2010 Prius battery capacity
Discussion in 'Gen 3 Prius Main Forum' started by Per, Mar 26, 2009.
  1. Per
    Per New Member
    232
    San Antonio
    The 2010 has the same type battery as the Gen II Prius, but I don't remember seeing whether the 2010 has the same battery capacity as Gen II. Anyone?
  2. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Yes. Same capacity, 6.5Ah 201.6V.
    Ken@Japan
  3. qbee42
    3,079
    They are, however, using it a bit more, so the effective capacity is a bit larger.
  4. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Yeah, but the new 2010 battery can give up to 27 kW of instant power instead of current model's 25 kW peak power, that's 2 kW more.
  5. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I've heard 2010 Prius is going to use same 40-80% SOC range.
    Ken@Japan
  6. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Yes, I believe so, but the instant max delivery power has nothing to do with SOC range, does it? Am I missing something?
  7. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Hi João,
    You're right, but we're talking about the capacity, not power, on this thread.
    Ken@Japan
  8. qbee42
    3,079
    Good point.
  9. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    OK, so I will refrain from adding useful information related with the topic from now on... <G>! :(
  10. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    I seem to recall reading that in the Escape hybrid Ford gets more capacity out of their NiMH battery pack by widening the SOC margins at the upper and lower charge boundaries (80% and 40% in the Prius).
    Does anyone know any details? Stretching the Prius pack boundaries to 90% and 30% SOC would give a 50% increase in pack capacity, although these end points probably move too far from the flat part of the pack voltage curve.
    Maybe Toyota are just being very conservative for warranty reasons.
  11. qbee42
    3,079
    Not at all. I brought it up originally, and said "good point" to acknowledge that my answer was wrong in relation to capacity. Power output is still relevant.
  12. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    The Ford Escape hybrid has active cooling from the AC system. But while the SOC range might be a tad larger the useful power is a bit smaller since Ford was very conservative. The Fusion Hybrid I believe has more power available.
    Wayne
  13. Per
    Per New Member
    232
    San Antonio
    Thanks, guys!
