OK, what is it??
Discussion in 'Gen 2 Prius Main Forum' started by bobc, Apr 8, 2005.
  1. bobc
    bobc New Member
    361
    Durham, NH
    In taking apart another portion of my car, which has been turning into a hobby lately, I discovered this just in front of the passenger's front tire, behind the wheel well.
    It's a plastic (I know, hard to believe on a Prius) container. It's not the coolant reservoir. The air intake under the hood dumps air into into this.
    All my points go to the best (not necessarily correct) answer! Although, it would be nice to know what it does....
    PS Don't think about it too hard 'because I only have a few points to give you! :)
    -bob
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    induction silencer
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Warp field generator
  4. Frank Hudon
    4,147
    Evan take your meds!
  5. rick57
    rick57 Member
    572
    Circleville, Ohio
    Martini shaker. " Shaken not stirred". 8)
    Yes Frank is right, an induction silencer. Toyota calls it a resonator.
  6. flying
    flying New Member
    48
    ft. myers,Fl
    Kidney trip extender?
  7. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(bobc\";p=\"79814)</div>
    Why in the world would you do that?
  8. Widdletink
    Widdletink Member
    218
    Claremont, California
    2022 Prius Prime
    Hi All,
    I think it is a bee hive because this is one honey of a car!
    My husband on the other hand says it's a spleen:)
    Take care,
    Tisza
  9. KTPhil
    KTPhil Active Member
    1,379
    Flux Capacitor
  10. marathonmike
    marathonmike New Member
    Lemont, IL
    Used washer fluid collector
  11. KTPhil
    1,379
    Repository for excess gasoline generated by super efficient hybrid power plant when regenerating with 8 green bars.
  12. gaulfinger
    gaulfinger New Member
    65
    Memphis, TN
    <div class='quotetop'>QUOTE(rick57\";p=\"79860)</div>
    I guess this begs the question: what would the car sound like without it? Does it effect fuel economy? Usually anything upstream of an ICE's intake reduces efficiency and power potential.
    Gary
  13. 200Volts
    200Volts Member
    439
    46
    Northern CA
    This device really smacks of the self serving rational that absolves the automotive design business of any reality. It makes me desist any further pretentious terminology or inculpating syntaxial descriptions.
    (Oh crud, the tube fell off my oxygen tank)
  14. DaveG
    DaveG Member
    806
    Vancouver, BC
    <div class='quotetop'>QUOTE(flying\";p=\"79862)</div>
    I actually read about a doctor a number of years ago that actually used a condom-catheter to extend his distance driving range in the US... Basically the Mtn. Dew went in the mouth, and after "processing" could be "purged on the fly" via the catheter and a bit of tubing out the door :p
    Them zany doctors :p
    Dave
  15. DanP
    DanP Member
    256
    <div class='quotetop'>QUOTE(gaulfinger\";p=\"79917)</div>
    A quick Google search turned up a page that provides instructions to Mustang owners on how to remove this part from their car. It is regarded as a no-cost performance enhancement.
  16. Frank Hudon
    4,147
    the induction tract makes almost as much noise as the exhaust when under full load. Had a big block Chev on the dyno and at full power it was almost unbearable. My ears rang for a week after that setup was done. Ford has tuned the resonator on the new pickup to what the customer thinks is what a truck should sound like and I'm sure on the Prius it's there to stop the pulsing stacato bark that 4 cylinders make under load. Full throttle sound levels for the Prius is less than 78dba. Pretty quiet. As for robbing horse power I doubt that it makes much if any difference. It's no 5 liter Mustang.
  17. gaulfinger
    65
    Memphis, TN
    Thanks for the quick responses, guys.
    True enough, the maybe 1hp that might be gained on an engine this small isn't much for power, but if it got 1mpg better economy, there's a trade-off to weigh on noise vs. gas. Hmm...
    Bobc, since you're taken with taking apart your car, any interest in experimenting for the good of the Prius community? :)
  18. seeh2o
    seeh2o Prius OG
    447
    City of Angels
    An earthly container, waiting to be shed.
  19. senna4ever
    senna4ever New Member
    78
    Stupid 2010 Olympics
    Mr. Fusion?
  20. senna4ever
    78
    Mr. Fusion?
