BT Tech Stiffening Plate "Woyks" & also Transmission in 'B'
Discussion in 'Local Prius Club Main Forum' started by harrybet, Mar 11, 2009.
  1. harrybet
    harrybet Junior Member
    Kamuela,Hi.
    Have '08 #2 Package Prius ....with 5 K mi. ; just installed the stiffening plate ..to our satisfaction... perceptable improvement in feel & cornering . Easy install as described.
    Next planned improvement ... GY Triple Treads..
    By the By 1st oil change... now on Synthetic ....per AAA rec'md.
    Any guidance on use of 'B' on downhill grades appreciated ....was told by Toyota National it's a purely braking program...was on a particularly steep long run down hill 15 min....and could smell pads by the end...just riding the brakes manually Trans. in 'D'...subsequently looked up 'B' and it's use in the owner's manual...incomplete guidance ...so called Toy National..and received a little additional info ....it's a programed braking protocal having nothing to do w/ transmission(engine nor electric motor). When the pads wear , should I go to 'performance' pads?& rotors(drilled or slotted) ?
    thanks Prius fans...
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Here, READ THIS....
    B-mode made clearer
    [SIZE=+1] [/SIZE][SIZE=+1]There is a lot of mystery about the "B" shift selector position in the
    Prius. The official name for it -- Engine Braking -- should provide a
    first hint as to what it is really for. Page 137 in the '04 owners' manual
    spells it out fairly clearly, in fact. But somehow a whole body of mythology
    about "more regeneration" and extra battery-charge magically appearing from
    nowhere has sprung up since, and really needs to be permanently debunked.
    In the smallest possible nutshell, "B" mode is designed to WASTE some energy
    that the car cannot recover and store. But to fully understand "B" mode one
    must also take numerous other running conditions into account -- speed,
    temperature, battery state of charge [SOC], brake pedal pressure, etc.
    A preliminary to this was originally posted at Priuschat on Sep 20 2005,
    but was subsequently lost in the Great Database Fire. In recreating the
    information, several other posts and bits of mail were pulled together and
    rewritten. This is long and detailed and hopefully not *too* technical,
    but tries to cover everything known and verified about "B" mode. It is
    also worth reading Graham Davies' explanation, at
    http://prius.ecrostech.com/QandA/BMode.htm
    A few basics must be understood up front:
    The job of "B" mode is to help stop the car, not to save or
    recover energy. In fact, it largely throws energy away.
    The difference betwen "D" and "B" only appears during
    decelerative coasting [no pedals pressed at all] or actual
    braking. When accelerating or just maintaining speed,
    "D" and "B" produce the same behavior.
    All shift positions, with the exception of "P", are simply
    electrical states within the control computers. In "P", a
    locking pawl engages gear teeth to lock the front wheels
    against turning, but that's the ONLY mechanical change.
    Regenerative braking really has nothing to do with the
    physical wheel brakes on the car -- the regenerative and
    friction systems certainly cooperate closely, but they are
    separate systems. "B" mode has nothing to do with the
    physical hydraulic brakes at all, other than that the two
    systems can combine forces to help slow the car.
    Nonetheless, hydraulic braking, regeneration, and "B" mode are really all
    parts of the *overall* braking functionality. A good overview of the
    braking systems in both the '04+ and earlier "classic" Prius is in the
    technician-training material on hybrids available from Toyota's Techinfo
    site, in section "T072 Chapter 6 Brake system" and in the file
    ileaf/techtrg/techtpdf/techtrg/techtrg/cours/section6.pdf ...
    which is mirrored temporarily at
    http://techno-fandom.org/~hobbit/cars/cours-section6.pdf for
    reference. It does not really explain "B" mode well either, and in fact
    this document may be one of the sources of confusion -- where it says
    selecting "B" ... will maximize regenerative efficiency
    and is useful for controlling speeds downhill. In "B"
    mode about 30% of the energy is recovered.
    This is very misleading, because what it does *not* say is that in normal
    "D" mode with proper braking technique, considerably *more* than 30% of
    stopping energy is recovered! I think they meant "30% of the possible
    energy recovery" that would otherwise happen in "D" mode, but something
    got lost in translation.
