Tire Pressure; Should We Inflate to Higher PSIs as Air Temps Drop?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rokeby, May 31, 2009.
  1. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    While searching through the archives for information on tire pressure,
    I came across reference to this table:
    http://priuschat.com/forums/attachment.php?attachmentid=15137&stc=1&d=1243769222
    I'm not sure I understand what the recommendations are meant to
    achieve.
    The table seems to say that for consistent inflation at different air
    temps, you should be using higher pressure at lower air temps. If I'm
    reading it correctly, it uses 70 degF as the standard air temp. As an
    example, for 38 psi at 40 degF it recommends inflating to 41 psi.
    I know that tire pressure drops ~1 psi for each 10 deg drop in air
    temp. From that understanding, I expected to be adding air to my tires
    as the air temp drops... back up to the target pressure, I thought.
    What I did not anticipate is that as the air temp drops, the table says
    that I should be adding air to get a higher target air pressure.
    If tire pressure itself isn't constant with temperature, then the
    recommended air pressures are meant to achieve a condition such
    that the effect of the internal tire pressure is constant.
    What is the constant effect that the changing recommended tire
    pressures achieve?
    Does it have something to do with higher pressure = greater number
    of "air" molecules in the tire?
    Yes, I did read the article accompanying the table here:
    http://www.aa1car.com/library/tirepres.htm
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    The chart is consistant with the 1 PSI drop for -10F change. If your at 70F and you know your going somewhere the temp will be 40F, the chart recommends a higher pressure to compensate for the difference when you get to your destination. Or, just drive to your destination and adjust cold pressure after you get there, up to you.
    Wayne
  3. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Rokeby,
    Cold tire pressure means, before rolling the car down the road, in the ambient temperture, the tire pressure should be set to this.
    What this chart appears to be , is if your a service guy, and have the car in the shop at 70 F for several hours, but the outside air is like 0F, then you need to overpressure the 70 F tires so they will be right when the car goes back outside. Really nothing to do with most of us. Because we set tire pressures with the car outside, having sat outside for a long time.
  4. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    donee, Wayne,
    Thanks for your concise replays; it now seems obvious and simple. :)
    For reasons not now clear to me, I just couldn't get the simple message
    the table was meant to Illustrate... so much work, surely there was
    some subtle, heretofore undiscovered truth... Not! :p
  5. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Oops, ddoouubbllee ppoosstt.
  6. NoMoShocks
    1,292
    82
    Camas, WA
    Just don't forget to use Nitrogen for your tires. It is so much better than the ordinary 80 percent Nitrogen atmosphere.
