Cost of Maintenance
Discussion in 'Gen 3 Prius Main Forum' started by jbelectron, May 20, 2009.
  1. jbelectron
    jbelectron Junior Member
    25
    Central Oregon
    2010 Prius -Cost of Maintenance
    another Newbie here:)
    We are considering the purchase of a 2010 Prius. We have talked to several dealers about the costs of maintenance and most have said that because of the quality of components in the Prius, the maintenance costs are usually less that other cars on the market.
    Yesterday when talking to an auto broker from one of the major car rental companies. He explaind that in most vehicles, the car has a computer and something like 23 sensors that monitor engine components, etc. Because of the technological features in the Prius, he said the Prius has 7 of these computers and 173 sensors.
    He said this can become an issue down the road when you have (say) 100,000+ miles on the car and anytime one of these 173 sensors sends a signal to one of the car's computers, your warning indicator will come on required you to take the car to the dealer to have them figure out the problem. He also said, for example, that the cost to replace a transmission in the Prius is something like $12,000. Is this information accurate?
    This is an important purchase for us, and I love the technological features of the Prius, but we want to make sure that the Prius's cost advantages will continue many years down the road.
    Thanks,
    Jim
  2. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Hello Jim:
    There are many Priuses that have well over 200,000 miles on them, some in taxi fleets that have over 300,000. Those that use them as taxis say that the cost of maintenance is much lower than coventional cars.
    However, it is true that the cost of major repairs can get quite high. Thankfully, that doesn't happen often.
    There are many threads already here on the PC forums that address this issue. You can use the Search function to discover them. You can also use "Advanced Search" to only search for keywords in thread titles rather than the entire contents of posts. Often this will provide more meaningful results.
    Best wishes, and welcome! :welcome:
  3. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Crock of beans. Low maintenance cost and high resale are hallmarks of the Prius. Prius doesn't have a transmission in the traditional sense, but a planetary gear set, more akin to the rear end of a truck (granted, more complex). I've not heard of anyone replacing a Prius HSD, so that "cost" is not relevant.
  4. ceric
    ceric New Member
    1,114
    Fremont, CA
    Jim,
    Tell your broker to show you a picture of Prius transmission, the one that costs $12,000.
    He won't because it does not exist.
    While there are some parts on Prius that are not commonly found on other vehicles (battery, invertor, etc.), which makes them more expensive than others, Prius has very good reliability record than most if not all vehicles. Check ConsumerReport for a more objective data.
    Yes, it is amazing on Toyota's engineering. Prius is sophisticated, and yet, Toyota made them very reliable. Mine has 0 problem after four years of ownership. The way you expect it from Honda/Toyota.
  5. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I agree, sounds like the broker is parroting 'information' gathered from who knows where. Ask him how long the traction battery will last and see if he says 'they have to be replaced every 5 years and cost $8K'. If he does, discount EVERYTHING he 'knows' about the Prius.
    My '04 had 2 recalls. 1 was related to a part used in 3 or 4 Toyota models that COULD fail though none had ever failed 'in the field'. The other I *think* did nothing more than recalibrate the 'guess gauge' to tell me I need gas when I have used just over 9 gallons (i.e. almost 3 left) instead of after 10+ gallons. The 'presumption' was that the cause of some people's problems were due to running out of gas (which I guess pops up all sorts of warning lights and signs) because they drove too far after the 'add fuel' light came on.
    91+K miles, 4.6 years, same brake pads, only oil, filter and wiper refill changes. Did have them check and clean the brakes once just to make sure everything was fine. Don't use the brakes much in a Prius unless you do a lot of stop and go driving. The pads don't touch the rotors/drums until you get down to 8 MPH or hit them hard rather than slowing to a stop.
    A note for newbies - the cabin air filter is EASY TO CHANGE yourself, can be washed gently in Woolite, air dried and reused (at least a few times) and my dealer charges 15 minutes labor to change it (plus the part). Do it your self, it takes 3 minutes and requires NO tools! :) And you'll do it a lot more often if it costs you NOTHING instead of paying $20 for the part and another $20 for installation.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I've spent < $500 in "major" repairs between a combined 170,000 miles of the two cars when an inverter coolant pump died at 101,000 miles.
  7. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    This excites me greatly! I have a '98 Saab (aka "Saab Story") and on average I spend $400/yr on stuff needing fixed. I can't really count things like the battery, tires and normal wear 'n tear items, but that adds up too!
  8. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    I went to a Toyota dealer a couple Saturdays ago to get a 2010 Prius brochure and talk to the dealer. I told them I drive 130 highway miles a day to and from work and will drive 350,000 miles in the next 10 years before I retire. I asked whether a 2010 Prius or Corolla would serve me better (value wise).
    The response was that the Corolla would have much less maintenance cost than the more complicated Prius. They wanted to steer me towards the Corolla. They said you have to drive a lot of miles to pay for the difference between the 2 cars. They also provide a free lifetime warranty thru an outside company for the powertrain. You need to bring it back to the selling sealer for covered warranty repairs. This does not cover the electronics of either vehicle, just mechanical on the powertrain (and not rings or valves.)
  9. dbacksfan
    dbacksfan Member
    258
    22
    Scottsdale, Arizona
    2014 Prius v wagon
  10. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    I have 115,000 miles on my 2005. I keep track of every dime spent for everything, replacement bulbs, wipers, etc.
    Here is the summary ( details upon request )
    Oil and Filters......................... $ZERO (??) Everybody who buys a vehicle at our store gets O&F Free for Life. I eat them alive on this with 8 free changes per year.
    Air Filters every 30K.................. $60 ( 3 x $20 )
    Inverter Coolant @ 105,000 mi.... $81
    That's it except for 'rubber' ( tires and wipers ) and misc repairs from road hazards
    Rubber.....
    Tire Rotation/Balance.............. $242
    2 sets of replacement tires....... $883
    Wheel Alignment..................... $119
    Wipers 3 sets.......................... $21
    2 patched tires........................ $61
    Misc....
    1 rear taillight replacement bulb.. $0.05
    Front fascia from pail in the road $73
    4 people like this.
  11. DeadPhish
    2,010
    353
    Yes they wanted to sell you a Corolla. But both are good choices however with the miles you drive ( same as mine ) you will come out way ahead with the Prius if you're planning to drive 300,000+ miles in it. They both have very low maintenance costs but the Prius is just a little lower ( brakes every 200,000 miles or so ).
    Since you're going to keep it for a good long time ask yourself this question. What do you think the price of fuel will be in the year 2019?? Do you really think it will be $2.00 per gallon? If it's $7.00 per gallon then which vehicle do you want to be driving?
  12. Berzerkeley
    Berzerkeley New Member
    berkeley
    Sometime Wednesday morning, CNN had a piece on how hybrid cars are more reliable and easier to maintain than gas this week.
  13. SureValla
    SureValla Member
    590
    Shelton, CT
    I have ~52,500 miles on my 07. I have spent ~1800 in maintenance and repairs and new tires.
    that comes down to ~4 cents/mile
  14. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    I would send a complaint to Toyota informing them of what that dealer did. The guy needs a call from Toyota HQ... what a jerk!
    We once had some dealers here pushing potential Prius buyers to buy the Avensis instead. It was as simple as letting their bosses know what they were doing. It ended fast as hell.
    Believe me, the Prius is a far better choice than a Corolla, by any measurement.
