Engine loses power for a split second every morning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by OldManJimbo, May 25, 2005.
  1. OldManJimbo
    OldManJimbo New Member
    California Coast
    I drive a 2001 Prius. About 6 months ago it started doing something the dealer says he's never heard of.
    After about 5-10 minutes of normal driving in the morning, the car will have a slightly noticable loss of power. It only lasts about half a second and it's never caused any problems.
    It feels as though the gas engine is turned off for just a moment and comes back on.
    Has anyone else experienced this? The dealer has used his computer and can't find anything wrong. Is there something I should tell him?
    The car has just about 70,000 miles and has been given regular maintainence.
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    big hand syndrome. Have the dealer check the throttle position sensor on the gas pedal.
  3. OldManJimbo
    California Coast
    What's a "big hand syndrome?"
    Can you explain the throttle position sensor, so I can explain it to the dealer?
  4. Frank Hudon
    4,147
    that's what the falls flat on it's face problem was called in the old'n day's of Prius owner ship. There is a sensor on the gas pedal that determins the amount of throttle opening you want. And when they fail the car flat spots on acceleration. It's fairly expensive to replace (just giving you a heads up) so have it properly inspected if this is the case.
  5. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    If your dealer can pull out the DTC (Diagnostic Trouble Code), P1120, then it is probably the Accelerator Pedal Assembly (part# 78010–47030). (Technical Service Bulletin EG018-02).
    Vincent
  6. OldManJimbo
    California Coast
    Frank & Vincent - Thank you for your advice. Do you think this might be covered under the car's warranty?
  7. tochatihu
    tochatihu Senior Member
    9,758
    3,761
    Kunming Yunnan China
    2001 Prius
    Sorry covered only for 36k miles, or under Toyota's extended warranty if it had been purchased by that same deadline.
    If the assembly is replaced, please ask to retain the old one. I would like to purchase a failed one to determine if it can be made well by cleaning the potentiometers.
    But for whatever it's worth this does not sound like big hand to me. A diagnostic code check is definitely in prder.
    DAS, 74k miles on a 2001, no big hand yet
  8. vincent1449p
    894
    332
    Singapore
    As what DAS has said, the TSB only covers 36 months or 36k miles.
    But I think it also depends on your dealer. One owner got lucky and got it replaced FOC.
    Replaced accelerator pedal (2001 Prius)
    Vincent
  9. OldManJimbo
    California Coast
    Is this something I need to take care of immediately? It seems to happen just once period day - about 5-10 minutes after starting. Sometimes a second time but that would be after the car has stood still for many hours.
  10. vincent1449p
    894
    332
    Singapore
    You mentioned that the DTC did not appear on your dealer's computer so it may not be the accelerator pedal assembly afterall. But I could be wrong.
    It seems that your problem only happens during cold start. Next time, maybe you can observe the "Low coolant temperature indicator light (in blue)" on the instrument cluster. Does it happened before, during or after the indicator lights off?
    Vincent
  11. Frank Hudon
    4,147
    unless it sets the MIL I doubt that the code would be saved. If you really want to find the code just hold the gas pedal at the spot where it sags and keep it there till the ICE quits. That will set the MIL and the code will be stored for at least several restarts. If you can do this and set the MIL take it to your dealer as soon as possible and tell them the Check Engine Light is on (CEL=MIL) The dealer will understand and the tech will be able to pull it with the THHT.
  12. OldManJimbo
    California Coast
    Well - I had my local dealer R&R the Acceleratore Pedal Assembly. And, I now have the used part. For the life of me I cannot figure out why this thing was so danged expensive. They charged over $400 plus labor to replace it and other than a small sensor unit on one end, it is nothing more than some metal, plastic and a few springs.
    But the car (2K1 Classic) sure runs nicer. Seems to have more pep and is no longer sluggish on the hiway.
  13. tochatihu
    9,758
    3,761
    2001 Prius
    As I have posted elsewhere, OldManJimbo kindly send me his failed accelerator pedal assembly (APA), and I did things to it. It is currently in my 2001 Prius and operaing correctly for 350 miles so far.
    But I have seen other posts which challenge my understanding of the entire Big Hand Syndrome. Already established is that if you have symptoms, a VIN before the cutoff, and DTC P1120 (with info codes 104-114), you get a new APA under EG018-02, during the first 36k miles, 36 months.
    However with an intermittent loss of power at highway speeds, not accompanied by any DTCs, the tech is supposed to notice TSB EG006-1. This offers replacement of the HV ECU for 100k miles (with no reference to the APA).
    I have privately emailed OldManJimbo, asking him to look into this. But it may rasie the possibility that his APA was not originally at fault.
    Can anyone comment? As I am trying to understand how (if possible) to recondition a failed APA, it is important to know if the patient I operated upon was in fact healthy to begin with.
