First Fill-Up?
Discussion in 'Gen 2 Prius Main Forum' started by baeckknit, May 15, 2005.
  1. baeckknit
    baeckknit New Member
    I know it will be a little bit til I'm ready to fill my tank for the first time, but I have a question.
    When I fill it for the first time, where will I find the mpg display for the tank? Do I have to use a certain screen with the trip info? Will the car know I'm filling it and compute it for me automatically and bring up a screen? This car has so many different things, I'm a bit overwhelmed at times--although I love it dearly.
    I have an 05 package 4 by the way.
    Thank you,
    Babs in Lebanon PA
  2. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    congrats on your new Prius!
    your tank mpg will be whatever is displayed on the screen before you fill it. (consumption screen)
    after adding more than 2 gallons of gas it will automatically reset so if you want to keep track, make sure you write down your mpg number before filling up. i also jot down miles per tank.
  3. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    Right. The consumption screen has a reset 'button' on the right side. If you press that ANY time other than just after you fill up, you won't have the car's reading for MPG for the tank. It is always MPG since the last reset.
    Over time, your actual miles and gallons pumped in will be the accurate 'lifetime' reading. But tank to tank, since you never know if you are putting in exactly the same amount you used, the computer MPG is fine. Mine seems to run high by less than 0.5 MPG for the entire tank.
  4. baeckknit
    Thanks to both of you. I had a wee bit of a problem filling up for the first time--I didn't trust the first time the pump shut off, thinking there was no way I only needed about 8 gallons and overfilled. I definitely won't be doing that again!
    But I did write down my mpg for my first tank---50.3. I'm still going wow over that! And I did reset my button after filling, so now that I've done it once, I at least feel a little more comfortable.
    Barb in Lebanon PA
  5. yoda
    yoda Member
    116
    San Diego, Ca.
    Hi Barb,
    Congrats on your Prius purchase.
    YOU GOT OVER 50 ON YOUR FIRST TANK? I'm friggin jealous! My Prius is just over a month old - I'm on tank 3. Averaging 42 mpg - and I'm THRILLED with 42! But I've been told not to expect over 50 until the car "breaks in" (about 10,000 miles). Even if it stays where it is, I'll be quite happy, but I HAVE noticed increases since I bought it (first tank was 39 mpg) so I'm guessing this "break in" thing might really have SOME merit.
    That said - the one thing no one else mentioned (I don't think) - Trust your consumption computer - NOT the amount of gas you put into the tank. Prius has a bladder in the gas tank (designed to reduce emissions). There are VARIABLES that cause a "fill up" to be less accurate then the computer consumption screen.
    Yoda
  6. baeckknit
  7. dontcheff
    dontcheff New Member
    68
    Helsinki
    For all I have noticed is that MPG depends (believe it or not) on the fuel I tank (not the octane, it is always 95 but the petrol station I tank at). Same route, same speed, same outside temp., MPG varies from 45 to 50. Trip distance is 300 km (about 200 miles).
    At least I know now from where to tank in order to get better MPG :)
  8. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    Some totally anal Prius owners have gone so far as to public track fuel consumption and other statistics for all to view.
    I think it's stupid myself, but I'm curiously drawn to it...
    http://www.w8kc.com/priusmileage.htm
  9. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I'm even calculating cost of ownership per mile, taking price, interest, maintenance, deducting equity, etc. So far, about 65 cents per mile, which will go down significantly as the car gets paid off, and purchase costs get averaged into more miles.
    Also calculating estimated gas cost savings over my former Saturn
  10. DanMan32
    3,799
    27
    Tampa Bay, FL
    I was in upper 40's first 2 tanks myself, but realized I was 'idling' with the AC while playing with NAV during summer, and had taken more trips on highway. Normal commute was more in the mid 50's.
  11. john1701a
    john1701a Prius Guru
    12,794
    5,276
    57
    <div class='quotetop'>QUOTE(priusham\";p=\"91141)</div>
    No offense taken; however, you have grossly misinterpreted the purpose.
    The actual reason for publicly documenting real-world effeciency data is too prove the misconceptions incorrect.
    Some of us are so frustrated by the false claims people make, we go to the trouble of providing detail to show that they are incorrect.
  12. DanMan32
    3,799
    27
    Tampa Bay, FL
    Well, for me, I am a pack rat, and that includes useless data. Well, not terribly useless.
    I still have most of my electric bills as far back as '92. I plan to get trends on that, including monthly, seasonally and yearly consumption and cost trends.
    So, yes, a bit retentive AND PROUD OF IT! :)
  13. yoda
    yoda Member
    116
    San Diego, Ca.
    Danman,
    Being THAT detail oriented, you MUST be an Accountant (or at least the accounting type)
    That explains two things.
    1. Why you bought a Prius.
    2. Why I like you - we are very similar. 8)
    Yoda
  14. DanMan32
    3,799
    27
    Tampa Bay, FL
    Actually, network engineer. I provide network OS and Email systems support for resellers. I am very detailed oriented though. A messy, disorganized, detailed person.
  15. bruceha_2000
    3,054
    301
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(yoda\";p=\"91064)</div>
    Break in yes, but temperature and what sort of driving you do has more to do with it.
    My first tank, mostly coming home from the dealer was about 49 MPG, A lot of 50 MPH or less with few stops then 30 miles of 65 MPH interstate.
    Worst was just under 33 MPG when the temps were max single digits above 0F for 2 weeks.
    Now have ~8K on the odometer, just filled at 491 miles, 51.9 MPG computer. Would have waited since I hadn't gotten to 1 bar blinking yet and could have made 500 miles easily. But my wife IMed that a station was selling at $1.969. Couldn't pass that up, it is $0.10 less than the lowest I've seen in months. I was really hoping for my first 52 MPG reading as it has been bouncing between 51.7 and 52.3 the last 4 bars. Unfortunately the station was too close to work, the first 5 minutes pulled it down.
    But I'm not anal about it or anything :roll:
  16. priusham
    priusham New Member
    525
    <div class='quotetop'>QUOTE(john1701a\";p=\"91240)</div>
    John old boy, you do know that the website I mentioned is actually mine? I'm making a slight joke of it.
    I created the on-line version of the gas mileage because I saw yours during my research and I thought it was pretty cool :)
    Like you, I also use it to give validation to what happens in REALITY when the temp drops, the oil is changed to Mobile 1, the miles driven goes up, etc.
  17. DanMan32
    3,799
    27
    Tampa Bay, FL
    Now that's a new one, a kitty that's humble enough to laugh at itself.
  18. john1701a
    12,794
    5,276
    57
    So am I. Being anal is actually a good thing, a must on a resume for my particular career. That has resulted in an unusual perspective, where insults are actually taken as compliments.
    Did you know I have a collection of over 1,000 music videos on my computer, all digitized *BEFORE* my Prius became a reality. Back then (5 years ago), most people hadn't ever heard of MP3. And here's John, with 75GB of MPEG-1 files.
    How about that? I absolutely did not want to lose that aspect of my past. So I preserved it on disc. Needless to say, it was a great thing to do. It was proof I was strong-willed (stubborn/anal) enough to do the same Prius in the early days. So I did.
    Interesting, eh?
