The MCE-5 VCRi, a new kind of conventional engine
Discussion in 'Fred's House of Pancakes' started by Tideland Prius, Feb 26, 2009.
  1. Tideland Prius
    16,444
    In these morose times where hard-to-come-by credit and a financial crisis are having their way with the auto industry, revival will come from the development of a new type of heat engine. Over the next 20 or 30 years, this type of mill will no doubt still account for nearly 80% of the market.
    http://www.auto123.com/en/news/car-...-new-kind-of-conventional-engine?artid=105454
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Very interesting!
    Combine variable compression with variable valve timing, and per-cylinder fuel monitoring and control, and you could expect V8 power out of 4 cylinder fuel economy
    Or, combine that into a 2 cylinder and get 4 cylinder power out of it
  3. Tideland Prius
    16,444
    Any idea how this works? How do they get variable compression ratio?
  4. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    When I first clicked this thread, I thought the title was a thread about the latest in HTPC front-end w/ PVR capabilities.
  5. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    The MCE engine has had a detailed website up for some years. One of the big advantages of it is the linear crank connection, which minimizes friction forces between the piston and cylinder wall.
    Here is a link to that webpage, which includes an aninmation of the operating engine: MCE-5 VCR Engine .
    This more complicated design is probably enabled by the use of computerized mechanical design, and improved materials technology. Its hard to see a pre-computer engineer successfully being able to manufacture this with all the mechanical stack-up involved.
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    PER CYLINDER compression ratio adjustment. Now that is cool
  7. qbee42
    3,076
    Compression is adjusted by varying the length of the stroke. This is fairly easy to do with a linear stroke.
  8. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    I've been doing that for years. :eek:
  9. qbee42
    3,076
    Short stroking? :rolleyes:
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Everybody hold on tight, we're going off the rails again
    baaaaaaaaaaaaaaaa
