Poor Idle is driving me crazy!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vertex, Jun 7, 2009.
  1. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    I bought a totaled 2006 Silver Prius last summer. It was hit in the front drivers corner. Airbags did not deploy. Someone had removed parts before I got the car. Drivers fender, hood, radiator support, radiator, condenser, fan, TB, air intake, storage bottle, pump, & coolant valve were all replaced. Everything was new except the radiator and the TB. Some of the connectors on the transmission were broken, they were replaced. I repaired everything, and had the salvage inspection etc. I have not been able to pass the emissions inspection because of this problem. The car seems to drive fine, except under the conditions I describe below:
    The main symptom is that when the engine idles (that is not shut off, not driving wheels, and not charging the battery) the engine RPM hunts between 1700 & 2000 RPM when in park, and up to 4000 RPM when in drive. This occurs when the engine is in the ultra lean mode, O2 is 0.015 volts. Once the engine warms up to over 158 F, the P0101 DTC occurs. Otherwise no codes.
    I checked the MAF and it looks new (as it should, since it is). I checked for vacuum leaks, couldn't find any. Gasket under TB is new. I checked the 3 vacuum ports, and they all seem fine also.
    I had the idea that even though the MAF was new, maybe its output was high, causing the DTC. The voltage does go over 2.2 volts sometimes under these conditions. So, I tried to reduce the airflow through the sensor. The car ran better, much less surging etc. However, I would get a DTC for lean mixture. I tried to reduce the amount I blocked the flow, but I could not find a sweet spot between the points so that neither DTC occurs. The engine is racing when it shouldn't so mileage is under 30 MPG.
    I think that I am looking in the wrong place, but don't know what the right place is. I doubt that the MAF is bad, but maybe I should change it ($$), or the ECU ($$$$$$$). I have the Autoenginuity scantool with the Toyota package.
    Also, maybe someone has an idea how I can get it past inspection, so at least I can use the car while I try to figure this thing out!
    Thanks in advance for all your help!
  2. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Your situation sounds somewhat similar to this very perplexing vacuum
    leak problem that was discussed on one of the CleanMPG,com Forums
    Hope this helps.
    FWIW, this thread also discusses some incredibly strong user support by
    the SccanGauge folks.
  3. vertex
    672
    144
    new york
    2018 Prius Prime
    Interesting, I have to check where that is located. There was some minor damage behind the inverter where the brake cylinder is.
  4. vertex
    672
    144
    new york
    2018 Prius Prime
    I can't locate the hydro booster in the shop manual. It mentions it but does not show where it is. Anyone know which hose is the vacuum going to the booster and where the booster is?
  5. Patrick Wong
    18,200
    6,499
    The Prius braking system does not depend upon engine vacuum, so that should not cause your issue. The brake pressure accumulator pump is electrically powered.
    DTC P0101 does point to the mass air flow meter. A few thoughts for your consideration:
    1. Are you sure that the installed MAF is the correct part? The Toyota part number is 22204-22010. Any problems with the wiring harness connector?
    Further, the Toyota repair manual provides info about how to diagnose a failed MAF vs. engine ECU in the discussion about DTC P0100, P0102, and P0103. Although your car doesn't register those DTC you may find the troubleshooting procedure relevant to your situation.
    2. How about the O-ring, was that replaced with a new part when the MAF was replaced? The part number for that is 90099-14141. Are the two screws that attach the MAF secure?
    3. What about the metal clamp that secures the air cleaner housing to the throttle body. Is that secure? Any cracks in the air cleaner housing or the intake manifold downstream from the MAF?
    4. Have you attached a vacuum gauge to an engine vacuum port to see what vacuum is produced by the engine?
    5. Have you checked the voltages at the engine ECU to see if they are correct? The Toyota repair manual provides info about this, for example p. 05-370 of the 2005 repair manual explains how to verify voltages at the ECM. Voltage is provided via IG2 and EFI M relays.
