bike racks for Gen III
Discussion in 'Gen 3 Prius Accessories and Modifications' started by loopybunny, Jul 15, 2009.
  1. loopybunny
    loopybunny team autobus
    17
    northern california
    I need a bike rack for my Gen III. Well, need might be kind of strong. Maybe the word I should use is want.
    I spoke to a Yakima representative over the weekend at a charity ride and he was unable to help me. Problem is that my car is just too new and nobody has an information on what bike racks work with the 2010 Prius.
    Hitch mounted racks - Toyota specifically makes a point to say that they do not recommend the use of these on the Prius (it's in the owners manual). Unfortunately, this is the way I wanted to go...
    Trunk mounted racks - The spoiler on my car seems kind of flimsy. How much pressure is put on that if using a trunk mounted rack? I'll most likely be hauling 2 or 3 mountain bikes, which easily weigh probably 30 lbs each with all of the components on them.
    Roof mounted racks - Yeah, my bike weighs about 30 lbs. I don't think I want to be trying to lift that over my head to get it onto the roof of my car. I'm more than just a bit clumsy and I'm sure I'll drop it. Or worse, forget it's there and drive under the carport doing serious damage to the bike and car.
    Does anybody have any experience on using racks on their Gen III Prius? I don't want to assume that because it works on a Gen II, it'll work on a Gen III. I had that problem with my Civic. I really don't want to do damage to my car, but I'd prefer not having to put our dirty mountain bikes into the back.
  2. REDWIND88
    REDWIND88 New Member
    53
    SEATTLE WA.
    I just use a trunk mounted rack which is 2 bike capacity. The straps up to the top of the hatch are pretty long so I have permanently bonded the straps. I only carry road bikes so I don't know if this is helpful. I have a sunroof so mounting on the top is out of the question.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    While hitch mounting isn't "recommended" - it is entirely possible.
  4. loopybunny
    17
    northern california
    Now why is it not recommended in the first place? I can understand them saying they don't recommned you tow a trailer or boat, but a hitch for a bike rack?
    I'm curious what the possible consequences will be if I decide to go this route anyhow.
  5. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    I don't get that either, loopy. Sure, the hitch adds weight and degrades aerodynamics, but no more so than on any other car. Plenty of folks have used hitches on Gen II's.
    I've also seen people fold the rear seats and haul multiple bikes inside, which is a great alternative if only 2 people or less.
  6. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    just in passing guys i did not use any rack on my gen2 and my gen 3 is bigger. i just folded the rear seats and put the bike in complete with wheel on. . i think that works great when there is only one bike and one peop (me)
  7. john1701a
    john1701a Prius Guru
    12,803
    5,287
    57
    None.
    The rack on back fits great, wrapping around the spoiler without trouble. I tried my Saris Bones 3-bike rack.
    Photos on the way... eventually... rather busy at the moment.
  8. loopybunny
    17
    northern california
    And the bikes aren't too heavy? This is making me feel a little better. I would love to see pictures just for reassurance.
    Thanks for the input.
  9. pdth
    pdth Member
    95
    32
    Castle Pines North, CO
    Me too, this could be just what I'm looking for.
  10. 2010-V
    2010-V Green, without envy
    Pennsylvania
    Saris claims the Guardian line will fit the 2010, just ordered one through my local Trek shop.
    I installed the Saris Guardian rack on my 2010 Prius today, 7/25/09. Check out my album for two photos.
  11. john1701a
    12,803
    5,287
    57
    Even less than the 2004 Prius, since the 2010 is pushed further back taking pressure almost completely off the glass.
    Of course, the arms touching the glass are for nothing but stability anyway... since the wind from driving reduces the weight on them to pretty much nothing.
    Support for the bikes is on the vertical legs. Here's photos from the Iconic model... bike rack
  12. pdth
    pdth Member
    95
    32
    This looks really good, John. It appears the hatch can't be opened without removing the rack, correct? Is it as quick as it looks to install and remove it?
  13. RickFlashman
    RickFlashman New Member
    141
    31
    Winter Park, FL
    Glad to hear, I got a Saris Bones 3-bike rear rack too, red one at that, sitting in the garage from a former car. So
  14. LAPriusIV20
    LAPriusIV20 New Member
    30
    Los Angeles
    I have a Yakima Receiver Hitch Rack from my Tahoe. I am planning on getting a hitch installed on the Prius to attach the rack. I have seen the warning posts about installing a hitch mounted rack.
