Typical water usage?
Discussion in 'Environmental Discussion' started by Celtic Blue, Jun 26, 2009.
  1. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Since some here are in regions with serious water depletion issues, I thought it might be interesting to hear what typical water usages are for forum members.
    I'll start with my own (two adults, two kids, modest yard):
    In-home use ran about 5.8 kgal/month over the past year.
    Lawn use ran about 10.1 kgal/year. The annual total was a little less than 80 kgal/year. Rates here are about $3+/kgal.
    Primary water consumption for us is four showers/day, 1 dishwasher load/day, 1 load of laundry/day, handwash of misc. dishes 2-3 times/week, cooking use 1-2 times day, some lavatory sink use, uknown number of toilet flushes.
    I've taken a few steps that have reduced our consumption, some of which are already reflected in the average above: 1 low flow showerhead, 1 front loading washer, insulating hot water lines (so that taps/showers come to temp faster.) I'm a believer in minimal lawn watering but took over from someone who seriously overwatered the lawn, so I had to water it more than I liked last year to keep it alive.
    This year's water conservation plans include: another low flow showerhead for the master bath and one high efficiency Toto toilet (1.28 gpf). If the high efficiency toilet works well, then I'll probably repeat in the other two baths. As I understand it the ecoDrake I'm looking at can be converted back to 1.6 gpf by changing flappers so there is little risk in the experiment. The current 1994 vintage toilets are marginal flushers, retiring the plunger is the primary motivator for replacing them. Hopefully the above changes will knock water use down by another 1 kgal/month and get us down to around 4 kgal/month excluding lawn irrigation.
  2. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    I'll have to check ours.
    We have 2 shower takers and 2 bath takers (who take a bath together, the dirty, wee buggers). 1.6 GPM shower head. We have vintage toilets (1.6 GPF) but I put a brick in each toilet tank to try to reduce the amount of water in the tank (is this a waste of time?).
    We have a typical, top loading washer, but it has an adjustable load setting which we use with every load. Probably not as good as a front loader, I'm sure, but we probably save quite bit of water. We also have it set on one rinse cycle instead of two.
    We don't leave faucets running while doing dishes, hand washer, tooth brushing, shaving, etc. I'm not sure what our water usage is for the lawn (this year it's quite low because it's been quite wet), but I have the zones adjusted for what makes sense for that area and I never let the system run if it has rained recently. Our backyard if filled with trees so the grass doesn't need a lot to do fine (we have, mostly, KY Bluegrass, idiotic I know). I'm thinking about Xeriscaping the front yard to: a.) dramatically reduce the amount of water we use. b.) save on time maintaining the lawn. c.) reduce the amount of weed killer I have to apply to keep crab grass and various broadleaf weeds in check.
    We'll eventually replace the washer with a front loader. I'm going to buy a new dish washer very soon and energy star will be criterion for sure. Cost most also play a key role right now, sadly.
    I'm interested to hear what others have to say on the subject, esp the desert rats (not the WW2 blokes).
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    My house has an Energy Star dishwasher, washing machine, etc. Minimum 2 adults, sometimes 3 adults depending on how long my Aunt visits
    Dishwasher every day, twice a day on the weekends. Washing machine load every day. Numerous showers, etc.
    My water meter reads in cubic metres. Fall, winter, spring, I average 18-22 m3 a month, or about 4,700-5,800 US gals a month. In summer, depending on how much I have to water the lawn, 35-60 m3 a month, or 9,200-15,800 US gals a month
    Compared to my neighbors, my water consumption is 15-25% lower. Water here is pretty cheap, I only get billed every 3 months. The winter bill is usually around $55 for 3 months, the summer bill around $200 for 3 months
  4. burritos
    burritos Senior Member
    4,946
    253
    Live in Socal. Don't know how much we use, but with 3 adults, one toddler we pay about $15-25/month, summer months $35-50/month.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    2 Adults in an 1150sq.ft. apartment = 3670ga/mo ($55.11/mo).
    Once my roomate moves out I expect the water use to be cut nearly in half because she does soooo much laundry. lol Iguess i'm partially to blame for being sick and haviong to use the bathroom so much.
  6. JSH
    JSH Senior Member
    2,605
    140
    PDX
    We averaged 2066 gallons per month from January to March. The garden was planted in April along with some ground cover in the front yard. That jumped our usage to 3050 for April and ??? for May. (City had to come out and replace the meter)
    Our main usages are 1 shower per day and the toilets. (We do go by the "If it's yellow..... rule so that cuts down on flushes.)
    Other than that we do about 3-4 loads of dishes per week and 3-4 loads of laundry. The garden has been watered about every 3 days and is well mulched to retain water. We put down about an inch of water per watering.
  7. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    I'm single and live alone. I do have a yard, but it's not big, and I don't water it very often. I do shower every day, but laundry and dishes are only done maybe once a week.
