Need a bulb adapter...
Discussion in 'Environmental Discussion' started by Celtic Blue, May 3, 2009.
  1. NoMoShocks
    1,292
    82
    Camas, WA
    Now the only thing left to do is to remove the light beam sensor from the far side of the door and mount it on the same side as the beam source face to face on the same side of the door. They are a lot less troublsom that way. Or you can mont them face to face up on top of the opener for shorter cable run.
