Defect or feature?
Discussion in 'Gen 3 Prius Main Forum' started by bwilson4web, May 31, 2009.
  1. bwilson4web
    16,123
    This afternoon at 3:30 PM, I started up our 2010 Prius in 90F weather. The neighbor's tree was just starting to cast its shadow but the radio didn't work. The LCD display showed 'heat stress' muddled patterns and no sound came from the box.
    I had errands to run and about 10 minutes later with the AC working, the radio came back. The display was still 'heat muddled' but at least the electronics were working. I parked in the shade to do my shopping and when I came out, the radio and LCD display were working perfectly.
    So the question is, what next?
    Do we treat this as a defect and return the car for correction?
    Now I can put some sort of sun screen over the radio area and hopefully minimize or reduce the heat stress. Southerners are also used to using a sun shield in the windshield and I'll put one in the car. Now I can easily instrument the area and verify that my fixes work. But that doesn't get the problem back to Toyota for a proper fix ... if it can be fixed.
    Thoughts? How should we address this 'feature' or 'defect'?
    ps. The 'feature' is no sound to distract you from having saved money by avoiding the window tinting.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I vote defect. Be interesting to know what the interior temp was.
  3. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    And it was only 90. Wait till it gets hot. :)
  4. Patrick Wong
    18,200
    6,499
    Hi Bob,
    Yes, I suggest you use a digital camera to take a good photo of the display when it has failed so that you can prove the existence of this intermittent problem.
  5. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    An old-fashioned thermometer parked on the dash would be helpful, too.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Very much a defect IMHO.
    BTW - why not post this stuff in the general forums?
  7. efusco
    19,891
    1,196
    Nixa, MO
    Moved to 2010 forum
  8. NoMoShocks
    1,292
    82
    Camas, WA
    Definately get it in for a check. According to Murphy's law, they will not be able to duplicate the problem, but you will have a record so that after the warrantee expires, and it starts doing this consistantly, you will be able to get it fixed under warrantee becuase the dealer has a record of you early complaint.
  9. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    In marketing, there are no defects, only features. This feature is to audibly and visually indicate you should be cautious because it's hot and you could be in danger. So this is a safety feature, not a defect :p
  10. qbee42
    3,079
    Defect. Get a photo.
  11. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Oh, like when the 'server' at a restaurant warns you the plate is hot! :)
    I have to agree, 'defect or feature', it shouldn't be happening. There isn't likely a warning in the owner's manual to not park in the sun because some of your electronics will fail.
