2010 Prius engine?
Discussion in 'Gen 3 Prius Main Forum' started by toyotareference, Jan 13, 2009.
  1. toyotareference
    toyotareference New Member
    Portland OR
    Anyone know the engine code for the 1.8L in the new Prius? Bonus points if you can also tell me the chassis code(s).
  2. Tideland Prius
    16,549
    2ZR-FE (FXE for the Prius). Don't know the chassis code since it's a new chassis.
  3. toyotareference
    Portland OR
    Ah, the same basic engine that is in the Corolla, Matrix and Scion xD. Thanks much!
    The chassis code could be the ZHW30... we'll see.
  4. Tideland Prius
    16,549
    NHW you mean.
    Yes it's the same engine but with Atkinson cycle.
  5. toyotareference
    Portland OR
    No, I mean ZHW. NHW would be the chassis code if it still had an N-series engine, but now that Toyota has put a Z-series engine into the car the chassis code will start with Z. I don't know if it will be a 30-series chassis code, but I would guess that it would since this is the third generation Prius. Of course, sometimes the platform is spun off of another car, then the code could be anything.
  6. Tideland Prius
    16,549
    Hmm, I see. Should've asked us before we went to Detroit.
  7. toyotareference
    Portland OR
    Well, often times they won't release the chassis code until the car is just about ready for sales. Once the cars start showing up in the dealer ordering system the chassis code will be available.
  8. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The chassis code is ZVW30.
    Ken@Japan
  9. toyotareference
    Portland OR
  10. rusty houndog
    rusty houndog mountain rider
    152
    Buffalo, Wyoming
    Does that mean the Corolla, Matrix, and Scion XD have an offset crankshaft? Or does that mean the Prius will not have an offset crankshaft?
  11. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Speculation aside, I'd find it hard to believe Toyota backpedaling on such a successful design. Cylinder wall wear reduction was a motivator for this design IIRC, as well as a more efficient use of the power stroke at TDC.
  12. Doc Willie
    1,717
    144
    Out there, somewhere
    Damn, you guys are good!
  13. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    The base 2ZR-FE engine has an offset crankshaft.
    Pressroom - Toyota - Press Kit Details
    "The fully balanced crankshaft is offset by 8mm to the intake side of the bore centres to reduce the maximum side force on the cylinder walls and increase fuel efficiency."
    Ken@Japan
  14. HTMLSpinnr
    5,341
    920
    251
    I believe MRV took that photo. I was sitting in the driver's seat when it was taken and happy that she did so.
  15. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    what car was that from? We can see that GVWR is only 200lb more than on 2004 Prius.
  16. Tideland Prius
    16,549
    blue car with nav, 15" alloys and moonroof. They may all say the same number despite the options.
  17. HTMLSpinnr
    5,341
    920
    251
    Gross weight will likley be fixed, it's curb weight that determines "carrying" capacity. Sadly, we don't treat our cars quite like airplanes and many of us may routinely exceed this w 5 adults, full gas, and some luggage.
  18. spwolf
    3,156
    440
    Eastern Europe
    nevertheless it pretty much confirms that 100lbs note from detroit... which is rather impressive.
    seeing new Avensis dismantled to pieces, latest vehicles get so much anti-crash protection, it is miracle that they are all not 5000lbs.
  19. qbee42
    3,079
    You don't calculate weight and balance before you back out of the garage?
  20. HTMLSpinnr
    5,341
    920
    251
    No, and my tires hate me for it!
    On a different note, it was interesting that the Chief mentioned a requirement to keep weight UP in some ways for safety/crashworthiness reasons.