    Going back to the original definition of "B" mode -- it takes energy to
    turn a car engine that is otherwise not running. Friction in bearings
    and pistons and cams can be significant, as anyone who tries to turn
    an engine by hand is aware. But more significant is that it takes energy
    to pump air through the engine -- without fuel and spark, an engine is
    really nothing more than a big air compressor. The amount of energy
    needed to keep all that turning and pumping is what causes the "engine
    drag" felt in conventional cars when the accelerator is released. And
    if the transmission is geared down, the drag effect is more pronounced
    because the engine must then spin [i.e. be pulled around against air
    and mechanical resistance] that much faster.
    In the Prius, however, under most normal conditions when the accelerator is
    released the engine shuts down entirely and leaves the car in electric-only
    mode. This would provide no engine-drag, so the Prius fakes a drag feeling
    electrically by having the main electric motor-generator [MG2] generate some
    current and thus present an energy load against the turning wheels. Above
    41 mph, the engine does still spin, but it is not fed any fuel or spark and
    the valve-timing is changed so that the air-pumping loss through the engine
    is minimized. Electrical energy is still drawn from the wheels by MG2
    regardless of the car's speed -- and the most useful place to send that
    energy is to store it in the battery. This is a regenerative stopping
    force, but in "D" with no brake pedal applied it is a fairly weak force --
    not one you could really consider as "braking". It is not enough to prevent
    the car going faster and faster down an appreciable hill, for example.
    Regeneration current into the battery in this state is between 10 and 20
    amps [out of a possible 100] depending somewhat on speed -- at 200 battery
    volts that's still 2000 or 3000 watts or more, which is quite a bit of
    energy from just gently resisting the car coasting along!
    Gently applying the brake pedal increases that regeneration current, up to
    a maximum of 100 amps -- 20 kilowatts -- and in the '04 and up Prius, does
    not use the physical friction brakes at all until they are needed. That's
    like the motion of your car powering four electric dryers at once, and
    it's *all* going into the battery pack! But even 20 kilowatts cannot always
    provide enough stopping power, especially at higher speeds, so anything over
    and above that must be supplied by the friction brakes. The rest of that
    energy then gets wasted as heat in the rotors and pads. But what if you're
    driving down a long, steep mountainside? Maybe that 20 kilowatts of
    battery-charging energy is enough to hold your speed back -- for a while.
    But eventually the battery gets full -- actually, to the 80% charged limit
    enforced by the computers -- and to protect the system, charging current is
    eventually reduced to zero, and the only thing now holding the car back
    from disaster is the hydraulic brake system -- which is now rapidly getting
    hotter and hotter and reaching its own limits on how well it can continue
    stopping the car. Brake fade, when the parts cannot absorb or dissipate
    any more energy, is a very real problem on mountain roads.
    Enter "B" mode. As in, "trucks use lower gear". By forcing the wheels
    to spin the engine and pump air, a good deal of that energy can be turned
    to heating the air going through the engine instead of heating the brake
    parts. Since fresh air is always coming into the engine, having it leave
    as much warmer air provides a convenient place to dump excess energy.
    In a conventional car the wheels push the engine around through the
    transmission, but the Prius needs to help that process out a little bit
    by actually having its combination of electric motors spin the engine.
    In this case, the valve-timing in the Prius engine is advanced to increase
    the amount of air taken in and the suction against the throttle flap -- which
    uses much more energy than the coasting-in-"D" scenario above. Either way,
    stopping power now comes from a combination of things and the burden on the
    friction brakes is greatly reduced, allowing the hill to be descended safely.
    "B" mode also increases regeneration current to 30 - 40 amps with no feet on
    the pedals, so the part about "more regeneration" is somewhat true. That
    is one of several mechanisms used to increase the "drag" feeling. That
    level also varies with the car's speed. However, the car's movement is
    often supplying much more energy than that, so what isn't captured in the
    battery is wasted by flailing the engine around. This is *not* more
    efficient usage -- it is almost always better to gently brake in "D" for
    maximum energy recapture, if you have room ahead to do it. This is one of
    the common misconceptions about "B" mode -- it does not create more energy
    from nowhere, despite how much it may feel like traditional "gearing down"
    and using the brakes less. In fact, for those times when the rolling *car*
    has too much energy for the battery, "B" helps get rid of it. In addition,
    using the brake pedal while in "B" mode behaves exactly the same as in
    "D" -- if there's any capacity left in the battery, the system tries to
    regenerate up to the same limit of 100 amps, above which the friction brakes
    are brought in to help -- the only difference in "B" that the engine is also
    spinning away against air pressure. Again, the hydraulic brake system does
    not care if you're in "D" or "B" -- it just supplies what the rest of the
    systems cannot.
