Floor Jack
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Woody, May 6, 2005.
  1. Woody
    Woody New Member
    Can anyone recommend a floor jack for the Prius? Is a low profile Jack needed? Also, where under the car should the Jack be placed when Jacking either front or back?
    Thanks
  2. naterprius
    naterprius Senior Member
    1,843
    I own a Sears Craftsman Aluminum floor jack. It's pricey, but it's lightweight enough to hang on the wall. A similar jack is for sale at Costco and Sam's for a lot less.
    Jacking points are mentioned in the owner's manual. Don't forget your jack stands! Jacks are lifting devices, not holding devices! Jack stands are very cheap, so buy them, and use them.
    Nate
  3. dbird29
    dbird29 Junior Member
    Where are the best jack points and jack stand points on the Prius?
    Anybody got a diagram?
  4. bobc
    bobc New Member
    361
    Durham, NH
  5. Prius Maximus
    Prius Maximus Senior Member
    955
    809
    Northeastern IL
    The jack must have a lifting range starting at less than 6 inches. I have this jack from Sears Craftsman that has 5 3/4 inch to 20 inch lift range:
    http://www.sears.com/sr/javasr/product.do?...pid=00950148000
    It is on sale during May for $100.00 and comes with 2 stands.
    I put this jack under the frame even with the center of gravity, and can lift the entire side all at once. Saves a lot of time doing tire rotations.
  6. popsrcr
    popsrcr New Member
    232
    Richmond, VA
    FWIW, you can also just drive the car up on some wood. That gives you the clearence you need. (assuming you aren't buying a jack, if you are, might as well get a low profile one)
