Change radio station presets without touching screen?
Discussion in 'Generation 1 Prius Discussion' started by jdms2000, Jun 25, 2009.
  1. jdms2000
    jdms2000 New Member
    37
    Irvine
    2002 Prius
    Is there any way to scan through my radio station presets without touching the screen for each station? I have a 2002.
    Thanks!
  2. Tideland Prius
    16,547
    Press and hold ">>"?? on the SEEK button or was it just Press? I can't remember. Try one of those methods. One will skip to the next available station, the other should go through your presets if I remember correctly.
  3. jdms2000
    jdms2000 New Member
    37
    Irvine
    2002 Prius
    That didn't work on my radio. I was so excited, too.
    Pressing the >> button goes to the next signal, like 105.9 to 106.1 to 106.3.
    Holding down the >> button tunes the radio to the next clear signal.
    Any other options?
  4. Tideland Prius
    16,547
    oh darn. Sorry!! Guess you can only select your presets on a Gen 2 Prius and up (using the steering wheel buttons).
  5. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi jdms2000,
    You can try to press and hold [SCAN] until you hear a beep. "P.SCAN" should appear on the display. The radio will tune to the next preset station, stay there for a few secs. and then move to the next preset. You can select a station by pressing [SCAN] a second time.
  6. jdms2000
    jdms2000 New Member
    37
    Irvine
    2002 Prius