    The only time the physical brakes are used *by preference* is during a
    panic stop, when the pedal is suddenly slammed down. The system senses
    this fast rate of change and immediately brings in the hydraulic brakes
    for faster and safer stopping with all four wheels. "B" mode makes no
    difference there, either. And of course all regeneration quits at less
    than 6 or 7 mph, when the motors aren't turning fast enough to provide
    useful power -- the physical brakes handle the last part of stopping.
    Many people can feel a sort of braking "sag" at the transition, although
    Toyota has managed to make that fairly smooth and seamless.
    If one thing must be understood here, it is the distinction between the
    BRAKES and the total BRAKING SYSTEM. The hydraulic friction brakes in each
    wheel cannot supply energy -- they can only waste it, throwing it away as
    heat to the air around them. Parts of the braking SYSTEM -- that one could
    consider as including the driveline and electric motors, the hybrid and
    braking computers, the battery -- can work together to recover energy and
    direct it around to where it needs to go. But when someone naively says
    "the brakes charge the battery", that's really rather wrong.
    Now with all of that said, there are a few funny quirks and factoids to
    know about "B" mode, none of which really help increase fuel efficiency
    but are interesting to know about regardless. In general, the amount of
    extra resistance given by "B" mode is sort of staged upward depending on
    the car's speed and how charged the battery is. Some of these conditions
    can be utilized in entertaining ways.
    Under 20 mph, if the engine is not already running and your foot comes
    off the accelerator, B mode simply regenerates reasonably heavily [30A or
    so] into the battery. This drops off around 12 mph to a lower current,
    and is then similar to being in D until regen capability kicks out entirely
    around 7 mph. So between 19 and maybe 10 miles per hour, you can use "B"
    to slow down in an energy-productive way, and essentially drive around in
    electric-only mode with one pedal -- but be careful to not do something the
    person behind you doesn't expect without showing brake lights! As soon
    as you crest 20 mph, however, the engine begins spinning -- to enable the
    system to dissipate more energy at the higher speed.
    If the engine is running and you come to a standstill while in "B" mode, the
    engine *stays* running -- just idling. The reason for this is not really
    known, but it is a way to continue warming the engine when it's cold out and
    you're stopped in traffic. Driving around in "B" during warmup also tends
    to charge the battery a little faster, since electric-only mode is avoided,
    but again at the expense of burning more fuel to do it. Engine start/stop
    transitions are avoided. Sometimes this state feels more surefooted and
    responsive in snow and other tricky conditions. People who have autocrossed
    the Prius have recommended staying in "B" for better and quicker control --
    having the driveline "fall on its face" the instant your foot comes off
    the accelerator pedal may be desireable behavior at times. This may feel
    familiar to some EV drivers, where regeneration control all comes from
    releasing the go-pedal in controllers without integrated braking features.
    Fuel usage in "B" is somewhat mitigated by the fact that when decelerating
    above some nominal speed, somewhere around 17 mph, no fuel is sent to the
    engine and it just spins "dry". It's still wasting energy and slowing the
    car, but there's no reason to throw away gas along with that. This is
    sometimes called "fuel-starve" mode, and is also used in some conventional
    cars during high-speed coasting conditions.
    It is difficult to tell when that 100 amp battery-charge limit is exceeded
    without extra instrumentation. When the battery pack is cold, that limit
    is actually lower -- down around 50 amps, until cabin heat begins to
    circulate through the battery pack ventilation ducts and the pack self-
    heats a little from being used. The system is quite good at protecting
    the battery against things like overcurrents, and sometimes that gets in
    the way. Slowing over bumps often confuses the regen mechanism, which can
    sometimes be felt by the seat of the pants as that same little braking "sag"
    right after the bump. The system has given up on regen at that point, and
    is now only collecting the "coasting" baseline 10 amps of battery current,
    and using the physical brakes almost entirely to stop you. Recovery from
    this situation appears to be time-based, so your best bet at that point is
    to slap it down into "B" for the duration of that stop since while you may
    spin off some energy in the engine, regen current *will* be a bit heavier
    than in your now pathological D-but-confused braking state and you might
    recover a tiny bit more energy. But don't get into the habit of using "B"
    to slow down unless you really need it -- that's sometimes hard to get used
    to if you come from ingrained years of "gearing down" in conventional cars.
