Typical water usage?
Discussion in 'Environmental Discussion' started by Celtic Blue, Jun 26, 2009.
  1. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    Sure, of course. But other than folks in 3rd world countries who are lucky to have the use of 5 gallons per person per day (which, btw, was the allowance afforded to a friend of mine who took a month long guided safari-type tour of Africa), that low of a water usage is... dare I say... unheard of, or at least, highly unusual in a westernized country.
    Last year, a group I belong to challenged everyone to 'make do' with 5 gallons of water for one day. It was very difficult when considering all our modern 'conveniences' (particularly, toileting, showering, hand-washing, etc.). To accomplish such a low usage sustained for several months is quite admirable. :)
  2. fuzzy1
    10,433
    One can get by on less than 22 gal/day even with a daily shower. I've done it, when home alone.
    It helps that our 2 gpm showerhead has one pattern setting that produces an acceptable pattern, to me, when turned down to 0.6-0.7 gpm. But one must not have one of those shower mixer valves that has only a single flow rate, full blast. I regard those valves as a ******* waste.
    For the doubters, try practicing with one of the bag-style solar showers. And learn to share a single bag with others.
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Totally! I wasn't disagreeing with you. I was just saying how crazy it sounds that you could use less than that on some days. :)
  4. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    There are two primary water users for us: showers and toilets which are roughly equal in consumption. The front loading clothes washer and energy star dishwasher combined are small users in comparison to either of the other two.
    Getting by on amounts of ~2 gal/day is trivial for short time periods (camping/backpacking, etc.) where almost all of the water is for drinking, cooking, and washing pans, with a rare solar shower. But at home in town where one is using the sewer system and bathing regularly, and doing laundry the quantity is much higher.
    Decisions about how to best reduce shower and toilet water consumption are more delicate...particularly the latter. Skipping showers at times works, but it isn't for everyone. Buying lower flow showerheads and taking shorter showers also works, but some aren't ready for that step. And skipping flushes...well, that is not high on my agenda. I spent too long training my kids to flush (and flush often with the problematic older 1.6 gpf that didn't handle toilet paper well) to untrain them now. Barring necessity, I'm unlikely to change flush habits. So for me, going to a toilet that does the job well with less water is the primary option.
  5. oxnardprof
    oxnardprof Member
    250
    17
    Oxnard, CA
    Here in Oxnard, we use 5 HCF, or about 3750 gallons per month for a family of three.
    Dishwasher (new model) averages twice per week.
    Showers each average once per day (so, three showers per day).
    Clothes is front loading, efficient model, average of once per week.
    Garden is low water requirement, no lawn.
    The 5 HCF per month (our goal is to stay below that number, for example the bill I just got shows 4.6 HCF last billing cycle). If we do so, we will use less than 40 gallons per day per person.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    One thing I forgot to mention was that the community I live in has well water, and the water is *very* hard >60 grains. I have a Sears Ultra Soft 800 softener and it regenerates 2-3 times a week
    Every time it regenerates, it uses around 0.5 m3 of water. That's about 132 usg
  7. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    I'm surprised Tom hasn't chimed in on this thread. Cruising sailors regularly get by on very little water. "Water makers" are expensive and can be unreliable. Catching rain water in sails is a tried an true technique, but since you never know when you're gonna get it, you measure every drop.
  8. qbee42
    3,079
    I did chime in earlier. The issue is that I do most of my cruising on 1/5th of the world's fresh water supply. The water tank on my boat is connected to 5,000 cubic miles of drinking water. On the Great Lakes I don't use a desalinator, I just run the water through a Katadyn ceramic filter, which is cheap to run and very reliable.
    I bigger problem for us is black water. We aren't allowed to flush over, like you can do in the ocean, so it all goes into a tank. We are careful with flushing, and use a very efficient hand pumped toilet.
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    As an added bonus, the diesel engine in your sailboat will *never* overheat
    Hand pumped .... must be a joy when somebody gets the runs
  10. tripp
    4,717
    79
    Denver, CO
    oh yes, so you did. Yeah, I was referring to saltwater cruising. Love the ceramic filters for backpacking but it takes an age to pump a reasonable amount of water.
    Do you have a special "marine" one for us on the boat or did you go to REI and get a backpacking one?
  11. Celtic Blue
    2,224
    139
    Midwest
    Weather tricked me into watering before I left on a trip (wanted the lawn something other than bone-dry for any 4th fireworks while I was absent and the rain chances were shown to be poor.) It promptly rained several inches in the following days. At least I was able to get a good measurement of each sprinkler station to determine where I might cut back. 1,100 gallons wasted.
  12. tripp
    4,717
    79
    Denver, CO
  13. qbee42
    3,079
    It's a hiking filter. I use a ceramic filter element from an "expedition" unit (made for larger groups). Pressure comes from a Sureflo high-pressure (100 psi) agricultural spray pump powered by 12 VDC. A typical under-sink type filter provides a charcoal pre-filter which removes larger stuff and organic contaminates. Production is about a gallon per minute with a clean filter.
  14. qbee42
    3,079
    It almost gets warm if we run it long enough.
    Flushing a marine head is a bit of an art. It often sounds like this: "Whoomph, squeak. Whoomph, squeak. Whoomph, squeak. <pause> Whoomph; whoomph, whoomph. <pause> WHOOMPHWHOOMPHWHOOMPHWHOOMPH. <pause> TOM! CAN YOU HELP ME WITH THE TOILET?"
  15. tripp
    4,717
    79
    Denver, CO
    LOL.
    Canny clever arrangement with your filter, BTW.
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    I think that's a sure sign that you two have been married a bit too long now
  17. qbee42
    3,079
    It's even worse with first timers on the boat. After a basic explanation of the various levers and valves on the marine head, my wife always tells new guests "...and if you can't get it to flush, don't worry about it. We will get it for you - happens all the time..." It's better to flush for someone that to have them either A) break the head, or B) fill the entire 55 gallon holding tank.
  18. Celtic Blue
    2,224
    139
    Midwest
    Getting back to the outdoor water use for a moment, I find the various guidelines for lawn watering at odds with common sense when considered in terms of efficiency. Most of it is written more from the perspective of keeping a green growing lawn throughout summer. So they tend to recommend watering fairly heavily in the morning and not watering at night/evening because of fears of mushrooms and fungus etc. Plus they indicate watering fairly heavily/rapidly each time.
    However, it makes more sense to me to run sprinklers late in the evening/night, giving the water time to soak in and for the grass to recover after the grass has just suffered through a long hot day. Since the guides point out that lawns have trouble absorbing more than 1/2 to 2/3 of an inch of rain it also makes sense to me to keep the watering at or below 1/2.
    I want to put just enough water on to keep the grass alive and relatively green...but not growing much through the summer. To me that means watering about once a week at about 0.5 inches when the rains don't come and the soil cracks...and not watering at all when the rains do come.
  19. qbee42
    3,079
    Adding to Shawn's comments, I can't understand how we collectively allowed ourselves to be convinced that green lawns are a necessity. Even in an area with plentiful water, like where I live, lawns are a horrible waste of resources: fertilizer, gas for lawn mowing, water to make it green, and all of the time used for lawn care. It just doesn't make sense, unless it's something you really like to do.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    How about first timers who develop a serious case of the trots? They might as well jump overboard
