Daytime running lights
Discussion in 'Knowledge Base Articles Discussion' started by ninalr, Jul 5, 2006.
  1. ninalr
    ninalr Junior Member
    My 1st Prius was a 2003...it came with daytime running lights. Then I got the 2004 which didn't have that feature (the dealer told me they all went to Canada where that's a legal requirement). Sadly, I was in a crash which totalled my less than 1yr old baby. So now I have a 2006 which still doesn't have daytime running lights. Meanwhile my husband is still driving the original model with DRL!
    Does anyone know why this feature is not available on current models?
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(spanielsmum @ Jul 5 2006, 04:58 PM) [snapback]281690[/snapback]</div>
    Because the U.S. government does not mandate it.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Yes, lots of us miss that feature. There is a work around, if you just turn your lights on and leave them on they will go off when you open the door after shuting the car down.
  4. tdub1974
    tdub1974 New Member
    Greenwood, IN
    <div class='quotetop'>QUOTE(seasalsa @ Jul 5 2006, 08:52 PM) [snapback]281718[/snapback]</div>
    This is what I do as well. I think the owner's manual turned me to this making it out to be the same as daytime running lights
  5. roopesh
    roopesh New Member
    I, personally, am glad DRL is not enabled by default. Though it may seem insignificant, think about the extra battery drain those headlights are placing on your car.
    I don't like DRL. I had a truck with that and had to find a way to disable it... different strokes for different folks, I guess...
  6. sdsteve
    sdsteve New Member
    88
    <div class='quotetop'>QUOTE(roopesh @ Jul 5 2006, 06:14 PM) [snapback]281733[/snapback]</div>
    so can the dealer program this feature on??
  7. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    I don't like DRL's at all. I think they serve little purpose.
    I had them in my '02 nB and I disabled them. My MPG actually went up. You do use some power for lighting them.
    To each her/his own.
  8. blfuller
    blfuller Junior Member
    33
    Eastern Washington State
    2026 Prius
    XLE AWD-e
    I was reading the manual of my '09 and they are disabled on the US models but I would think they could be enabled if desired by the dealer or if you know how to do it yourself
  9. qbee42
    3,079
    No, this is not the case. The better U.S. models feature HID headlamps, which are not compatible with reduced wattage use as daytime running lights. To have real daytime running lights, the cars would require the addition of another headlamp assembly, not simple configuration from the dealer. This is also the reason that U.S. models of the Prius lack auto-on headlamps.
  10. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    AMEN, with all the problems folks have had with HID, I would rather not just waste them away in the daytime. The only exception, at least here in CA if your windshield wipers are on, your headlights have to be on. New safety law enacted Jan 2007!! If wipers are off, off with the HIDS!
    Safety First!!!
    73 de Pat KK6PD
  11. UncleC
    UncleC Junior Member
    Chatsworth CA
    WebElectricProducts.com has a DRL kit that uses the [front] turn signal lamps for this purpose. Quite effective - very visible.
  12. darelldd
    6,059
    389
    Northern CA
    I have. It is insignificant. Compared to the energy needed for motive force, the energy used for lights is nothing.
  13. Syclone
    Syclone Member
    540
    One of the nice things about DRL is that most insurance companies will reduce your premiums $40 - $50 U.S. :car:
  14. KK6PD
    4,003
    946
    118
    Sadly, MOST companies DO NOT give a rats nice person about DRL's!!!
    I just called AAA, 21st, StateFarm, yadayadayada.....NO NO NO...
    At least on the west coast. So much for that thought
    Besides for what they charge to change a HID, DRL is stupid!!!
    73 de Pat KK6PD
  15. Syclone
    Syclone Member
    540
    Shows how small my world is. AMICA, in New York offers a DRL discount.
  16. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    what he said!!!
    that is...i use my HID's as little as possible, lamenting the day when one begins to flicker.
  17. dominicsavio
    dominicsavio New Member
    83
    Anyone know whats so special about HID headlamps?
  18. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    HID lamps are much brighter and in theory should last longer.
  19. dominicsavio
    83
    Prius_07 - thanks. But is there also something else like an 'auto-leveling' feature for the HID lights? I'm wondering what this/how it works and how to tell whether my HID has this?
  20. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Not insignificant. 1-2% is more accurate. Small, but not insignificant.
