How Powerful and Effective is the 2010 Air Conditioning?
Discussion in 'Gen 3 Prius Main Forum' started by web1b, May 24, 2009.
  1. web1b
    web1b Active Member
    817
    52
    Maybe with pre-cooling the interior with the solar roof fans and remote a/c, it can get by with a less powerful a/c system, but that leaves out the people who don't buy the heavily loaded models.
    Since it's only May, maybe not many people have had a chance to test the performance in truly hot temps, but how does it seem so far?
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Heating/Cooling capacity on paper for the 2001-2003:
    Heating: 5300W
    A/C: 4200W
    Cooling capacity on paper for 2004-2009:
    Heating: 5300W
    A/C: 4500W
    Cooling capacity on paper for the 2010:
    Heater: 5200W
    Cooling: 4920W
    So over the generations, cooling has improved, however it would seem we lost 100W of overall capacity for heating.
  3. NoMoShocks
    1,292
    82
    Camas, WA
    I have seen no difference in cooling ability. It will freeze your nuts off if you so desire. But then, it is only May.
    The solar roof works well, althought due to radiated heat off of surfaces, not as cool as outside air. Very effective when used with sun shade in windshield and leaving windows cracked ever so slightly.
  4. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
  5. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    I just purchased a 2009 model and love the air-conditioner. Especially in comparison to the VW Passat I got rid of. I did not realize the heat was also electric. :)
  6. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Wouldn't the exhaust heat recovery system lend a hand here? I thought that system was going to be able to recover about one-third of the otherwise-lost energy going out the tailpipe.
  7. HTMLSpinnr
    5,341
    920
    251
    I think the heating capacity is more of a function of the hottest coolant passing through the heat exchanger/radiator while the blower operates at the max speed allowed.
  8. a priori
    3,083
    408
    Chicagoland (West)
    So . . .
    Does this mean that we've lost some blower capacity, but because the exhaust heat recovery system is in place we'll get heat sooner (just not as forcefully)?
  9. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
  10. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I love the comments about how it will "freeze your nuts off", from people in cool climates. The green house affect of the acre of glass in the southwestern states tells a different story. :)
  11. Martin37
    Martin37 New Member
    200
    Joseph, Oregon
    Your assumption that "heavily loaded models", (in other words those who spend the big bucks), somehow get a different AC system than those who say get a model II, is incorrect, I believe. All models have the same AC system as I understaand it. Now the yet to be released model I may be a different story.
  12. Martin37
    Martin37 New Member
    200
    Joseph, Oregon
  13. dbacksfan
    dbacksfan Member
    258
    22
    Scottsdale, Arizona
    2014 Prius v wagon
    On the day I picked up my P III, outside temp was 102*. I had climate control set to 77 with fan one of the middle-to-higher speeds. I turned the fan speed down a notch or two as it was too cold.
    Now it may get a bit uncomforable for riders in the back seat if the sun is directly shining on them. There are no rear seat vents to get AC directly to the rear seats. Next on my list is window tint to help with that situation.
  14. Runabout
    Runabout Junior Member
    The air conditioner on my P II has worked very well for me. I have had the car for over a week in 95-100+ degree Texas weather and have enjoyed how quickly the car cools down, especially for the first few days when I could not roll down the windows because of the tinting install.
  15. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    Have only had one 90 degree day so far but the ac worked great on my III.
