Autoblog/Edmunds First Drives the 2010 Lexus HS250h
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by 1SMUGLEX, May 26, 2009.
  1. 1SMUGLEX
    1SMUGLEX I love the smug!
    315
    51
    Atlanta
    Full Article
    * A Pre-Collision System that you get when you check the Dynamic Radar Cruise Control option. If your HS thinks you're going to hit someone, it will ring the warning bells and add brake pressure if it doesn't detect you're pressing the brake hard enough. The driver monitor will also be working to make sure you're still at work behind the wheel. If you do happen to have a boo-boo, you'll be protected by ten airbags.
    * A heads-up-display that projects not only speed, but nearly any input you give the car, including audio system commands and navigation instructions. The steering wheel buttons are touch sensitive, so that when you rest your finger on one, it appears dimly in the HUD display, and is illuminated if you actually press it. You also get Pre-Collision and Dynamic Radar Cruise Control warnings shown to you in the HUD.
    * The wide-view front monitor is the same feature you get on a Rolls-Royce Phantom. If, for some reason, you can't see what you're about to nudge the HS's four-foot nose into, turn on the front monitor and you'll get a 190-degree view from the grille-mounted camera.
    * An infrared-cut, acoustic glass windshield that reduces IR waves by 30%, and side glass with a water-repellent coating for better wet weather visibility and defrosting.
    * Intelligent high-beams use a camera in front of the rear view mirror and automatically switch between high and low headlight levels. They can also shorten the distance of the beam depending on whether traffic is approaching you or you are pulling up behind someone.
    * Lane Keep Assist helps you stay in your lane in two ways. When the lane departure warning system can clearly make out lane markings, the steering wheel will vibrate and if you stray, the car will apply an ever-so-subtle amount of steering input to get you back in the lane. The second feature is essentially the car keeping itself in the center of the lane. Once the HS 250 knows where the lane markers are, it will gently provide steering inputs on its own to keep the car going right down the middle. Not that you would – but you can take your hands off the wheel and watch the car keep itself between the lines. Of course, this feature doesn't work on switchbacks, and it's not an auto pilot, but it does appear to be the way things are going these days. * Casual voice command capability (as on the IS convertible) that let you blurt out "Make it cooler" and "I need a gas station" instead of dictating your way in clipped tones through menus.
  2. 1SMUGLEX
    315
    51
    Atlanta
  3. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    But it can read your mind! -
    "An additional camera mounted in the instrument cluster is aimed at the nut behind the wheel. This driver monitor system uses facial pattern recognition and other signals to determine if you're paying attention and feeds this into the pre-collision system."
  4. 1SMUGLEX
    315
    51
    Atlanta
    2010 Lexus HS 250h first drive - [Lexus dedicated hybrid] - MotorAuthority - Car news, reviews, spy shots
    First Drive: 2010 Lexus HS 250h [Review]
    05/26/2009, 2:26 PM
    By Mark Elias
    Despite hot sales since its luxury-laden arrival nearly 20 years ago, Toyota’s premium division, Lexus, isn’t content to rest on its laurels. Having really only dabbled in more performance-oriented hybrids, the brand has decided to capitalize on its parent company’s successful Prius by offering an eco-minded hybrid of its own: The HS 250h.
    The HS 250h is actually Lexus’ fifth foray into the world of fusing gasoline and electricity; the LS 600h, GS 450h and two generations of hybrid RXs have been met with varying degrees of sales success.
    To experience the HS 250h, we’ll zoom back to Orange County, where we recently traveled for the introduction of the Lexus IS-C convertible. This we drive through the neighborhoods of bazillion-dollar homes where even the housekeepers drive luxury cars. Jay Leno’s new crib is up on the hill, almost complete in time for his “promotion” to prime time.
    A segment of one
    The HS 250h is unique for the brand, as it stands alone in its field. To this point, it is the only compact luxury hybrid vehicle in the marketplace. Size-wise, it slots in against the Toyota Corolla - slightly larger than the Prius and Honda Insight. Although these others are hybrids, they hardly reek of anything approaching luxury despite their popularity among those with dough.
    As Lexus rightly claims, the HS stands alone in a segment of one.
    The HS 250h features an exterior design that seems to draw from several sources, including those outside the company. Starting with the strong look of the tri-bar grille that resembles that seen on the Ford Fusion, it is flanked by two sharp accented headlamps that do lend a bit of style to this all-new platform. The D-pillar features a shape in the rear-door windows that recalls the line seen in the HS’s corporate sibling, the IS sedan.
    Slipstreaming
    Aero tricks built into the body, from the subtle lip spoiler in front, and the flared front fenders that cause airflow to run past the front wheel wells, to the aerodynamic tail lamps and rear decklid spoiler have enabled the HS to cheat wind to the tune of 0.27 Cd. The A-pillars have been smoothed as well to assist in this effort. Seeing that the name of the game here is fuel economy, these all contribute toward that end.
    Power for the HS comes from Lexus’s first four-cylinder gas/hybrid system. The gas side of the equation is an Atkinson-cycle 2.4 liter that contributes 147-horsepower and 138 lb-ft. of torque. The electric motor adds 140-horsepower, but don’t go adding A+B to get the sum of C. Power computation with hybrids doesn’t quite work that way, but according to the propellerheads at Lexus, the combined Lexus Hybrid Drive system manages to crank out 187-horsepower. That’s not hot-rod territory by any stretch, but for a fuel-sipper weighing 3682 pounds with batteries, it’s not totally out of the realm. Additionally, the system incorporates an exhaust heat recovery system to help reduce warm-up times and to allow the engine to shut off sooner. The net result is more efficiency overall, and improved operation in colder climates.
