Driver's Seat Remount at Home - 2 5/8" Back
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cycledrum, May 24, 2009.
  1. dogfriend
    7,512
    1,189
    Carmichael, CA
    Yes, I have my seat all the way back and it is perfect for legroom for me. I couldn't move further back because I'm already reaching for the steering wheel. I could use about an inch of telescope of the wheel toward me to make the reach more comfortable.
  2. Nortnarg
    Nortnarg Prius~To go before
    83
    Blue Springs, Missouri
    I am 6'5" and am considering a similar mod.
    Is there a chance of setting off the airbag in the seat when disconnecting and connecting the wiring to the seat?
    Do you disconnect the battery before doing this? If so, what needs to be reset after the battery disconnect?
  3. dogfriend
    7,512
    1,189
    Carmichael, CA
    Yes, you must disconnect the 12v battery before removing the seat. You should wait a few minutes before starting to work anywhere near the airbags.
    After reconnecting the battery, you have to reset the power window auto stop feature - see instructions below
  4. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Nortnarg,
    Also, when doing work on your seats, the Seat Assembly Instructions may be useful:
    http://jaygroh.dreamhost.com/prius/Prius%20Info/Official%20Toyota%20Info/Repair%20Information/Repair%20Manual/SE%20-%20Seat.pdf
    Also, besides Brett's work, you might want to check out nyprius' work:
    2 people like this.
  5. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Wait at least 90 seconds when disconnecting auxiliary battery before disconnecting leads under the seat, (I think there's a battery backup for seat airbag). I usually take a break to be sure.
    Reconnect battery at end of project. When powering up car, press 'power' button once, this will leave dash lights on, press it again and should be good to go.
    Consider whether you'd want to do it to your original seat or a used one.
    Feel free to PM me with questions also.
  6. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    thanks dogfriend. so that's what is going on.
    and thanks for the link Tom.
  7. Nortnarg
    83
    Thank you Boo, Dogfriend and Cycledrum.
    Great information and links. I am starting a file of my own to reference later. I am not ready to start my own mod yet, but one of these days I will!
    With help like this, How could I go wrong? :focus:
  8. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Follow up. Note - steering tilt not all way down in pics. Reach a little better with tilt full down.
    All the way back - equivalent to 4 extra clicks. Reach to dash and steering wheel too far.
    1 click forward - Reach a little far to steering wheel.
    2 clicks forward - Best balance of legroom, reach to steering wheel and angle for seatback.
    4 clicks forward or original position all way back. Eeeek. :eek::eek:
    Overall greatly improved. As good as the 2010 Prius? No way. I would do this mod again. Totally worth the time and money :)
  9. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    ** Edit - I don't use this cushion anymore and would not recommend it **
    Custom seat cushion.
  10. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    3-way attack for more comfort in the seat -
    * remounted back for legroom
    * Edit - I don't use this anymore >> custom seat cushion for thigh support
    * seat cover with bottom cut-off to protect seatback and get bit closer to steering wheel.
  11. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    edited 6/14
    Some follow up. Did a coastal mountain pass from Los Gatos to Scotts Valley. Using 3 clicks back from stock max position. The seat position / legroom is remarkably better than stock seat mounting. I've moved seatback 2 clicks forward and reach to steering wheel is really not bad at all.
    On the way home, stopped at Toyota, jumped in 2010 for comparison. The new Prius seating is better than mine. The telescopic steering wheel, height adjuster and better positioned brake pedal improve ergos a lot.
    In the 2010, it's like I'm more 'in the car or seat' whereas on the 2009 with my mod, I'm a more 'on the seat'.
    If I can pick up 24 more HP, I'll be set :)
  12. Boo
    5,051
    488
    97
    Flushing, NY
    Hi Brett,
    Curious, now that you've mounted your seat 2 5/8" further back, and have sat in the 2010 Prius, are you able to give a good seat of the pants estimate of how much further back the 2010 Prius goes than the stock Gen II Prius?
  13. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Yes. The 2010 driver's seat goes about 2 1/2" farther back than a stock Gen2 Prius seat. And, the 2010 seat / steering reach is effectively much better than a remounted Gen2 seat for a very tall person -
    * 2010 height adjuster allows more headroom, so can sit low and bring seatback forward for better reach to steering. Plus, you get 1.5" steering wheel telescope in the 2010.
    -- Also measured 41" maximum brake to back of seat bottom in 04 - 09 Prius. Little over 43.5" in 2010 with height adjust full down. 2.5" doesn't sound like much, but equates to about 4 extra clicks in a Gen2, something many would like to have.
    * In 2010, the gas and brake pedal sure seem to have more even reach to them. IOW, adjust for good reach to gas, move to brake and reach feels the same. Brake pedal is set closer than gas in Gen2.
    This seat remount is still a good mod and worth it. Hats off to the 2010 though. It is improved in many ways.
  14. Boo
    5,051
    488
    97
    Flushing, NY
    2.5 inches was my final estimate too after sitting in the 2010 for the third time.
    I knew that there was no way that the 2010 only went 1" further back than the Gen II (a measurement that was posted once in this forum).
    Enjoy your 2009. It's a great car. And being the last model year of the Gen II, it just might be the most reliable car made.
    The 2010 has improvements for sure. But even those improvements plus the very generous Prius Priority Pre-Order discount offered to me, were not enough for me to get the 2010 when I had a perfectly good 2007 with only 6500 miles on it.
  15. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    How cool, we've got the same results!
    I hear ya. No reason to strain for a 2010 which would just set me back. Better to save money.
    This is 'splitting hairs', but ...
    I used to recline my seatback too much before the modification just to gain some headroom. After the mod, I'm using 3 extra clicks back, so I picked up some headroom since the seat rails have some tilt.
  16. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    3 week follow up -
    The front extension braces are holding up fine even though they measure between 5/32 and 3/16" thickness (11/64" , forgot that guage # of steel).
    If I had it to do over, I might use 1/4" thick steel for the front braces. If they bent, I'd redo it all over if necessary.
  17. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    About the steering wheel ...
    I hold the wheel quite a bit at 6 o'clock, one hand, palm down, but go for another grip depending on traffic.
    I'll take the extra legroom with extra reach to the wheel 24/7/365 :cool:
  18. griffycprius
    griffycprius c11prius
    31
    Laguna Beach
    if you want an easy way to move your seat back... go to www.extendmyseat.com. We make custom brackets specifically for the GEN 2 prius. Install in less than 30 minutes and all you need is a socket wrench not an arch welder.
  19. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    It's looks like the brackets can easily be removed if someone wants to sell or trade-in their car, so that is a good thing.
    I can vouch that sliding a Gen2 Prius seat back 3+ clicks extra for a person with long legs is so much better than stock seating. And like you say, plan to move the seatback more upright to keep reach to steering wheel reasonable.
    Wish I'd seen your brackets a couple months ago. I looked all over before doing the mod.
  20. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    dupe post.