  6. dogfriend
    7,512
    1,189
    Carmichael, CA
    I would check carefully for vacuum leaks. Your "idle" speed (no load in P) is a lot higher than what I see with the Scangauge - I usually see 1200 - 1400 rpm. The Prius does not have an IAC (idle air control), but if extra air is leaking in that is not metered by the MAF, that would explain your high "idle" speed.
  7. Patrick Wong
    18,200
    6,499
    As the throttle body came from a salvage vehicle, is it possible that the wrong part number was installed or that the TB is defective?
    I agree with Jason that you need to search very carefully for a vacuum leak. Since the original TB was damaged in the accident, is it possible that the intake manifold has a crack somewhere?
  8. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Patrick,
    Thank you for making this crystal clear. :rockon:
    In my post I was trying to suggest that the problem here might not be
    in the vacuum hoses and their connections, but rather a leak in some
    piece of equipment typically presumed to be airtight. :(
    All you guys are far more knowlegable in automotive engineering in general
    and Prius-specific trouble shooting than I am. Well, I'm here to learn. There
    seems to be a general consensus that the symptoms point towards a vacuum
    leak. As an aid to my education, can you help me/us understand more about
    this? :confused:
    In the OP, it is stated that there are three vacuum ports on the throttle
    body, TB. To what pieces of equipment do they lead? You've said it's
    not to the brake system. And while I've still got a lot to learn, I know
    it's not to the windshield wipers. :p
    Where then do they go? One to the PCV valve and...?
  9. Patrick Wong
    18,200
    6,499
    Hi Rokeby,
    If you open the hood you will see a decal that shows the engine vacuum system. Note that there's one hose that connects to the vacuum switching valve and a purge port. The latter provides vacuum back to the fuel tank HC emissions control. See
    Automotive Training and Resource Site
    Look for the Technical Article, Hybrid13 Fuel and EVAP System, page 3-5.
    Also, if you take a look, you will see a port that is covered by a rubber plug. This would be a good place to connect a vacuum gauge for testing (or your old-fashioned windshield wiper motor...:cool: )
    You are right in identifying the PCV hoses as another potential place for a vacuum leak, especially the hose connected below the throttle plate. Other common places for a vacuum leak include the oil filler cap (if the rubber O-ring has failed or the cap is not fully tightened) and the oil dipstick not being fully inserted or with a bad O-ring.
    If the OP cannot find the leak, then I suggest physically removing the intake manifold and carefully inspecting for a crack. Fill the manifold with water if necessary and see if any leaks out. Use all new gaskets when reinstalling.
  10. vertex
    672
    144
    new york
    2018 Prius Prime
    I checked both the PVC hose, and the other hose. The PVC valve seemed to work correctly, and the one going to the purge was OK up to the valve next to the engine.
    Maybe I can disconnect both, plug the ports, and see if the car idles OK. I expect other DTCs, but at least that would let me know if the leak was there.
    I got the TB from Autobytel. They only sell Prius parts, so it is probably not the wrong one. However, the TB position sensor was bad when I got it, and I had to replace it. I checked the replacement one, and it was OK. I bought a new air intake/filter assembly that comes with the MAF in it, so the part must be correct.
    I set it up for 14% reading on the position with the ICE off. I looked at the intake manifold, and did not see anything amiss, but it could be there or the gasket. The concensous seems to be Vacuum leak.
    I tried the propane trick, but didn't come up with anything. Even puting the propane into the aircleaner didn't have a noticable effect, so I'm not sure how well this works on the Prius.
    One thing I don't understand, is why is the RPM higher with a leak?
  11. dogfriend
    7,512
    1,189
    Carmichael, CA
    On most EFI engines, idle speed is controlled by regulating bypass air (air bypassing the closed throttle plate). This is usually a function of the IAC valve, which is operated by the Engine Control computer. So, if there is excess air leaking past the throttle plate that is not metered (or accounted for) it will raise the idle speed. My understanding is that for the Prius, the IAC function is integrated into the electronic throttle body. You mentioned that you replaced the TPS. Any chance that it could be misaligned with the throttle plate? How are those two indexed?
