Trouble inflating tires on GIII
Discussion in 'Gen 3 Prius Main Forum' started by charlotteprius, Jun 16, 2009.
  1. charlotteprius
    charlotteprius New Member
    Charlotte, NC
    I just checked the air pressure in the tires after a couple of weeks on my 2010 II. Needed some, but found the standard air chuck(s) on my compressor would not fill. Seems the valve stem is smaller and the release pin in recessed further not allowing it to release. Had to push the tire gage very hard to register the pressure. Anyone else having problems or have recommendations?
  2. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Nope, the same old pump as with my two previous Prius works as is.
    Sorry, I'm not sure why yours would be different.
  3. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Checked with my standard digital gauge and added air with standard air compressor fitting - 17" tires.
    The wheel's valve stem appears to be a bit slimmer/smaller diameter but I had zero issues working on mine. Perhaps stop at a tire store nearby and have them check it out...
  4. fuzzy1
    10,412
    No problems with my gauge. But the dual Schrader / Presta head on my floor pump doesn't work well with the wheel covers. The only angle it fits leaves the hose nearly pinched.
  5. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    No problems with mine. I use a portable pump powered by the 12V plug in the car, and I noticed only that it was slightly easier to lock/unlock without letting air out of the tire.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I had problems w/ the air compressor nozzle as well - the 60°+ angle versions are hard to seat w/o possibly scratching up the wheel covers.
    I was also surprised to see a lack of green caps - I thought that was an indicator of TPMS, or am I mistaken?
  7. equake
    equake Member
    155
    Los Angeles
    I think the green caps indicate Nitrogen inflation if I'm not mistaken.
  8. fuzzy1
    10,412
    My past green caps were for Nitrogen, from Costco, on a car without TPMS.
  9. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    No problems here.
  10. qbee42
    3,079
    Green caps are for "Nitronized" tires. Obviously most tires are filled with mostly nitrogen.
  11. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    I also Found it a bit harder.
