Home renovation project
Discussion in 'Fred's House of Pancakes' started by Patrick Wong, Apr 12, 2009.
  1. Patrick Wong
    18,200
    6,500
    We had granite countertops installed in the kitchen, first floor bath, and laundry room. Enough granite remains so that we will also have a second floor bath done later this coming week.
    The contractor's bid was for demolition and granite countertop installation so I took it upon myself to install the new faucets, do the sink drain hookups and electrical work. My area has hard water, and I needed to replace all of the water supply valves.
    Several years ago I had bought a cheap puller to remove the compression sleeve used on copper pipe. This is sold at Home Depot and Lowes for around $20; this puller is close to worthless and I do not recommend this tool. See first picture, right side.
    I found a good plumbing store and bought the puller shown on the left side of the first picture. This cost <$40, and does a great job. I suggest spraying WD-40 on the copper pipe first so that the copper ferrule will more easily slide off the pipe.
    I had to cut some of the PVC drain pipes and used a Dremel tool for that, this makes very quick work of that task.
    We had a new gas cooktop and downdraft vent installed in the kitchen island. The installers used a huge saw to cut away some of the floor in the island because the ducting had to be modified. I covered up the jagged hole with Masonite board so that things wouldn't fall into the hole. See the second photo.
    Had I anticipated the need for this sawing, I would have suggested using my jig saw to cut away the floor, instead of the installer's huge saw with a 2-1/2 foot long blade. That saw looked like something you would use to cut down a big tree...
    I also had to move the AC outlet box as the original (see photo of rusty box) got in the way of the new downdraft duct, so I got to learn how to work with flexible aluminum conduit. The new box has an extension on it because I couldn't get four cables and the outlet to all fit into the space provided by one box.
    The last few photos show the completed work.
  2. oxnardprof
    oxnardprof Member
    250
    17
    Oxnard, CA
    Thanks for this information - although it is not even Politics (what I have thought was in FHOP).
    We are planning similar work, although I am considering Caesarstone or another renewable countertop material. What is the model of downdraft burner you installed? I also have the island with downdraft hood, and I will replace with the same type of cooktop.
    The finished product looks very nice.
  3. Patrick Wong
    18,200
    6,500
    Thanks - Fred's House of Politics is the site for political discussions. FHOPancakes is the catchall for miscellaneous ramblings.
    The downdraft vent is made by Broan, model 273603. 500 cfm blower, when you set this on full speed it sounds like an airplane ready to take off. It is very effective, we cooked bacon yesterday and after we were done there's not much smell of bacon around.
    Product Detail
    The vent has a 10" rectangular opening that can be adjusted to either vent at the bottom as was the case with my installation; or to the left; or to the right. You can also shift the vent several inches by sliding the box containing the motor laterally.
    The gas cooktop is a 5-burner GE Profile, which Consumer Reports rated very highly.
    http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JGP975SEKSS&SITEID=GEA
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Nice work. Where does the exhaust come out?
  5. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Thanks Patrick.
    I love your choice of granite pattern and color. It's both beautiful and functional -- hides dirt, water, toothpaste and soap residue well.
    We just finished putting granite countertops in my mom's kitchen. One of my brothers chose black, and I wished he had chosen a pattern and color like yours.
  6. Patrick Wong
    18,200
    6,500
    The ducting goes under the floor, then rises up the wall and vents a couple of feet above ground.
    Thanks, Tom. Dark granite patterns have been popular in the past. We like lighter colors and this matches the kitchen cabinets and the light tile floor.
    The granite is called Juparana Colonial and a closeup can be found here. It has little silver specks (not visible in the photo) which make it very interesting to look at:
    EarthStones Granite and Marble - Gallery
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Patrick
    Excellent work on the remodel
    I have a personal theory on home remodeling: rent a bulldozer and repeatedly ram it into the house until only very tiny pieces of the house are left. You should probably evacuate any other people and pets from the house before firing up the bulldozer
    I don't have much patience for remodeling, and by my count I have remodeled 7 homes over my lifetime. I refuse to remodel another home.
    For some reason, I'm just like Mike Holmes on tv: I start a "simple" project, discover something is haywire, and next thing you know, the entire house is stripped down to the studs
    Amazing true story: I once tried to add an upstairs laundry in an old home I had, back in Utah. Everything went well, until I turned the water back on. The pipe I had tapped for the cold line, sprung a leak at a fitting just below where I tee'd into
    Ok, fine, took things apart and soldered again. Then the pipe sprung a leak at the NEXT fitting further down. I swear, by the time I got done, it was 2 days later and I had pretty much replaced all the copper piping in that home
    My thick muscular neck was also pulsating in a very alarming manner when I was finished. I really should see a doctor about that. Evan??
    jay
  8. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    ...I also had to move the AC outlet box as the original (see photo of rusty box) got in the way of the new downdraft duct, so I got to learn how to work with flexible aluminum conduit. The new box has an extension on it because I couldn't get four cables and the outlet to all fit into the space provided by one box...
    What are you nutz? Move the electrical off the floor where pooling of water and other leaks will occur and use GFCI (isnt' it the law in your town?)
