Driving on packed snow long distance
Discussion in 'Gen 2 Prius Main Forum' started by bobjeri, Feb 14, 2009.
  1. bobjeri
    bobjeri New Member
    70
    Olympic Penninsla, WA
    We're headed to Southern CA from WA next week and hoped to drive the Pri starting next Monday ... we could fly on Wednesday but want to have the car for the visit and return on the coast. Can't delay the trip.
    The problem is the snow on the mountain road (I 5) from about Grants Pass in Oregon to south of Mount Shasta ... approx 150 miles ... based on the weather forecast at least 80 mi (probably more) will be packed snow covered . 2000 - 4400 ft altitude.
    Basic question is will our 05 Pri with VSC handle at least as well as other FWD wo VSC --- from the forums I think so. BUT I've only driven on snow for under mile on the level with the Prius. Driven other cars on snow quite a bit.
    Tires are 195x60R Mich mxv4 with about 10,000 miles. Will drop the psi to about 36 or so for the trip. Cable chains on board.
    Mild storm came thru last night -- Bigger expected today (Sat) and tomorrow(Sun). Flying is beginning to look like the choice.
    CA road pics -- crux is Weed -- Mount Shasta--
    Siskiyou County Traveler Information
    Oregon road Pics -- crux is near CA-OR border--
    TripCheck - Road Cams, Road & Weather Conditions in Oregon - ODOT
    Our other car is a beater AWD Subaru which normally does snow runs ... but it is not suitable for the long drive.
  2. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    bobjeri,
    made that run a number of times in the 70's in the snow in a VW
    Squareback Variant.
    Seems like I was always driving at night when it was only me and
    the 18-wheelers on the road -- and they drove like demons, far
    faster than I felt was safe. So they all passed me. And if it was
    slushy, they threw massive waves of slush on the car and the
    windows. I had to come nearly to a stop for the wipers to have time
    to clear the windshield. I was often terrified, especially if there was
    another truck coming up behind. :eek:
    I learned to stop at a motel as soon as I didn't like what I was
    seeing --that is, when I could see. :eek:
    If it was absolutely, insanely necessary to keep moving, I'd pull off
    at an exit and wait for a snow plow to come by and fall in behind.
    Yeah, you know it, they too drove at maniacial speeds. :confused:
    Good luck, and God bless. Be careful out there... :)
  3. bobjeri
    bobjeri New Member
    70
    Daytime only--
    Our plan is to get away at 4am so we'd go thru (hopefully) abou 1-5pm ... if lucky.
    I'm pretty sure the Pri can do it but the VSC is a bit of unknown ... good threads here helped.
    IT IS those BIG BUDDIES, the 18 wheelers, that are the primary concern ... the bow wave wind blast, the slush wave, aggressive driving etc.
    Worked in Ballmer 1977 to 1979 ... interesting town BUT moved west in 79 and never looked back.
    Best.
  4. qbee42
    3,081
    With those tires it will be as good or better than any front wheel drive. Keep in mind that the Prius sits fairly low to the ground, so you can't plow through deep drifts.
  5. Arniesea
    Arniesea New Member
    26
    Bremerton, WA
    The main thing is to shift into "B" which gives you the gas pedel control of the drive wheels instead of freewheeling. This is will give you a simular feel for traction that a conventional transmission would give you though gas milage will suffer.
  6. bobjeri
    bobjeri New Member
    70
    Tires -- we wanted something clearly better than the standard tires in rain and dry and so far we like them ... just confirmed snow ability which wasn't a prime concern but nice to have now.
    B -- very cool. Only used B a time or two and noticed that generally a little throttle was needed to get 'down' our hills. Similar in this application I guess to gearing down a notch for engine braking. The ONLY times I have not liked FWD was downhill, in slime from Paradise at Mt Rainier in winter for ex ... this sounds better.
    I retired from working for the Navy in Bremerton.
  7. qbee42
    3,081
    B mode won't really help with traction: you still have the same tires gripping the road and they will still be used in exactly the same way. What B mode will do is let you keep your foot on the accelerator pedal when going down a long hill. Otherwise you need to shift back and forth between the accelerator pedal and the brake pedal. That works fine, but B mode does inspire a sense of more control, even though it is an illusion. I have used it more than once for just this reason, even on dry pavement.
  8. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I would not recommend the use of B mode at all, unless you're coasting down a very long, steep grade.
    It would be a good idea to ensure the washer fluid reservoir is topped up.
  9. bobjeri
    bobjeri New Member
    70
    The B Illusion --- Thanks for amplifying the concept -- roughly what I was thinking except for the 'illusion' part. Less braking is good ... removes the temptation to corner too fast on the slime. Expect to kinda feel my way and suspect the grades will mostly be too flat to get up much speed downhill even in D.
    window washer filled with -20*F or lower stuff. 2 scrapers and 2 squeegies too. Rain-X'd and interior glass de-fogged.
  10. patsparks
    10,664
    569
    Adelaide South Australia
    I'd rather brake than use B mode, braking allows the ABS to work, a slide in B mode is uncontrolled except by the driver. ABS works quicker than you can react. Stability control will help. B mode will give the throttle a more "on or off" feel. Gentle inputs is what you want on slippery stuff.
    Live a little, don't fly.
    You only live life to the full when you feel like life is on the line.