    Many strange things happen when the battery pack gets up to "eight green
    bars" full level. The hybrid system begins doing several things to pull
    a little energy back out of the pack -- the engine will tend to spin in "D"
    mode even at low-speed, low-demand conditions, in fact just about in the
    same way as "B" mode does when the charge state is more normal. If "B"
    mode is selected in the full state during coasting, then the engine *really*
    screams and even more energy is pumped away. So while all the energy of a
    long descent cannot be captured, speed can be controlled in some interesting
    ways by creative shifting between "D" and "B" even after the pack is topped
    out. When the car is stopped, the engine may randomly start and stop several
    times -- the theory is that the system is ridding itself of excess battery
    charge to get it back within safe limits. You only really get 600 watt-hours
    full range to play with, which isn't a whole lot. Still, the car really
    goes out of its way to make sure there's plenty of stopping-power reserve
    on tap if the driver needs it. And there's no question that larger battery
    packs would give a much wider range of energy-recovery -- possibly enough
    to hold an entire mountain descent's worth. Some of the extra-battery
    experimenters have successfully done that, in fact.
    It is said that the early Japanese "hypermilers" used B mode to gain fuel
    efficiency. There is no advantage to be achieved by this with the current
    generation of Prius, but in the earliest Japanese models and the "Classic"
    imported to the US for 2000-2003 the regenerative braking system is a bit
    more crude and brings in the physical brakes much earlier in the game even
    when they're not necessarily needed. With higher-power-capable motors and
    the reworked "by wire" brake system in the '04 and since, this is no longer
    relevant since little or no pressure is sent to the wheel brakes until the
    system has extracted as much regeneration as possible. However, those early
    and somewhat vague stories could be another source of myth and misinformation.
    Help clear up some of the confusion about B mode. Tell other owners [and
    dealers!] who don't necessarily read this stuff why "B" is NOT saving
    them any gas.
    Any clearer now?
    Thank You to
    techno-fandom.org/~hobbit for putting it out there!
    [/SIZE]
  3. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    To summarize, 'B' mode increases the resistance to motion experienced when you lift off the power pedal. It's like changing down to a low gear on a manual transmission. It does it in a variety of different ways depending on the battery's state of charge, but doesn't use the friction brakes.
    However, 'B' mode is largely no different from just applying the brake pedal gently, as the car will use as much regeneration capability as possible. The difference is that when the battery cannot hold any more charge, applying the brake pedal uses the friction brakes; 'B' mode uses the engine as an air pump to resist motion ('engine braking').
    I've found that B mode is really only useful on very steep downhill gradients.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    .. so.. in english.. if you have a hill that your battery fills up on.. and you're smelling brakes.. Use B.. i coast down hills till the battery is full.. then ingage B so i don't gain more speed... (being sure to go back to D when i get near level ground again... so my battery stays full.. otherwise B will drain the battery due to forceful engine rotation by the electric motors)
    once the battery is full, you kinda end up in a neutral state.. so B keeps you below 45 on steep grades...
  5. harrybet
    Kamuela,Hi.
    Thanks Much Sportsfans! Got better info from you guys than Toyota.
  6. patsparks
    10,664
    569
    Adelaide South Australia
    I use B on one hill some days. If the battery icon on the energy screen goes all green and I'm more than half a kilometre from the bottom I select B mode.
    Another interesting fact, when in B the engine spins, if you apply the brakes in B mode when the battery is full the engine spins even faster. It can get quite loud actually. When the battery is full the system dumps energy through the engine even when not in B mode, when in B mode the energy dump still happens making the engine spin even quicker.
  7. Winston
    Winston Member
    614
    SF Bay Area, California
    If you go down a long down grade in the D mode, your battery may overheat. If you use B mode, your battery will be less likely to overheat.
    Oh, and your brake pads will last longer than the car. They are hardly ever used.