    I think I'm averaging around 1400 gallon per month. I'm pretty sure less than 2k. If I do water the lawn a lot, that can easily go up to 4 or 5k.
  8. fuzzy1
    10,406
    In my water district, residential customers average 84 CCF per year. (CCF = 100 cubic feet = 748 gallons)
    With the old water hog toilets, dishwasher and clothes washer, my household (2 adults) averaged 66 CCF/year (4100 gal/month). With my upgrade three years ago to 1.6 gpf toilets, EnergyStar dishwasher and frontloader clothes washer, two rain barrels for hand watering, and consistent use of drip irrigation instead of sprinklers in the gardens, usage has fallen to 31 - 37 CCF/year (1930 to 2300 gal/month), depending on how much we travel.
    The lawn is not watered. Any dryland farmer knows that grass is supposed to go dormant in the summer.
    If any household member has that middle-aged problem that the TV pharma ads call 'bladder urges', then it is imperative that any old water hog 3.5 or 5 gpf toilets be replaced. The common cheap replacement flappers and mechanisms push these hogs to even higher levels of wastage than the original parts.
  9. Celtic Blue
    2,224
    139
    Midwest
    We did the same up until they got old enough that it was causing problems. Counter to conventional wisdom they used less water that way compared to the next year or two when they started showering. At first when they were showering I couldn't get them out without a struggle. Kids do like the little hourglass timers you stick to the side of the shower though, that helped.
    If the toilet still flushes adequately then it's fine. If I did the volume calc right the standard U.S. brick dimension works out to 0.3 gallons. So you've effectively converted yours to an HET (High Efficiency Toilet) at the expense of a brick. The advantage of such a conversion is that the starting level remains at the same height so the initial impulse is unchanged.
    Most toilets are still 1.6 gpf. The 1.28 (or less) types are the High Efficiency Toilets or Watersense. Some are the dual flush type: 0.8 gallons for a whizz, 1.6 for a deuce (or anything with paper.)
    Our old 1.6 gpf standard Gerbers have a couple of problems: they really aren't well designed or fabricated for the flush volume and they have small water spots. The water spot is the area of water in the bowl. If the toilet waterspot is too small like ours (about 4x5 inch) then the toilet is prone to needing a second flush to clean off skid marks...and often a brushing too. Plus when in use anything missing the waterspot tends to make the room smell like an Asian style squat/slit toilet (which are about one step improved from an outhouse)...making courtesy flushes advisable. The Totos have about three times the water spot area of our old Gerbers.
    Of course, I can't justify this sort of change (1.6 to 1.28) based on water saving economics, but it's not hard to conclude that it is worth doing to eliminate unpleasant clogs & extra clean up, and to reduce odor. I would gladly hand someone $20--probably more, at least $50 when company is around--to make an individual clog disappear as if nothing happened (without the mess and cleanup.) :( Doesn't take many events to pay for a new toilet on that basis.
  10. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    In winter when we don't irrigate, we use about 100 gallons per day (4CCF/month) for the two of us. I'd like to get that down to what JSH has above. What we've done so far:
    - converted toilet in Master BR (most used toilet) to Australian Caroma toilet (dual-flush 1.6 or 0.8 GPF). Hall bath toilet is next when we remodel
    - We also follow 'if it's yellow...'
    - We capture warm-up water from showers and use in the garden
    - We also capture hand-washing and other grey water in sinks and use in the garden
    - Low-flow shower heads. Also do 'military' style (rinse-turn water off- soap up- rinse)
    - Although I do collect some rainwater in garbage cans in winter, it is quickly used. I would like to set up a bigger system for storing.
    The thing we need to work on is our garden. We have a relatively big lawn in the back. I think I'm going to take out half of it next year and sow red clover in the other half to reduce it's water requirement. Right now I water it just to keep it from 'burning' (esp. the roots), but it is slowly turning golden. I also don't skimp on the veggie garden, but do amend the soil well and use mulch. Summer usage is much higher, probably 15-18 CCF/month, and I want to knock that down.
    Thanks for posting this thread. I've been wondering about relative usages.
    BTW, our property is a typical suburban property, about 1/4 to 1/3 acre in size.
  11. Celtic Blue
    2,224
    139
    Midwest
    I was looking at the EPA's Watersense site. They claim that the average use is about 100 gallons/day per person for a family of 4! (That must include irrigation.) Our current average is at around 5,000 gal/month for 4 of us or about 42 gal/day per person (if there is no irrigation.) This is as a result of the front loader and low flow showerhead that have reduced our average in the past few months.
    Others here seem to be in a similar range. My target is 4,000 gal/month for 4, about 33 gal/day per person for indoor use. Looks like fuzzy1 is already there as far as use goes. It would be easier if we weren't such homebodies and nobody was home during the day or if we ate out more or had more dry cleaning.
