No Touring model in 2010?
Discussion in 'Gen 3 Prius Main Forum' started by nickfromny, Apr 21, 2009.
  1. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    What no touring performance driving model available? Thought we wanted better gas milage so we could drive. Most of the US roads have twists.:(
  2. mirak
    mirak New Member
    127
    Discussed extensively in other threads. The Prius V with the 17s is the 2010's version of the Touring. Additionally, the suspension on all 2010s is supposedly improved.
  3. qbee42
    3,079
    Essentially *all* of the 2010s are touring models. They all get new improved suspension and a stiffer rear end. In addition, as pointed out above, there is a package with fancy wheels.
  4. Tideland Prius
    16,547
    I thought US roads were generally straight lol.
    Yeah they all get the euro-tuned suspension.
  5. qbee42
    3,079
    We have a mile of straight road north of town. As teenagers, that's where we would take our cars to see how fast they could go. Everything else around here is a deer trail with pavement, some without pavement.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Funny that, I find the twisty roads to see how fast my car will go.
    The Aussie Prius handles pretty well although it has a little much body roll but it isn't all that bad.
  7. Tideland Prius
    16,547
    Interesting... we have this road called the Trans-Canada Highway. Between Medicine Hat, AB and Winnipeg, MB, it's fairly straight... and boring. You can do over the limit for miles and miles and you'll just see prairie grass and landscape.
  8. qbee42
    3,079
    When I was a teenager, most American cars didn't do well around corners. That was an era of big iron, followed by an era of poor performance when emission controls entered the scene. I had a Jeep C-J5 that took eleven seconds to go from zero to sixty, even with a 304 cubic inch V8 engine. The Jeep was especially bad on corners.
  9. nickfromny
    309
    24
    Binghamton, NY
    Are the 17" wheels and tires lighter than the 15's or 2009 16's? Heavier unsprung weight(wheels, tires, brakes, shocks) will hurt performance. To fix body roll one needs a stiffer front end to eliminate/reduce roll. One can add stiffer front springs or a stiffer front sway bar to achive.
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    The 17" wheels are not lighter than the 15" wheels.
  11. Tideland Prius
    16,547
    I highly doubt the 17s are lighter than the 15s. The 15s are lightweight alloys (lighter than regular 15s). The 17s are regular alloys so the difference will be greater.
  12. KlumzyDriver
    KlumzyDriver New Member
    Northern NJ
    Will the Touring model get it's own EPA mileage rating? I have to think the larger wheels will cost some efficiency.
  13. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    nope... I think EPA is using the average of units sold.. but european prius is several % less efficient with 17" (tested)... I think difference was between 2% and 3%.
    It is not required to test car with different numbers, Toyota did it in Europe since it is Prius. Same results are valid for any other car (increasing weight, rolling resistance increases fuel consumption).
  14. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Specifically the 15" wheel is reported as 3.9L/100km fuel consumption, the 17" as 4.0L/100km, 2.5% more. Those figures are not yet final. The fuel consumption figures are rounded to 0.1L/100km which loses quite a bit of precision at this level. The CO2 emission, 92g/km compared to 89g/km, is 3.3% higher - the CO2 emissions are reported to 1g/km.
    The UK government's fuel consumption site, VCACarFuelData.org.uk, has numerous models where the manufacturer has had to submit different results for different tyre sizes - where they have had to have multiple type approvals. The Mercedes C-Class saloon, for example, is shown with 51 different configurations depending on engine, rear tyre size and gearbox. The C180 Kompressor (turbo) with 5-speed automatic gearbox has three entries, for 195, 205 and 225/245/255 width tyres. (CO2 emissions for those cars are 180, 182, 185g/km respectively.)
  15. freo-1
    freo-1 New Member
    180
    22
    Mass.
    Though I would bring this back. What does the 2010 exactly have for a suspension? After checking out my buddy's 2010, I still think the 09 Touring model has a better road feel.
    I'm not sure if it's just the 16 tires, or if the Touring rear suspension is a little more involved than the 2010?
  16. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    And I assume your buddy is driving a Prius II thru IV model?
  17. freo-1
    freo-1 New Member
    180
    22
    Mass.
    Yes, a Prius II.
    And, from looking at the Toyota website, it appears that the Touring model rear suspension may indeed still be different from the 2010 model.
    If so, that would explain it.