    Stop frequently, have a coffee with a local.
    Ever wondered why boredom is in epidemic now days?
  11. bobjeri
    bobjeri New Member
    70
    If the downhill grade is such that B will retard speed sufficiently w/o much braking it seems better than braking more often even w ABS....but maybe not. Thanks for that thought .... this is on snow and ice.
    Related to your comment and my initial question ... I am assuming (hoping actually) that VSC will be a useful part of the driving-control equasion, if needed, DOWNHILL on slippery roads.
    I assumed that VSC - ABS worked in both B & D modes??? Not that I want to test this except in a parking lot.
    I've enjoyed your posts in other threads ... thanks for those too.
    Epidemic Boredom = Epidemic TV Watching and vice versa
  12. patsparks
    10,664
    569
    ABS and VSC can't control the B mode.
  13. Arniesea
    Arniesea New Member
    26
    Bremerton, WA
    Thanks for the info about ABS in the B mode. I was raised in Colorado and am a very experienced snow driver. I trust my own skill more than a machine thinking for me. (That's why I have not upgraded to Windows Vista ... but that is another topic. ;))
    However, ABS is a good thing and I did not know it was disabled in the B mode. (Why would they do that?!?) Where the rubber meets the road is the most important part of this equation and as already noted, the tires are more than adequate.
    As always, an interesting topic.
  14. bobjeri
    bobjeri New Member
    70
    The loss of ABS-VSC in B is not what I expected either.
    Just about everyday I am humbly reminded of Mark Twain's timeless line:
    "What gets us into trouble is not what we don't know. It's what we know for sure that just ain't so."
  15. patsparks
    10,664
    569
    Hang on, you haven't understood what I am saying.
    ABS is not disabled in B mode!
    When in B mode the HSD uses energy from the wheels to drive the engine thus retarding the forward motion of the vehicle. The ABS has no control over this retardation. Should the front wheel start to slide while in B mode with no foot on the brake it will continue to slide. This is in a very low grip situation I am talking about. If instead you use light pedal pressure on the brakes while the car is still in drive the computer will look after retarding the forward motion of the car. The ABS will almost instantly, faster than you can react, switch from electric regeneration braking to hydraulic friction braking and will apportion the brake force to the wheels with the most grip, you can not do this manually. This is why I say it is better to use gentle braking than B mode.
    VSC works all the time but VSC is not ABS, it will bring the car straight or assist with cornering but it wont stop a straight line skid, that is the job of ABS.
    Have we all got that? B mode does not disable ABS, ABS has no control over the HSD functions except regenerative braking which it can only turn off to switch to friction brakes.
  16. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    B mode seems very complicated, but the basic concept is this: it produces more braking force when you lift off the throttle than the car does in D mode.
    The exact approach it takes depends on the charge of the battery and the charging rate. It will use engine braking a little more aggressively than D mode to reduce the amount of charge generated, to prevent overcharging the battery.
    Generally when snow driving in a regular car, you want to be in the highest gear possible to prevent the wheels locking up under the influence of engine braking. Therefore, stay out of B mode which simulates a lower gear.
  17. patsparks
    10,664
    569
    Yeah, what he said.
    Thanks Mike.
  18. Arniesea
    Arniesea New Member
    26
    Bremerton, WA
    Ah Ha! Thanks so much for correcting my misunderstanding. I drove a 1996 Camry for many years before buying our Prius 3 months ago. The Camry normally has overdrive "on" that saves gas by letting the engine drop back to idle whenever you let up off the throttle. Essentially "freewheeling." This is not good in snow and ice as you want a direct link between the throttle and the drive wheels for maximum control. Therfore, I would turn off the OD on the Camry in snow conditions.
    I assumed that this was the same case for the B mode on the Prius as it feels similar in the throttle pedal.
    After reading more about the PSD (Power Split Device) I now better understand what a different bit of engineering is in the Prius. (Damn elegant is what it is!)
    So thank you Patsparks for correcting my assumptions. I agree that light braking is the way to go since the various systems in the Prius will provide the best control. (ABS, PSD and VSC)
  19. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    If we are assuming driving on very slippery or icy or very slush filled roads then BRAKE mode will give the most firm and absolute control, especially when driving down a steep mountain slope. Of course Brake is selected early and not when driving overfast. All the other hypothetical technicalities may apply, ABS, VSC, when driving fast on a dry road. but that was not the question. Whether one is driving a Camry, a manual shift or a Prius: maximum gear control in snow is the goal with no sudden moves. Light braking in a overfast situation leads to heavier braking which leads to a out of control skid. I'm sure all Pat's comments were technically correct, but we are discussing driving in hairy conditions, which always means slow. I also had a Camry (84) and drove exactly as you did. The OP's initial instincts and past experience is/was correct!
  20. qbee42
    3,081
    As further clarification, when using B mode or just plain regenerative braking, all braking is done with only the front wheels. If either wheel looses traction, the control system disables regenerative braking and switches to friction braking, where full ABS is in play on all four wheels. This transition works very well, but often scares the bejesus out of drivers not familiar with it. The momentary reduction in braking feels as if the car is accelerating and shooting forward. Obviously it isn't, but our human brains interpret the reduction of deceleration as forward acceleration. Don't let if fool you into panic. Just keep pressing the brake pedal and everything will work just as it should with ABS.