    Has anyone had a receiver installed on their Prius yet?
  15. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Not recommended does not mean "will void your warranty". That 'warning' didn't exist in the '04 and '05 owners manual, started in the '06 when Toyota saw that the 'towing not recommended' (even though the service manual has items to check more often if towing, a sentence that is also in the '06 manual) didn't keep people from getting receiver hitches for bike racks. I don't know what their issue is regarding hitch mounted racks unless they are concerned some idiot will load it up so much the front wheels start to lift. Certainly the drag of bikes on the back will be less than bikes on the roof. Even a light trailer with a tongue weight of 10 to 20 pounds would be less drag than a roof mounted cargo carrier. You'll find a number of PriusChatters have successfully used small trailers with no ill effects.
    I have a Saris Bones 3 bike rack. Most of the weight is on the rear bumper and I pad the top straps with pipe insulation. The top straps don't pull down on the spoiler though. Check this picture on John's site (I have the same rack and two of the same bike, though I've not had a need to put both on the rack at the same time.) http://john1701a.com/prius/thumbnails/Prius_RecumbentBikes_03.jpg We have only used it for relatively short distances and not on the Interstate so I don't know if that would make a difference. I think the spoiler on the 2010 is a bit larger than the 2004-2009 which might make a difference, I suggest you go to the bike store and do a trial fit of ANY rack you buy to see where it , or any bikes might contact the spoiler.
    I also have a 2" receiver hitch (Coastal Tech) and a 45" Masterbuilt Hitch Haul Sport plus 48" cargo bag. Used the combination (first and only time since I just got the cargo tray and bag a month ago for a trip I knew would not allow 4 passengers and gear for the trip) last month. NO PROBLEMS! I actually bought the hitch for this exact purpose not long after getting the car but didn't run into anything I couldn't handle inside the car until now. 4 people lots 'o gear, 150 miles Interstate and country road, 55 MPG. See my album. Since I already had the Saris for my prior vehicle AND we don't use the rack all that often AND the receiver bike racks are expensive, I haven't bought a hitch rack.
  16. jcleme1537
    jcleme1537 New Member
    Studio City, CA
    Hey there - I really like the Saris Bones 3 rack but I don't see any pictures with the GEN 3 Prius - these pictures are all with the GEN 2 Prius. Does anyone know for sure that it works with the new 2010 prius?
  17. loopybunny
    17
    northern california
    That's a concern of mine because I ran into that with my Civic. A certain bike rack worked on all Civic EX coupes except for my model year and one other, and they weren't consecutive years. Just because a rack fits on a 2009 doesn't mean it'll fit on a 2010, especially since they've "restyled" the body.
  18. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    Just so you know Thule has clips for the 2010 Prius. I had a hitch on my gen II and have a hitch mount bike rack. I am waiting on Curt to come out with a hitch. Hopefully by the end of July it will be out.
  19. 2010-V
    Pennsylvania
    I had a Saris bones when I purchased my 2010 Prius and I was unable to install it. I took it back to the local Trek shop where I purchased it, they could not install it either. I wound up selling the bones and ordered the Saris guardian which I picked up on Saturday, installed it and added two photos to my album. It's a great fit for the 2010 Prius.
  20. DavidA
    2,342
    1,818
    Chicago western burbs
    The "not recommended" might also have something to do with reduced rear visibility with your eyeballs or the rear video camera system when the bikes are mounted. The lawyers are always working on stuff like that.
    Personally, if a top hitch mfgr. has a 1½" model that's well designed for the '10 and won't necessitate the cutting of the plastic around the rear bumper, I'd do it. The convenience of a hitch bike rack is superior to messing with straps and rubber pads (which can scratch glass or paint is there's dirt or gravel on the pad). Just remember to tell the installer (or the dude quoting the install) that it's for a bicycle rack and they don't need to add the towing electrical connections.
    EDIT: Looked under the backside of the car today. Tons of plastic covering much of, well, everything. How the heck can they attach anything to the frame back there?
