Video: 2009 Toyota Venza [& Prius] iPhone Streaming Bluetooth Audio
Discussion in 'Gen 3 Prius Main Forum' started by ggood, Apr 2, 2009.
  1. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
  2. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
  3. Tideland Prius
    16,508
    For bluetooth handsfree, it'll automatically sync. I'm sure if you chose the BT tab, it'll try to auto sync with the last phone used.
  4. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Nice! Now, how about streaming the freaking phone book?
  5. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Prius Team confirmed that is already possible on the venza, and therefore on the 2010 Prius.
  6. zenMachine
    3,355
    300
    Excellent. Would be nice to get a list of compatible phones.
  7. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    Oh great now my iPhone battery will only last 30 minutes instead of an hour. Still would have been better to have an iPod connection port or USB so you can access and listen without having to drain your battery.
  8. ashileedo
    ashileedo New Member
    I think you can plug your phone into the adapter charger. This just keeps you from having to plug your iphone in separately.
  9. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    There are also car charger adaptors that use the sound signal from the bottom connector. Instead of connecting the aux RCA cable to the top of the phone, you plug it into the car charger. From a sound quality perspective, a hardwired connection is still going to be better than bluetooth.
  10. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    You can look-up the phones that are compatible with the Venza here:
    Toyota Bluetooth Phone
  11. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    If you have to plug it in to charge it, then might as well make it a full blown iPod port. Right? I mean, what's the advantage of having a bluetooth stereo link?
  12. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    you do realize that there will be an iphone/usb accessory for Prius you will be able to purchase and get installed at Toyota dealer?
    Advantage of having bluetooth stereo is that you can have phone other than iphone and it will work. You are not being limited in selection. Also, you will be able to use any music player that has A2DP support.
  13. spwolf
    3,156
    440
    Eastern Europe
    also, let me point "small" error in the article - A2DP is supported by many phones. Standard itself was released in 2003, and iphone is probably last smart phone that got support for it. GSMArena lists 637 phones that support A2DP in their database.
  14. MUPAUL
    MUPAUL 55 MPG Average
    60
    Pleasant Prairie, Wisconsin
    Will A2DP be included on the Prius III package? I read somewhere that it won't be. I sure hope its included Thanks
  15. saxamoophone
    saxamoophone New Member
    33
    Orlando, FL
    Prius III (and up) w/ nav will have it. I guess it needs the Nav to work..which is kinda lame....( sync can do it just fine without a nav...)
  16. ceric
    ceric New Member
    1,114
    Fremont, CA
    A2DP is fun for a while. After that, you will find that it sucks power 2X that of regular BT channel (because it actually uses TWO!). It can work up to 20-30ft away, after that the link would drop (in a car that is not an issue).
    Above all, you get the FM quality (down from near-CD quality of MP3 players) due to wireless bandwidth limit.
  17. MUPAUL
    60
    Thanks for the response. That's too bad that it will only work with NAV. I for one won't get NAV due to price and the fact that when I need maps/directions, my cheap little portable works fine and can be transferred to other vehicles and rentals. I hope they have a decent USB connection available from the dealer with steering wheel controls. Otherwise, for a car that is so advanced, it will miss a key feature that is standard on the Insight EX (USB connection).
    I'm guessing that there are a high number of Prius buyers who are also iphone users (ot to mention ipod users). I wish a USB connection was available from the factory as standard or at least as an option.
  18. zenMachine
    3,355
    300
    What would be really cool, IMO, is some sort of universal USB docking station that allows both charging and playing audio from a device while at the same time serving as a holder/mount. Of course different adapters would be required for different devices.
    I must be dreaming...
  19. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    That's what I'm trying to say, just put in an ipod/phone/usb port and be done with it.
  20. PriusCrazy
    213
    28
    Triad, NC
    Heck no man, It ain't far from reality! :thumb:
    It wouldn't take very much really. Most all devices come with a cable that connects the device to a standard USB port. Why not just provide the USB "mate" connection, which according to the USB spec, would supply power to the device.
    I say it's *easily* doable now...