    If I was doing things from scratch I would probably look at a cistern for roof runoff and use that as the suction tank for the sprinklers. That would be enough to eliminate irrigation for us. I really only use irrigation as life support anyway. I ran it for a few minutes this year during an early spring dry spell, just to make sure none of the heads had frozen this winter and so that I knew it would pass backflow inspection. I haven't needed it since due to some well-timed rains. When the lawn is getting dry enough to warrant watering the birch trees start shedding some yellow leaves...that's what I figured out last year as a tell.
    Water is probably the one utility most directly correlating to body count in a home. Shower/baths, toilet flushes, laundry loads, dishwasher loads, etc. are all almost perfectly correlated to the number of occupants. (Irrigation is not.) Contrast this with electric/gas that are more strongly correlated to the size of the residence and somewhat insensitive to the number of occupants.
    Compare this profligate target (33 gal/day/person) with backpacking or primitive camping/canoeing I budget about 2 gal/day of filtered, treated or boiled water per person for everything including cooking, dishes and the occasional sun heated shower. Of course the laundry is a lot more primitive...and the toilet involves a small shovel and a bit of paper at worst.
  12. tripp
    4,717
    79
    Denver, CO
    The brick was free, mate. I found it in the back garden. Good to know about the volume calc. Thanks for that info.
  13. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Ours is metered in Cubic Ft... and we are billed every two months. Three adults, one of which only comes home to shower (!) (That's just one cubic foot, btw... not 100 cubic foot. Once cubic foot contains 7.5 gallons of water, according to wikipedia)
    In the previous two months, we used 730 CF. Our usage a year ago (when there was just the two of us...) was about 600 CF for two months. (730 CF = 5475 / 56 days = 98 gallons per day)
    I do have a garden this year, and am watering my raised beds every few days... and we have four new trees I'm keeping alive by watering them until they get well established (I lost the little japanese maple by not watering it enough :( )
    I do have a dishwasher -- it runs about 4 times a week. I do three or four loads of laundry a week, in a front-loading washer. We tend to shower more than bathe.
    Does this help?
  14. PriuStorm
    2,239
    149
    Davis, CA
    Well, whaddaya know... reading Rae Vynn's thread, I just realized that my 'monthly' winter usage of 4 CCF is actually a TWO month usage! That puts us at 50 gal per day with two people, or 25 gal per person during winter. OK, I feel much better now. Same with the other usage of 15-18 CCF in summer... that is two months.
    Update on my hall toilet... funny, right after I wrote my post above, the bar off the handle that lifts the flapper broke. When I went to ACE Hardware to price replacement parts, it was not that much more expensive to just buy the kit that converts the toilet to a dual flusher. And Voila! Now we have two dual-flushers in the house. :)
  15. Celtic Blue
    2,224
    139
    Midwest
    Ours is metered in ccF as well, but I figured folks could relate better to kgal, especially since I anticipated the discussion drifting to gpf, gpm and gpd.
    The nice thing about these threads is that most folks here actually analyze their various utility bills in units of consumption rather than just dollars. It is so much easier to have a productive conversation with folks who speak the same language. Whereas it is frustrating to have this sort of conversation with highly intelligent folks who only think in terms of dollars on each statement and have never even considered their engineering unit consumption.
  16. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Less than 2000 gal. every 3 months. 2 adults. No washer/dryer. And feet of rain this spring. Sump pumped 500 gal + a day for most of spring.
  17. Celtic Blue
    2,224
    139
    Midwest
    Man, that's low! GPD per person would work out as:
    2000 / 3 / 2 / 30 = 11.1 gallons/day per person.
    To cut water back that much we would have to curtail toilet flushing in a big way (2 about 2/day per person) and shower about every other day for 5 mins with 1.5 gpm showerheads.
    I'm assuming the clothes washing is done at a laundromat. Are you showering at work? One could cut a lot of home water use if using change-house showers and if the company laundered uniforms/overalls.
    Eating out would cut home water use as well. (Of course using the laundromat, showering elsewhere, and eating out really wouldn't reduce personal water use, just shift it out of the home.)
  18. qbee42
    3,079
    Not a clue for me. Water is one thing we have in spades. In this area, the only issue relating to water is the cost of pumping. We have amply fresh water, and after use it recycles right back into the same aquifer.
    I have the figures here somewhere - let me check. Ah, there it is: we have 5,000 cubic miles of drinking water right outside our house, and that's just surface water. There is more if you consider what's down in the ground.
  19. PriuStorm
    2,239
    149
    Davis, CA
    Wow! ~22 gallons per day total for the household. That's a little more than 4 buckets of water per day... total! (5 gal buckets). :eek:
  20. F8L
    19,011
    4,083
    Grass Valley, CA.
    If you think about it, you would end up using more water during shower days so on some days you would use less than 22ga. lol
