Help Diagnosing Unintended/Uncommanded Acceleration Issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nylion, May 2, 2009.
  1. phoebeisis
    phoebeisis Member
    139
    Jayman,
    The lawyers are always involved now. The poor folks manning the phone lines are given instructions to take info, but to never, never admit that there have been similar reports. They are bottom of food chain, but they can be the first to see a pattern developing. I wonder if the "phone people" are actually in one big room with 100's of work stations? If so they could compare notes or overhear other conversations?
    I wonder if there is a problem with the traction control system ABS interaction?
    Still, the throttle position being misread for some reason -something stuck-seems more likely(is there a strain gauge in there, or is it strictly position). Like Bob mentioned, the Prius II's have a cheezy plastic casting throttle "thing" (i just looked at it-doesn't inspire confidence) but the 2010's are metal. Makes you wonder why.
    Charlie
  2. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    RHD 2008 Prius pedal setup:
    Looks like the metal rod clips into a plastic plunger that operates the same sensor assembly.
    Coming from a 2001 Ford Focus, I found the brake pedal in the Prius incredibly wide. Of course, that car had a clutch.
  3. phoebeisis
    phoebeisis Member
    139
    Mike,
    Interesting- my 2006 Prius has a plastic "rod" not the metal rod yours has. I wonder why it was changed?
    Charlie
  4. qbee42
    3,080
    It has two hall effect sensors which monitor position.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I've already posted it, but here is the schematic again
    Here are possible accelerator pedal sensor DTC's
  6. phoebeisis
    phoebeisis Member
    139
    Strictly position-thanks.
    Charlie
  7. nylion
    nylion New Member
    167
    61
    Seattle WA
    There is a package 8 in 2006. It included leather and navi. We already cleared this up about 200 messages ago.
  8. nylion
    nylion New Member
    167
    61
    Seattle WA
    Thanks for all the hard work. I just did a quick search of the NTSA data base for speed related complaints. I only looked at 2006 and 2007 Prius. I found at least 15 (attached Excel spreadsheet). Based on this sample, there are probably over 100 for 2004-2009, the life of this generation.
    I can't help but wonder why no one outside of here is taking this seriously.
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    Probably because the problem is so rare and difficult to isolate. However, if a Prius owner with a few bucks happens to get killed due to unintended acceleration, and the spouse retains a lawyer who is straight from hell, I bet after the lawsuit they fix the problem
  10. nylion
    nylion New Member
    167
    61
    Seattle WA
    I don't want to be the dead husband!
  11. dogfriend
    7,512
    1,190
    Carmichael, CA
    FYI, you can always do an emergency shutdown of the hybrid system: push and hold the Power button for 3 full seconds - the hybrid system will shutdown - system main relay will disconnect the HV battery - transaxle will go into N - power mode will be ACC.
    Give it a try when there is no traffic so you will know what to expect. It will not hurt the car, you will still have brake function because of the emergency backup power supply.
    3 people like this.
  12. nylion
    nylion New Member
    167
    61
    Seattle WA
    I think I solved the problem for good. I just ordered a 2010 Series V advanced technology model. The opportunity was too good to pass up. Washington (state) passed a law in 2005 that said it would waive sales tax (9.5%!) for new vehicle sales if the vehicle gets 40mpg or bettter. This law was to be in effect from Jan 1 2009, to Dec 31, 2010. I had planned to buy a 2011 Prius in the fall of 2010 and take advantage of the tax break. When the economy tanked, Washington repealed the tax break though it had already started. The last day to purchase a car and still save the sales tax is July 31. Happily, my new car will be delivered July 25.
    It turns out that my prius (2006 series VIII [yes there was an 8 in 2006] with XM) has a trade-in value of more than $14,000. So, quickly doing the math, the 2010 V with advanced technology (and some other stuff) is around 33,000 USD. The trade-in pretty much cuts that in half and the sales tax saving of $3000 is just icing on the cake.
    Maybe the unintended acceleration was a sign. I sure hope it's fixed in the G3's.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    I hope Toyota reads these forums. The fact a 2006 owner has to trade as he no longer trusts his car, is an omen
  14. satwood
    satwood Member
    107
    Webster, MA, New England, USA
    2014 Prius v wagon
    Yes, or an unintended upside that helps Toyota sell more new cars. Note that he still bought another Prius. It's all upside for Toyota.:p
  15. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Yup. If the dealer doesn't sell it to someone else, it goes off to auction. The dealer never looses.
  16. mean-boy
    mean-boy New Member
    san francisco
    I was reading the manual for our 09 NAH and it's suppose to have a EDR or event data recorder. Does the Prius have this? Here's what the manual stated:
    The EDR in this
    vehicle is designed to record such data as:
    c How various systems in your vehicle were
    operating;
    c Whether or not the driver and passenger
    safety belts were buckled/fastened;
    c How far (if at all) the driver was depressing
    the accelerator and/or brake pedal; and,
    c How fast the vehicle was traveling.
    c Sounds are not recorded.
  17. howardbc
    howardbc Member
    154
    Scottsdale, AZ
    Wow, that would be great. I would really like to know what happened, even if it was my doing. No one else has mentioned an EDR or "black box," so I assumed that it's not available on a 2008 Prius. But thanks for mentioning that they are available on other cars. I didn't know what you meant by a NAH.
  18. mean-boy
    mean-boy New Member
    san francisco
    Sorry,
    Nissan Altima Hybrid = NAH
    I was thinking that since Nissan licensed the hybrid technology from Toyota this would have been borrowed as well.
  19. patsparks
    10,664
    567
    Adelaide South Australia
  20. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    Just for reference, it SEEMS like my 2007 Prius has a plastic "rod" as well. It's too dark now to tell for sure, but I felt around, and it's certainly shaped differently from what's shown in that 2008 metal rod picture...