    Or, by the numbers, 35 mpg in the city and 34 on the highway for a combined average of 33 miles per gallon. It pales against the Prius and Insight, but the city number blows away any other compact luxury sedan in the North American market, including the diesel BMW 335d, which is rated at 23 mpg around town and 33 mpg on the highway.
    As is typical with other Toyota and Lexus-branded hybrids, the HS 250h uses two electric motors. Motor Generator 1 is the engine starter, generator, and transmission ratio control. Motor Generator 2 operates the front wheels, and helps for energy regeneration during braking. The batteries that MG2 regenerates to are located under the rear seat of the interior.
    Several modes of operation exist on the HS. An information gauge in the binnacle displays efficiency guidance to drivers for the various driving modes they may select. Normal mode operates the car as you may expect a typical hybrid to, while ECO mode remaps throttle response and air conditioning for more fuel-efficient starts from stop. EV Mode is the “sneak home” mode that runs on electric only for a limited distance; typically a couple of miles, and Power Mode runs with a bias towards the gas engine.
    Power to the wheels is by way of an electronic continuously variable transmission. We found it a capable cruiser on highways, and were surprised to find the characteristic escalating whine that normally comes from such gearboxes was absent, or heavily silenced by the quietness of the HS’s cabin. The ride was well modulated, and managed to send a moderate bit of road feel to driver in exchange for his input. The MacPherson struts with coil springs in front and double wishbones with trailing arms in back helped to give a typical Lexus ride quality to the HS 250h. Luxurious, yes, but not pillow soft. Mind you, this is no BMW 3-series or Mercedes C-Class.
    On local California toll roads, the car did not get squirrelly when encountering repaired expansion joints and road imperfections. An available sport-tuned suspension can be had with the Touring package.
    Although Lexus claims 0-60 is achieved in 8.4 seconds, expect to stand on the accelerator to merge onto fast-moving highways. In addition to its quiet interior, it is silent outside too, so much so that some sort of motor “noise” should be added for safety sake to remind you that the vehicle is running or to let a pedestrian know the car is about to move.
    The extras
    All the technology, in half the space. That’s what we found while going over the list of options available in the HS. They include Lane Departure Warning, which helps to steer the car back into the lane, while Lane Keep Assist alerts the driver to any deviations in direction. An available wide-view monitor displays a front side blind spot via the in-dash monitor, while the backup camera shows its view in the same place.
    Ecological insides
    Lexus boasts that the HS 250h’s interior is the first vehicle to use Ecological Plastic for its upholstery. Made from plants, using a photosynthesis process, it can be reclaimed through thermal recycling, which is near-carbon-neutral. It’s just a start, but it amounts to around 30 percent of the interior and luggage trim area.
    A new widescreen pop-up monitor occupies the top of the center stack, offering map views for the navigation system as well as audio and climate info. Twin system gauges occupy the driver’s gauge binnacle, and give an idea of power regeneration, consumption and modes as well as vehicle speeds and other information. Although we did not have a chance to experience it, a heads-up-display unit is available as an option.
    Seats are comfortable, though not really well bolstered for enthusiastic stints behind the wheel. But then, that’s not what the HS 250h is about. The rear seat was surprisingly roomy and can accommodate three passengers for a least a few around-town jaunts. A driver and passenger heating and ventilation package is available.
    First seen in the RX crossover, the “haptic” remote controller again makes its way into the line. Operated like a computer mouse, the controller works by touch with the goal of keeping both eyes on the road. Ditto for keeping fingerprints off the monitor. The shift-by-wire lever is a modern aged gear selector that has drive, reverse, and neutral on it; Place the car in park by pushing the park button.
    Finally, the HS 250h boasts of the largest trunk in the Lexus hybrid lineup. With repackaged battery systems and innovative suspension design, the cargo capacity can now accommodate up to four golf bags.
    Leftlane’s bottom line
    The new HS 250h is a first for Lexus as the smallest hybrid in their lineup. A capable performer that easily achieves their claimed mileage goals, it could probably go much further at the hands of a hypermiler. It shows off what is becoming the new face of the brand, and will be an important step for those craving “responsible luxury” without sacrificing ride quality and amenities.
    About as efficient as the diesel-fueled Audi A4 2.0 TDI or BMW 325d that don’t make the trip across the pond, the HS will no doubt appeal greatly to those who value the hybrid badge and the Lexus label above all else.
    Words and photos by Mark Elias.
    [​IMG] Print This Post
  5. Tideland Prius
    16,499
    holy crap, it has the Advanced PCS from the LS600h L?!?!?
  6. dawtips
    dawtips New Member
    I'm really excited for this car and will wait to see how it prices before choosing between this and a Prius.
  7. dawtips
    dawtips New Member
  8. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    and touch sensitive buttons shows on HUD
    and wide angle front monitor for T intersections.
    man I like that car
  9. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I do not know, I'm a gadget guy, heck I got the Prius V with AT... Although this car has added tech compared to the Prius its kinda tech I can live without considering its MPG numbers don't come close to impressing me like the Prius. Not to say I don't like the car, what's not to like, but for a gadget guy who still wants gadgets with gas mileage and what I'd consider top quality near luxury build the Prius still does it for me.
  10. spwolf
    3,156
    440
    Eastern Europe
    it is really completly different car from Prius... only reason people compare them is that both are Hybrids, otherwise as different as they could be.
    few years from now, every car will have hybrid versions so these silly comparisments will go away.
  11. Tideland Prius
    16,499
    And HDD Nav, Musicbox... yeah.
    But it looks like a Corolla. The Prius still looks cool.