  12. vertex
    672
    144
    new york
    2018 Prius Prime
    The TPS is mounted with two screws and can be rotated to adjust the zero. It has a post that is keyed into the TB plate, so that its mounting cannot cause a leak, but is could be misadjusted. I played with the adjustment, just in case I had it wrong, but it didn't cause any change in operation, but it will cause a DTC if set too low.
  13. Patrick Wong
    18,200
    6,499
    When the engine is cold, what idle behavior does it demonstrate?
    Do you know how to put the Prius into inspection mode so that the engine runs continuously, allowing you to assess engine idle over a long period of time?
  14. vertex
    672
    144
    new york
    2018 Prius Prime
    Patrick:
    Same behavior when cold, no DTC. I have instruction on inspection mode, but did not succeed in getting it to work.
    Howard
  15. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    I hope all-you-all won't mind me asking a connected, but tangential
    question. I'm curious about the expected vacuum leak induced RPM
    increase... curious minds want to know :)
    As I understand what's been said, a vacuum leak, depending on its
    volume, leads to a small but measurable RPM increase. I'm
    guessing that the ICE is running just a little lean.
    In the thread that I cited earlier, they sprayed small amounts of carb
    cleaner on vacuum hose joints suspected of leaking. This method also
    apparently produces a noticeable change in RPMs. When I read it, I
    presumed it was an RPM increase.
    Now however, I suspect it would be a decrease as the when the
    flamable liquid is drawn in below the throttle body, the mixture is
    somewhat richer than before.
    Am I even close to understanding what is going on here?
  16. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    This is a head scratcher. In the past, I've found the propane method to *very* reliably find vacuum leaks
    Seems we've covered all the usual bases here. A cracked intake could very well cause these problems. Patrick and Jason have covered the relavent diagnostics, nothing I can add except some photos
  17. Patrick Wong
    18,200
    6,499
    Hi Howard,
    I started my 2004 (which was warm from having been driven ~100 miles or so earlier in the day) in inspection mode. Then I tried removing the oil dipstick. Very little change in rpm.
    Then I removed the oil filler cap. Engine rpm increased slightly. This illustrates that the idle speed control logic is able to compensate for a relatively large vacuum leak. Therefore I'm less confident now that a vacuum leak is causing your driveability problem.
    Have you had a chance to perform the recommended tests that are shown in the repair manual regarding DTC P0100, P0102 and P0103? This would validate that correct voltages are reaching the MAF.
    In particular, note that if the hand held tester thinks that the air flow rate is excessively high (which may be the case since you have DTC P0101), check the resistance between terminal EVG (E5-32) and body ground. If the resistance is above zero, then the engine ECU is at fault. See for example page 05-97 of the 2005 repair manual or the analogous page of the Toyota repair manual that you are referring to.
    The manual goes on to show how to check continuity of the wiring harness that connects the MAF to the engine ECU. Since your car was in an accident, that wiring harness damage is a reasonable possibility to consider.
  18. dogfriend
    7,512
    1,189
    Carmichael, CA
    What better way to get information about leaks than to get it from the experts: Ford owners :madgrin:
    help finding vacuum leak... - FFCobra.com - Factory Five Racing Discussion Forum
    I believe that the second poster in that thread is correct: the propane will raise the idle slightly when sucked into the intake because it is a source of additional fuel.
    Here is an article covering the different techniques, with the addition of the smoke method which may be the best way of all if you have the equipment:
    Tech To Tech
  19. vertex
    672
    144
    new york
    2018 Prius Prime
    I checked again tonight each vacuum fitting again by removing 1 at a time and blocking the port. No change. I carefully looked at the manifold, and see now sign of cracks. I checked it when I had the car apart months ago, and did not see anything. Short of taking it out, the only test that I can think of is the propane, which did not work last time I tried it.
    Is a vacuum leak the only possibility, or is there something else? I can try the propane approach one more time.
    Thanks again for the help!
    Howard
  20. vertex
    672
    144
    new york
    2018 Prius Prime
    I like that VacuTech machine. I will see if I can find a shop that has one.
