Grey water gimmick? Or worth the $300?
Discussion in 'Environmental Discussion' started by burritos, May 31, 2009.
  1. burritos
    burritos Senior Member
    4,946
    253
  2. icarus
    icarus Senior Member
    4,884
    976
    earth
    A fine idea to save water..
    You could use a battery pump,, a 120vac pump,, or ideally a hand pump.
    Icarus
  3. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    To take a slightly different angle: Why is she still bathing a 6-year old? She says that is taking 30 gallons of water. With a 7 minute shower and a 1.5 gpm shower head she could cut that by 19.5 gallons/day, over 7,000 gallons/year. Even a 10 minute shower with a low flow head would cut that water usage in half.
    I agree with Icarus though, it would be easier to build your own for something like this. I would also probably want to run gray water through soil/sand/gravel column to filter out soaps and nasty bacteria before I put that water in a food producing garden. I wouldn't worry about it as much on the lawn...
  4. Celtic Blue
    2,224
    139
    Midwest
    Also, the link in the article itself is wrong, it should be H2ouse.org : Take Action (They had it listed as .com and they used a zero instead of an "o" which resulted in a dead link.)
