Bluetooth vs music streaming Bluetooth
Discussion in 'Gen 3 Prius Main Forum' started by damack1, May 17, 2009.
  1. damack1
    damack1 Member
    123
    25
    Huntsville, Alabama
    I know there's been a lot posted about the Bluetooth feature, but I didn't find this observation called out. My local dealership just notified me that they will be receiving what is apparently a trim level III with no added options and wanted to know if I was interested. I had been hoping for a level IV with Nav, but I decided to think about the III. As I was comparing the stereo units, I noticed that the III has "Hands-free phone capability via Bluetooth..." and the stereo in the Nav package has "hands free phone AND MUSIC STREAMING via Bluetooth."
    Since the level III base stereo apparently does not have music streaming, and it also does not have the aux jack, there will be no way to connect my iPod whatever, at least not until September when the connection kits are available.
    Am I reading this correctly? That would be very disappointing.
    Thanks.
  2. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    And while you folks are reading this how about a quick explaination of what exactly "streaming bluetooth" will do for me. I am iPod"less" at the moment but would consider one soon. I think I may know what it does but I'd be guessing as to how it actually works. Also how does the streaming bluetooth compare with the USB connectivity being offered in the fall. I will have the NAV system and am curious what advantages the USB would have (other than plugging in a memory key).
    Thanks!
  3. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Streaming bluetooth allows you to stream music from your bluetooth device, like a mobile phone or an iPod. So instead of using wires to connect your device for playing music, you can do it over a bluetooth wireless connection.
    That is it.
  4. damack1
    damack1 Member
    123
    25
    Huntsville, Alabama
    wvgasguy, my main motivation is to be able to load audiobooks on my ipod touch and play them on trips in my car. This really helps pass the time. I have a trip coming up in July, so I'm hoping to be all situated with a new car with ipod connectivity by then.
    There are several options for being able to do this, each with pros and cons. Bluetooth with music streaming would be nice because it allows you to control your ipod wirelessly from the steering wheel controls. (My ipod touch does not support Bluetooth, so I would have to buy an inexpensive adapter for it.)
    The ipod kit also allows you to control your ipod from the steering wheel, and would simultaneously charge the ipod. Unfortunately, it isn't available yet.
    Even the aux input jack would be okay. It doesn't allow controlling the ipod from the steering wheel or head unit, but at least I could listen to my audiobooks through the stereo.
    I've tried several FM transmitters, and they've all been abysmal failures. Maybe they work okay if you're staying in the same general area, but on a road trip it seems like you never get to stay tuned to the same frequency for more than an hour or so before you have to change channels again to avoid local channel interference.
    As for the USB connectivity, I'm not really sure either how that works with the ipod. Maybe someone here can enlighten us.
  5. accordingly
    accordingly Member
    268
    63
    Madison, WI
    Both Pruis 2 and Prius 3 have the auxillary jack. All of them will. This is a standard option on almost any new car.
    Basically, what it is is a jack that you can plug in your iPod or any other player in existence, as long as you have a $5 cord from radio shack. The cord goes from where your headphones would plug in on the player to the jack in the car. You can then hear the output on your car speakers.
    With the normal jack, you control the song selection and everything else from the player, just like you were listening with headphones.
    With Bluetooth audio streaming, IF your player has bluetooth audio (iPods and most mp3 devices do not, some phones do) you can stream the music directly to the radio over the bluetooth frequencies. This saves you the "huge hassle" of having a cord. You still control the player in your hands like you have headphones on. You can buy an adapter for your iPod or player to stream bluetooth, I think they are $25-50ish. I'm not sure when or even if bluetooth will become a standard feature for mp3 players, but for now it's pretty much only phones. They will never take the headphone jack out of mp3 players, so the auxillary jack is as future proof as you need unless you like the tech. You can buy a FM transmitter in the same price range that does the same exact thing and will work on any radio in the world bluetooth or not, though the quality is usually not as good. Then again, nothing is going to beat the wire in terms of quality, and most bluetooth wireless headphones are criticized for poor sound.
    With USB or iPod integration, this gets exciting. Now you can plug your iPod into the car and be able to control the folder search and settings right on your navigation screen or radio. (actually, in my experience, user controls on the iPod decice are known are the best in the world for a reason, the aftermarket attempts are always clumsier, especially without a large screen) Normal mp3 players will not work this way, only iPod.
    Even more exciting is you can plug a USB flash drive full of mp3s directly into the radio and see the directory structure on the Navigation screen and choose a song that way. If you have a newer TV you may be able to do this in the same manner with pictures or movies. I'm not sure if the Prius will handle video files and I doubt it but it would be very very simple and can probably be hacked by updating the firmware (assuming someone will write it). I know the prius handles mp3 and other compressed audio files on a CD in all models.
    edit: I did forget to mention that Bluetooth and USB/iPod audio will allow you to control the player from the steering wheel controls, which is nice, but again these things are usually not as easy to deal with as the user interface on the actual player. You may just get used to the new system for skipping songs or albums in your car, or it may be a pain in the neck.
  6. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The aux input is standard on all U.S. Prius, according to everything I've read.
    Regarding USB & iPod connectivity, here's a quote from Doug Coleman from another thread:
    Just to be clear, the accessory iPod adapter will only be available on Prius II (base audio system). The September USB/iPod adapter will only be on Navigation systems. The non-Navi JBL audio will not have a USB/iPod adapter.
    Doug Coleman
    Prius Product Manager
    Toyota Motor Sales, USA
  7. damack1
    damack1 Member
    123
    25
    Huntsville, Alabama
    I had to go check another source to confirm that information, and you are right. The standard equipment list I had been looking at only showed the aux jack as part of the standard equipment on the Prius II stereo system. The latest information shows aux jack on a separate line, and is included in all trim levels.
    So thanks for clearing that up for me. Now I'm happy.
  8. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    One more option. If your audio books are in mp3 format, you can burn them to a cd and play them in the cd player. I believe it will play wma files as well.
    Roy
