Blank bars in the Consumption screen?
Discussion in 'Gen 2 Prius Main Forum' started by avusblue, Jun 16, 2009.
  1. avusblue
    avusblue Junior Member
    Saint Paul, Minnesota
    Still a relatively new Prius owner. Love the car. Wanted to ask about a scenario that's happened to me on a couple of occasions:
    After crusing at 50 - 70 mph, I'll hit a traffic jam during my commute and I'm puttering along at a "slow & go" pace. Moving exclusively on battery power, probably averaging 5 to 10 mph. The consumption bar should be almost, if not completely, maxed out for that 5 minute segment, because I am making consistent, albeit slow, forward progress while burning no gas. The ideal setting for a Prius, right?
    But now and then I'll get a "blank" bar in between two segments that I assume means that the car thinks I scored 0 mpg during that segment. The bars to the left of the blank seems accurate, as does the one that eventually appears to the right as the time chart moves along.
    Interestingly, the blank segment still shows the little car-shaped leaves representing the energy captured during regenerative braking . . . which proves that I was indeed, moving along, speeding up & slowing down as the traffic flows.
    Any reaction? Is this normal, an anomaly, or seem like a fluke? Does this mean the 5 minute segment at 0 is being averaged into my overall MPG (which lifetime to date over almost 3,000 miles so far is 50.3)
    Thanks for the input. Not a huge deal, just curious.
    Cheers,
    Dave
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    That's normal when running on just the battery.
  3. Tideland Prius
    16,431
    If the engine came on at any time, it'll be near blank. (and the arrows don't have to be flowing for the engine to come on)
  4. avusblue
    That's interesting. So basically, a blank bar means you achieved "infinity" gas mileage rather than "zero" gas mileage during that particular 5 minute segment.
    That's not the way I would have done it, but I'm glad its normal!
    Thanks and cheers,
    Dave
  5. qbee42
    3,076
    The U.S. Prius has a divide by zero issue when no fuel is used. Normally this is displayed as 99.9 mpg, but when not moving you get zero divided by zero, which is undefined. A blank bar is displayed in this case.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    My opinion is that the car didn't travel far enough in 5 minutes to recognize a distance. 1 mile in 5 minutes is 12mph. Less than 1 mile and a little gas rounds to 0mpg.
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
    The behavior is different between 2004-2005 model and 2006-2009 model.
    When there was no fuel usage at all and the vehicle moved during the 5 minutes period,
    the 2004-2005 model displays full (100mpg) bar on the screen and
    the 2006-2009 model displays no (0mpg) bar on the screen.
    That's the feature, not a bug. :)
    Ken@Japan
  8. CharlesJ
    CharlesJ Member
    467
    29
    Monterey
    Do you have that screen open when you are in that traffic jam, slow progress? What indications you get from that right bar showing instant MPG? When I am in such a condition that it is running on battery only, flat terrain, coasting, etc, I see full 99.9 reading and have after 5 minutes seen the full bar in the 5 minute segment.
  9. avusblue
    Yes - and the instant MPG bar over on the far right is generally pegged at the max ("100mpg") because I am moving along making forward progress while using no gas.
    Again, the real mpg is "infinity" in this scenario -- where the Prius is really in its element! :)
    Dave
