concerns ab mounting safe under Driver's Seat
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Aces, Mar 27, 2009.
  1. Aces
    Aces Member
    66
    Seattle
    I'm considering mounting a slim safe for valuables under the Driver's seat. To be any good, I'd want to bolt it into the floor. But I'm not sure how best to figure out what's going to interfere. I don't have the DVD Navigation Package, so it's not in the way. But there are some flattened plastic openings that almost look like heater ducts for the blowing warm air to the back seat area. Can anyone confirm this? If they aren't ducts, could they be used to route wiring for the DVD Nav unit?
    And if possible, I'd like to route 12V DC power there, to conserve batteries for the electronic digital keypad. I found a safe that will fit okay. But it would cover those (duct?) openings.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Well, here is the most interesting idea of the day!!!
    How tall is the safe? I think the under seat idea has merit, I just wonder how much room do you have to play with? What is the HWD O.D.of the safe? Then what is the available HWD under the seat? My thinking on mounting with the goal of not obstructing the opening of the safe's door, is either machine a plate, of what ever material you deem worthy, I.E. Plastic, Aluminum, and or Steel! Make it thick enough to lift the safe just enough off the floor so as to not obstruct the vents. Of course the plate shoud not be too thick, just enough for clearance. I would aso try to mount the safe as level as possible. I assume you want the door to open facing forward. When you pull the seat out to mount the package, make sure to take the Positive cable off the battery. The seat has an airbag. It would sure dampen the day if it went off! Just disconnect the pug to the seat, after removing power, pop that baby out and you should be able to do a easy, class install!
    Good luck, I'd like to see pictures when your done!!
  3. qbee42
    3,082
    Heater ducts.
  4. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    hmm... a safe under the seat... That would be neat if accessible while seated. Would be a great place to stash my gun.
  5. Aces
    Aces Member
    66
    Seattle
    So they are Heater Ducts... Darn. That will complicate things. kk6pd, you have a good idea. If I make an inverted, flattened "U" shaped plate, heat could flow underneath it. I'm guessing the DVD Nav unit is narrow enough to not block the vent?
    I have a particular safe in mind, that's 3.5" tall at the back, & 4.9" tall at the front (8" Wide). I plan on mounting it with door facing aft. It's not as convenient oriented this way. But the height limitations require it.
    And Frayadjacent, you are spot on. I didn't want to bring that up. Because it's easy for the whole thread to run off topic. I've recently taken to defensive pistol ownership. And even with a CPL, there are many places where you can't carry. And IMHO, the only thing worse than loosing my pistol, would be to let it fall into the hands of a criminal. Hence the gun safe. I'm looking at a GunVault Mini. I actually made a cardboard mock-up of it, to see if it will fit. I think I can raise it a little, but I have to be careful about the wiring to the seat snagging on it if someone adjusts the seat.
    If I'm able to do this mod, I'll post pictures to help others. Thanks for all the ideas.
  6. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    How about installing some locks on the hatch box and use that as a safe?
  7. Frayadjacent
    375
    Austin, TX
    Aces, I had thought about getting an inexpensive Uncle Mike's holster for my 'car gun' (S&W 637) and somehow securely attaching it to the bottom of the seat. I'm not so sure the undesirable types will bother looking under the seats... mostly they'd go for things out in the open like GPS units and phones or purses, and then look in the usual storage compartments for other loot. I rarely keep anything valuable looking in the open in the car, but I'm still going to get the windows tinted dark. I've had a couple cars done with the darkest legal tint, and it's about impossible to see anything inside the car at night. I also use(d) a front window shade even at night. The less they can see in the less they'll want to risk breaking in for nothing.
  8. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    It's OK to block the rear heater vents. I stuffed some foam in mine to get more heat up front without any ill effects. The air just follows the path of least resistance.
  9. qbee42
    3,082
    Mounting a firearm over the vents might give new meaning to the expression "packing heat". :)
  10. Aces
    Aces Member
    66
    Seattle
    I spent some time yesterday playing with different position options with the cardboard mock-up. And I discovered that the safe is narrow enough that by shifting it towards the outside of the car as far as possible (w/o interfering with sliding mechanism for seat), the heat vents are only "mostly" blocked (reminds me of a line from "The Princess Bride" movie). So I've ordered the safe. I'll update to this thread, as I make more progress.
    As for the idea of mounting a holster under the seat: here in Seattle, in 2004, our chief of police (Kerlikowske) got his pistol stolen from under the front seat of his car. It was quite an embarrassment then. But he wasn't the most liked among law abiding gun-owners; because he was against 2nd amendment rights. Anyway, it's events like that, that have made me avoid anything short of a concealed lockable box. But one drawback with what I'm doing, vs the holster idea, is that it's much harder to stow/retrieve from the safe. I think I could open it if sitting in the passenger seat. But as the normal driver, I'll have to pull over short of my destination; and try to be discreet.
    I plan on bolting the safe to the floor using washer like spacers. I've found one existing bolt that I can use. I'm guessing it 's there to hold the DVD Nav unit in place. I'd like at least one more bolt. But I'll have to try to figure out how to avoid drilling into something I shouldn't. Does anyone out there have access to Toyota's online shop manuals? if so, it'd be nice to know what's being routed through the area under the driver's side front seat.
  11. Frayadjacent
    375
    Austin, TX
    Hmm... I'm wondering... if a small safe like box could be attached to the seat, with a solenoid lock tied to the door locks or security system... the casual smash and grab wouldn't be able to access the box.
  12. Aces
    Aces Member
    66
    Seattle
    BTW,
    I did finish this mod several months ago. I found there's a tapped hole I could use to bolt it down with. And I glued Velcro hooks to the bottom of the safe, so it couldn't be rotated around to try to to loosen the bolt. I had to be careful in locating it, to avoid the seat hitting it when sliding it for/aft. And it only covers half the vent for the back seat area. I also had to move the external power supply jack lower. to avoid the slide for the seat. But I haven't tried to figure out a way to get 12V power to it. So I wasted a little money, by getting the deluxe model. The safe works great. But I have to get at it from thru the rear door.
  13. MWA3C
    MWA3C New Member
    I know this is an old post, but i have a new idea...
    After reading through this post, i have given some thought to modifying the center console and installing a compartment door inside, on the bottom of it.
    Appears it should just open to the hidden front sliding tray.
    Could secure the front tray in a closed position, install a door inside the console opening to the tray below, and use the same lock used to secure the trunk compartment (cabinet lock sets from lowe's..)
