Smartkey FOB warranty?
Discussion in 'Gen 2 Prius Main Forum' started by rascal86, Apr 19, 2005.
  1. rascal86
    rascal86 New Member
    My husband and I have been going back and forth on if the Smartkey FOB would be considered in the warranty. I haven't looked in detail or called Toyota yet on this, but my assumption is that it would be considered an accessory...and therefore not covered under warranty. Does anyone out there know for sure?
  2. FBear
    FBear Senior Member
    355
    Maplewood, NJ
    2015 Prius v wagon
    I would assume the answer to that question is "YES" as long as the car is covered under the warrantee.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I'd suspect they'd consider it part of the 1st year/12k mile warranty period if it was malfunctioning.
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    not being a part of the car does make it much more vunerable to abuse, but its not a cheap item to replace. i guess that is why they give you two of them
  5. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I'd say the original two are covered under 3/36 warranty unless obvious signs of abuse (corrosion, cracked, missing). I don't know what the warranty would be on a new fob that did not come with the car.