  9. Patrick Wong
    18,200
    6,500
    Hi Ken,
    The old box was mounted on the island floor at the rear of the cabinet. The new box is mounted on the island floor on the right side of the cabinet (as viewed with the cabinet doors open.) There's no water pipe plumbing in the cabinet, so no reason for any water pooling to occur there. The island floor is raised up five inches compared to the kitchen floor.
    All of the electric outlets near the kitchen sink that are intended for general use are protected by GFCI, but the two outlets within the island dedicated to the cooktop and downdraft vent are not. Also, the two outlets below the kitchen sink dedicated to the dishwasher and disposal are not protected.
  10. kenoarto
    398
    Chicago, IL
    Oops, I assumed an under skink cabinet. Nonetheless, why not spend the extra $10 and put GFCI. Liquids are indeed involved where cooking.
  11. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    When moving into a house, I just flat out replace all outlets in Kitchen, Bathrooms, and Outdoors with GFI. It's so easy.
  12. koa
    koa Active Member
    980
    45
    Hawaii
    You can also replace the circuit breaker with a GFI breaker that will protect every outlet on that line. Or you can replace the first outlet on the line and wire it so every outlet after the first one is also protected.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    GFCI breakers are pretty expensive, but more reliable than receptacle GFCI's. In older homes I had nothing but trouble by retrofitting GFCI's, due to the flaky condition of the wiring.
  14. Patrick Wong
    18,200
    6,500
    Yes, this is how my home is set up. Each bathroom has a GFCI outlet and other outlets are protected by that. The kitchen also has a GFCI outlet that protects the adjacent outlets near the sink. The AC outlets mounted to the exterior of the house have individual GFCI.
  15. oxnardprof
    oxnardprof Member
    250
    17
    Oxnard, CA
    Would you feel comfortable sharing the cost of the renovation? I am waiting for my first quote (for some reason, the contractor is slow in sending me a quote).
    I also wonder if you looked into the fans, and the noise associated with their operation. You mentioned that the fan is noisy - and I wonder if you can tell how much is wind noise, and how much is vibration, magnisifed by contact with the center island. I suspect that in my current installation, the blower's vibrations are transmitted to the island, amplifying the sound level. I wonder if there is a installation method that would isolate the blower from the island (in terms of vibration.)
  16. Patrick Wong
    18,200
    6,500
    The total cost was < $12K:
    $7.7K for the granite, demolition and installation in the kitchen, two bathrooms, and laundry room. 150 sq. feet of countertop space was done so the price was ~$51 per square foot, a very good price considering the granite quality.
    $2K for the stainless steel GE Profile 5-burner cooktop and Broan downdraft vent
    $1.3K for two stainless steel sinks for the kitchen & laundry room, three porcelain sinks for the two bathrooms, and bathroom and kitchen faucets. I reinstalled the previously installed kitchen faucet in the laundry room as it was made by KWC, a Swiss brand, and in excellent condition.
    $0.2K for installation of the cooktop and downdraft vent
    $0.2K for a plumber to help me with a difficult supply valve installation where the copper pipe was deformed; while he was here I had him do five supply valves in the kitchen and laundry room. I did the six supply valves in the bathrooms and all of the faucet and drain hookups.
    $0.2K for flexible stainless steel water supply hoses, supply valves, electrical conduit wiring supplies, a few PVC drain pipes needed since the bathroom sink drains were in a different position compared to original, a 2 ft. long natural gas flexible supply hose, a metal duct converting 10" rectangular to 6" round, and miscellaneous.
    Regarding the vent fan noise, it is at an acceptable level. The vent enclosure is mounted at four points to the cabinet. It has two mounting brackets at the bottom of the cabinet, and two brackets at the top which screw into the plywood below the granite. Of course it also is attached to the duct work that exits under the floor.
    What I really liked about the contractor was that everything was done on schedule, and the schedule was very short - so the house was not in disarray for an extended period. The first floor demolition happened on a Monday and the granite was installed the following Monday. It would have been scheduled for the prior Saturday except I wasn't sure that the cooktop and vent would be delivered on time. The second floor bathroom demolition happened this past Monday and the granite was installed Tuesday. I completed the plumbing work this morning (had to buy a drain pipe extension from Lowes for one of the sink drains) and the entire job is now done.
    My wife invited three contractors to bid. One ended up not bidding. Of the two that bid, one was much higher than the other. We were comfortable accepting the lower bid because we had seen other granite countertop work done by that contractor in our neighborhood.
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    Patrick
    Gotta hand it to you, excellent job on the reno. But I bet next time, you just rent the bulldozer instead
    jay
  18. willicooper1
    willicooper1 New Member
    Yeah............you have done great work.......
  19. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
  20. Patrick Wong
    18,200
    6,500
    Thanks, this happened one year ago, and we did this work in prep for selling our Orange County home. That transaction closed in July 2009 and we moved to southern AZ.
    In retrospect, looking at those pictures one year later, its hard to believe my wife & I went through all that work... We are very glad to be out of OC now.
