88 Octane for 2010 Prius - What's up with that?
Discussion in 'Gen 3 Prius Main Forum' started by psu77, May 19, 2009.
  1. psu77
    psu77 New Member
    29
    Jacksonville FL
    It is being reported that 88 Octane or Research Octane Number 92 is required. I don't think the 88 is a misprint because normally the Research Octane Number is 91. So they purposely are using a higher number. Can the Toyota team please explain?
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    There is a confirmed discrepency between the owner's manual and the technical documentation. I'm going to believe the Technical documentation unless Toyota specifically says otherwise.
    I've burned 87 octane in cars that "required" premium - the consequence was retarded ignition timing w/ less power. In the Prius, the consequence of higher octane is sometimes lower MPG (or higher cost per mile).
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    So... the owner's manual said to use 88 Octane?
  5. hschuck
    hschuck Member
    385
    bay city, ca
  6. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
  7. richard schumacher
    7,664
    1,045
    United States
    Toyota should hire whomever writes the owner's manuals for Honda. They are marvels of clarity and detail (and presumably correctness?).
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    The one I have from TIS says 88 octane. I saw it the day it came out but I didn't even make a big deal about it because I'm running 87, plain and simple.
  10. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Prius 2010 III with navigation.
    My first tank from the dealer on 051709 was regular unleaded. So far I am averaging for the last 250 miles somewhere around 55 MPG , by computer guage) or so. Plenty of power in "Power Mode".
    Alfon
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I was wondering if there was a typo during the translation. That's why I wanted to know what Octane it said in the Japanese user manual.
  12. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Maybe Ken can help us out and tell us what it says in the Japanese manual. I hope ours is supposed to say 87 but either way, 87 it's gonna be in my tank :)
  13. mingjhwang
    mingjhwang New Member
    New Jersey
    "unlead regular gasoline" is what it says. Now what's the Octane of "unlead regular gasoline" in Japan. Any one? :)
  14. AirKuhl
    AirKuhl New Member
    63
    Santa Cruz, CA
    Just be aware that technically you are voiding your warranty if you use fuel below the minimum requirement. They could refuse to repair any engine related issues, and yes, I've seen where the dealer took a gas sample from the tank to verify the appropriate fuel was used.
    My guess is that 88 octane is a common fuel choice somewhere outside the US and this was simply transposed into the US manual. I'm guessing 87 octane will be fine but it doesn't hurt to verify this with your dealer and keep some record of the conversation.
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    are you guys seriously questioning this?... any Real prius owner would know they run off the lowest octane. (it's been comfirmed before.. it was asked because of the engine growing in size)
    newbs...
    i would say :focus: but there really isn't one....
  16. psu77
    psu77 New Member
    29
    Jacksonville FL
    No it was asked because it is in the owners manual. Previously the owners manual said 87 Octane. Aren't you suppose to follow the owners manual or you could be denied a warranty claim.
    Concerning Octane outside the U.S., isn't that the Research Octane requirement of 92 (previous model was 91 Research Octane)
  17. Steve Cebu
    Steve Cebu New Member
    523
    59
    Concord, NH
    I think the botom line is that Toyota needs to step forward and give a direct answer on this issue. I am very surprised that they haven't done so yet.
    So come on Toyota, let us know the real deal. Is it 87 or 88 octane that is required?
  18. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Not to say a company wouldn't try something like that but I'd like to see that tried with all the 2010 owners who we know are going to use 87 in the USA... Let's see what happens.
  19. sluday
    sluday New Member
    251
    Jersey Shore
    Regular fuel will be fine. I would not recommend diesel or low lead 100.
  20. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Why doesn't one of the new 2010 owners call Toyota Customer Care about this? Or at least ask the dealer that they bought the car from to check on this, for starters.
