Two Air Filters?
Discussion in 'Gen 2 Prius Technical Discussion' started by Duc, Apr 9, 2009.
  1. Duc
    Duc New Member
    24
    Kingsland, TX
    I opened my housing (just for fun) and see there are two filters in the housing.
    Anyone know why?
    Is this the cabin filter I keep reading about?
    Clif
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    What "housing"? There is only one engine air filter...unless you mean the little permanant carbon filter fixed inside the lid?
    The cabin air filter is behind the glove box and accessible from within the cabin only.
  3. Patrick Wong
    18,200
    6,500
    Hi Clif,
    If you are talking about the carbon filter located in the lid of the engine air filter housing, its purpose is to capture hydrocarbons that come up from the intake manifold when the engine is off. As Evan said, this does not require maintenance, just don't get it wet.
  4. Duc
    Duc New Member
    24
    Kingsland, TX
    Ahhh.... So does the air go through it first or does it just capture fumes?
    Found the cabin filter right after I posted the question, thanks.
    Clif
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The carbon thing adsorbs gasoline VOC's. My FJ has one too, it's considered permanent
  6. CharlesJ
    CharlesJ Member
    467
    29
    Monterey
    I bet if you trace the air passage from the intake duct you will see that the carbon comes after the replaceable filter.
  7. Duc
    Duc New Member
    24
    Kingsland, TX
    That is correct. So I read on several other Toy websites people remove those. Any one done that here?
    Clif
  8. Patrick Wong
    18,200
    6,500
    Hi Clif,
    I notice your signature block indicates that you get 52.2 mpg. My guess is that you don't achieve this via frequent full-throttle acceleration - am I correct?
    Since the only point of removing the carbon filter is to potentially slightly improve air flow to the engine, at the expense of emitting more hydrocarbons into the atmosphere, it doesn't seem that this is a modification that a Prius owner would be quick to do.
    If this concerns you, I suggest that you remove the housing lid, so that neither the carbon nor the paper filters are in the air flow path. Then do a full-throttle acceleration run and see whether you note any performance difference or not.
  9. Duc
    Duc New Member
    24
    Kingsland, TX
    Good points, I was simply curious.
    Thanks
    Clif
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I love that about the Prius owners doing mods to the car. They are environmentally conscious.
    When I had my Celica, people in the newcelica.org forum were removing the butterfly valve to gain a few extra hp without any regard to the emission.
  11. Duc
    Duc New Member
    24
    Kingsland, TX
    O I still want to do it I just want an extra box top to cut it out of and to modify a bit more. Sure it may/may not do anything but it might, problem is the cheapest lid I have found is $45. To much to try something that might not do anything.
    Clif
  12. brice197807
    brice197807 New Member
    Columbus
    I change my carbon filter in my home furnace every 3 months becasue it no longer removed cig smoke like a new one. I cant understand how this filter is perm and how it can somehow remove hydrocarbons for millions of miles. Its a nice trick but does nothing in the long run beside restrict air flow and collect dirt.
  13. richard schumacher
    7,664
    1,046
    United States
    Presumably it's to keep oil and fuel vapors from escaping the engine after shut-off. They get re-emitted by that filter and burned when the engine runs. Any crud that might clog it up gets stopped by the replaceable upstream paper filter (unless someone has removed that, hoping for more "performance").
  14. Politburo
    Politburo Active Member
    971
    208
    Just because you don't understand how it works doesn't mean it's a trick. Cig smoke is partially a particulate, and filtering particulates is different than filtering VOC. A furnace filter is also a completely different application.
    The filter does not permanently collect VOC. The collected VOC is returned to the intake air and burned off during vehicle operation. This is why it does not need replacement. It's located after the main air filter in the airflow, so if it's getting dirty, your engine is too.
