Wheel weights on the outside after balancing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by btrotter, Mar 19, 2009.
  1. qbee42
    3,076
    I used to manage an engineering department in a company that made balancing machines. I don't think ours were ever used on tires, they were a bit expensive for that, but they were used on power generation turbines and the like. It's an interesting application.
  2. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    I am not familiar with the Hunter machine. I'm sure it is much more expensive than our machine. Every time I rotate tires I put them on the machine. Usually, only one or two will need any adjustment at all, but it is nice to know that they are in balance.
  3. btrotter
    btrotter Junior Member
    36
    North Carolina
    I took the car back to the tire store today. The "tire guy" at first said that the hubcaps are designed wrong. I told him that he should have put the weights on the inside of the wheel, and he said that he could do that for me....using the tone of voice that he would be doing me a favor in doing that. So I have to drop the car back off with them tomorrow so they can let it sit in the parking lot all day while they get around to it. So far I am very displeased with them. The tires themselves are really loud. They feel and sound like knobby tires on a 4x4.
  4. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I would tell him a few words and take my business some where else, and let him know that they are not the only gig in town.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yeah, if that had been me, they'd quickly find out it's NOT a good idea to piss off the 800 lb mean bald gorilla in the room
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    Strobe? Laser? Dial? Don't tease me and just leave me hanging ...
  7. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Curious - what type of tires did you buy that were so noisy?
    There's no reason they can't stick weights on the inner and outer edges of the "inside" of the rim for a decent dynamic balance.
  8. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    I just had Michelin Energy Saver A/S tires installed. They put the tire balance weights on the outside. However, the weights prevented the wheel covers from fitting flush against the wheel.
    So I went back and they re-balanced and placed the weights on the inside. No problem. There is no wheel vibration at highway speeds, so it CAN be done.
    Marvinh
