.
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    The pretty logo in my avatar is the emblems on the radar-equipped model. It is paint, not light. Front and rear have the same blue "glow" paint. It is apparently something to do with the radar function.
  4. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Cool! And it also serves as a subtle warning to the rest of the world that the driver can't drive or parallel park. :rolleyes:
  5. HTMLSpinnr
    5,341
    920
    251
    I was told by the product development guy the blue logos were standard and that they were an "after thought" from the other two cars - a "last minute change".
    They appeared more like decals, not paint, as there was half-tone screening to get the fade effect.
  6. talonts
    talonts VFAQman
    468
    76
    I was told by a Toyota guy (I wouldn't say who, even if I remembered) that the blue logos were a "Japanese styling thing". I came up to him and asked if he wanted input on the various logo treatments on the car, and he said sure. I said please do NOT use the logo on the blue car - a full 1" deep 3D logo will be a complete nightmare to clean and wax. Then I noted that the grey car had a nice smooth logo, but the blue would not cut it. His response? "THANK YOU FOR SAYING THAT!" We then got into a discussion on US vs Japanese styling, and he said the Japanese designers really, really like the blue, and he agrees with me that the US folks are most likely going to hate it on some colors (it's going to look HORRID on a Barcelona Red car). He noted they've had discussions on it, but the Japanese designers aren't "getting" the US viewpoint. I told him if they want that fade effect, use white or silver, it would go with any paint color.
    Now for the fun part - he noted that there would most likely be a JDM part without the blue (similar to the black chrome logos you can get now for the 2G), and he promised that if the final product comes with blue logos, that the second he had the JDM part #, he'd make sure that we'd find out that part #.
    He noted that after I said if it came with blue, I'd probably have to remove the logos, sand the back of them until the blue disappeared, and repaint them before reinstalling them ;-)
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Here are mine:
    • Hood's prop rod can stand on two positions for different height.
    • The wipers are frame-less aerodynamic blades.
    • The brake LEDs now use 88% less energy than the Iconic model's LEDs.
    • Low beam LED headlamps use 20% less energy than the Halogen (My calculation: 44W Vs. 55W).
    • Backup camera video quality looks better.
    • Reverse beep is still there.
    • The radio antenna screws on the 'sharkfin' shape base.
  8. HTMLSpinnr
    5,341
    920
    251
    Retract from my previous, digging through pictures (the Picasa album has been updated), I did find the rear floor heater vents below the nav ecu and amp. Not sure being under is that great for fear of overheating those components in some situations...
  9. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    A couple questions for anyone who attended the show:
    1. How does the LCD brightness compare with the Gen 2 Prius MFD? What about glare from light entering the windows? Depending on your heading and the sun angle, it can be a definite nuisance in the Gen 2.
    2. How is the rear window visibility? I've gotten used to it in my Gen 2, but the crossbar in the rear hatch has always bothered me to some degree.
  10. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    The lower glovebox no longer has the deep pocket at the back that held mapbooks and manuals so nicely.
    I tried folding the seats flat, but couldn't do it. I thought I had moved the front seat all the way forward, and I removed the headrest - temporarily. Maybe the front seats are taller?
  11. Tideland Prius
    16,445
    I hope the reverse beep is defeatable!
    Interesting comment on the quailty of the image. I thought the MFD screen buttons didn't look any better than the current hi-res monitor. Do you think the camera has been improved or the MFD screen (or both)?
  12. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    looked closely at the driver's side profile picture of 2010 ...
    Words that come to mind -
    Bolder, sexier, sleeker to name a few.
    The more vertical front end gives a stronger look.
    Crest in the roof obviously moved back, increased rear headroom. Maybe even increased roofline view for driver.
    Rearend profile much improved. Gone is the rounded-in shape up to the spoiler which gives a bit of wanky-butt look to the 2nd Gen.
    Steeper rake / downward slope of top of doorlines - looks sportier there
    Good job Toyota! Don't worry, you'll sell tons of these :)
  13. darelldd
    6,059
    389
    Northern CA
    Great lists of the new features, guys! I'm glad you guys were all working your fingers off while I was sampling the bar offerings. ;)
  14. qbee42
    3,076
    I was chatting up the models. Those women were very tall (at least when you are my height).
  15. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    As to Japanese stylist's love for the blue background for the Circle-T badges,
    blue appears to be the "eco" color in both Europe and Japan.
    As a way to discourge its use on NA cars, perhaps someone with the right
    connections should tell Toyota that the blue has a wholly different association
    here. To my eye, it looks a whole lot like what back in the day was called
    "Chevrolet Racing Blue." Further, it looks suspiciously like the shade of blue
    used in the two broad racing stripes on the Ford GT-40 and some Shelby
    Mustangs. :eek:
    The Prius is supposed to be leading edge, not derivative, especially in the
    corporate logo. :eek:
  16. Tideland Prius
    16,445
    At least it's not red like the JDM Honda Type-R emblems.
  17. Tideland Prius
    16,445
    Hmm, I've noticed that there are two types of overhead console - one for those with Safety Connect (you get the nice shiny black disc) and one without (you get a standard plastic switch for the dome light only)
  18. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    My concern with the logo was not so much the color (though I'd probably prefer the "without" than the "with"), but the size of the logo. Didn't it appear to be much larger?
  19. qbee42
    3,076
    The logo is a moot point. It generally comes off with the first blind pedestrian...
  20. gak27
    gak27 Prius, Take Two
    117
    Akron, OH
    Jeez, I hope not. I personally despise autolock doors (almost as much as using child locks on doors for school age children...)
    On a more hopeful note, I read in one of the reviews that the front seats will have more legroom/longer travel; wouldn't it be great if the rails were compatible with the 2G models?
    greg
