Scangauge
Discussion in 'Gen 2 Prius Technical Discussion' started by shar1950, Mar 20, 2009.
  1. shar1950
    shar1950 Junior Member
    merritt, bc canada
    I had my car in for the oil and filter change last week. I had the Scanguage hooked up and when I got the car back that night, the guage was disconnected. I plug it back in and now it will not connect and get any info. The unit just keeps says "connecting" and never does. Is it possble for them to stop the info from going to the OBII ?? What can I do now ?? I know that unit works because, I plug it into my other car and it will display every thing.
  2. CharlesJ
    CharlesJ Member
    467
    29
    Monterey
    Did you have the car on 'ready' mode?
  3. shar1950
    merritt, bc canada
    The car is running when I plug the scangauge in. I have tried plugging it in different ways and still nothing happens,just says "connecting ".
  4. CharlesJ
    CharlesJ Member
    467
    29
    Monterey
    Then, you need to wait for more experienced folks to respond:D
  5. ThePackage
    ThePackage New Member
    74
    Why don't you contact ScanGage directly?
  6. shar1950
    merritt, bc canada
    This has nothing to do with the ScanGaugeII,the dealership that I had the car in at, told me a few time not to plug anything into the OBDII. I have had the car into this one dealership for all my regulater maintence [ 2007] and they allways disconnect it every time when I get back.
    Yesterday I took the car into a local tireshop and had the guys try to read from the OBDII plug and they also could not get any reading, so they have remove the signal going to the OBDII.
    My question is where would they disconnect it at ? Where does the wires from the OBDII go to ? Is there a plug local some where inside of the car or out in the engine area.
  7. bwilson4web
    16,118
    There are two sides to the OBD connector. One side is in the cabin but the other is on the other side of the mounting. It sounds as if a 'ham fisted' technician reached into the back side of the connector and stressed or broke the inside connection. Less likely, they may have pulled on the wiring hard enough to disconnect it from the other socket.
    IMHO, the oil change shop probably did it, which is also means I wouldn't do any more business with them. I'm afraid you'll have to ask your local Toyota shop to diagnose and fix the problem.
    There is one improbably failure mode ... the oil shop scanner broke or destroyed the connector. Not likely, it can not be ruled out. Again, the Toyota shop can fix it.
    GOOD LUCK but it sounds likely to be a $200 problem.
  8. shar1950
    merritt, bc canada
    Where is it located on the outside of the cabin, behind the engine,looking from the front of the car ? This is not your local oil change shop that disconnected or damaged the OBD connector, it's the Toyota Dealership where I purchase the car from.
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The red flag is waving. Why don't they want anything plugged into the OBDII? The ScanGauge is only a reader that can't damage anything. In NJ the car won't pass inspection if the inspection station can't communicate with the car.
    Sounds like it is time to find someone cheaper to change your oil.
  10. shar1950
    merritt, bc canada
    Well I will not be taking my car back to that dealership again for sure. I still need to locate all the connection points to that OBDII,so I can hook-up my ScanGuageII and get it working.
  11. RWB
    RWB New Member
    Bad Homburg near Frankfurt, Germany and frequently
    Hi. I'm just a user, no expert. But I've tried to decypher a few parts of the TechRef.
    If the OBD plug has not been disabled by some sort of reprogramming an ECU (which doesn't seem likely to me because of the nature of a bus system) and if the reason is an electrically broken circuit, the few things I've found out are as follows:
    - "There may be an open circuit in the CAN bus main line and/or the DLC sub bus line when the resistance between terminals 6 (CANH) and 14 (CANL) of the DLC3 is 69 Ohm or more. (Power switch off)"
    (They are writing as well, that if this resistance is below 54 Ohm, there may be a short circuit in the CAN bus lines, but I hardly believe that this can be the case if the car is operating normally.)
    - DLC3 is the name of the connector used for Scangauge (Data Link Connector 3). As far as I can see in the TechRef, its Can H and Can L wires are routed to pin 21 and pin 10 respectively of Junction Connector J15, alternatively called J/C1, which seems to be located at the far left in the dashboard. Since this Connector J15 connects several important ECUs to the bus, the car probably would stop functioning correctly if an open circuit beyond Connector J15 would occur, so those pins 21 and 10 should be the last possible disconnected location. (Again: I'm no expert, just citing the Specs.)
    J15 connector: two rows of eleven pins each, wire harness view shows them right to left if the straight side of the housing is down, pin 11-1 top, pin 22-12 bottom. For better orientation:
    Terminals <> Connects to
    J15-6 (CANL) <> J/C2 (CANL)
    J15-17 (CANH) <> J/C2 (CANH)
    J15-7 (CANL) <> Power Steering ECU (CANL)
    J15-18 (CANH) <> Power Steering ECU (CANH)
    J15-8 (CANL) <> Battery ECU (CANL)
    J15-19 (CANH) <> Battery ECU (CANH)
    J15-9 (CANL) <> Steering Sensor (CANL)
    J15-20 (CANH) <> Steering Sensor (CANH)
    J15-10 (CANL) <> DLC3 (CANL) !
    J15-21 (CANH) <> DLC3 (CANH) !
    J15-11 (CANL) <> Skid Control ECU (CANL)
    J15-22 (CANH) <> Skid Control ECU (CANH)
    (But: Right Hand Drive version uses different terminals...)
    Be careful. There are more 22 pin connectors than J15.
    I hope that this can be of some help.
    B)
  12. shar1950
    merritt, bc canada
    Thanks RWB... I will have to read this afew time to get it perfectly straight. I will try tomorrow to locate the wires and see what I can find. I know that there is wiring harness,with lots of plugin on the right side behind the glove box.
  13. RWB
    RWB New Member
    Connector J15 is not at the right side of the car where the glove box is, but at the FAR LEFT side, according to the TechRef pictures. There is a similar connector ar the far right side, but that is not the one where the wires of DLC3 are connected to.
    B)
