Brakes - Scared the SH!T Out of Me
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by disc0din0, Jul 9, 2009.
  1. disc0din0
    disc0din0 New Member
    Annapolis, MD
    Dear HippiChick,
    Thanks for your response. But what are you talking about?
  2. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    I think the key here is the "I hit the brakes" comment. I think the 2010 brakes are even more sensitive than earlier models. Overall design of Gen IV is to improve our driving skills and improve safety. I also applied my brakes firmly when I first got the new car when someone pulled out in front of me, ABS definitely in play.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    My FJ does the same thing. So did the 2000 GMC Sierra I used to have
  4. drewquant
    drewquant New Member
    Los Angeles
    My Gen II brakes were so bad I gave the car to my Mom the last gen brakes were so bad it made the car un drivable to me. Really shoddy engineering is the problem not manhole covers or road defects. The new one is much improved but still crap really. Any similarly priced German car will stop in 30% less distance at any given speed. I defy anyone to find a test that shows this differently. But in the end the fuel economy and relative green benefits outweigh the costs to me. As some owners will tell you. you just start adjusting to it and ultimately driving slower and safer which is not such a bad thing but if your in a big rush or being chased and you value your life at all take another car this is the main short coming on the cost/efficiency balance Toyota has struck
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Not that I *want* to add to this, but I did have the regen let go twice yesterday, both over bumps where wheels may have lost traction. Funny thing is the charge meter still read full despite no actual regeneration happening.
    IMHO, ECU logic should proportionately increase hydraulic pressure to maintain the same braking force. Some drivers may not react quickly enough to the reduced braking force w/ increase pedal pressure and that could make the difference in collision avoidance.
  6. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    on the Gen II your issues probably related to OEM tires.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    Again, my FJ Cruiser will behave the same way. High performance German cars will probably have more aggressive brakes anyway
    But the average Toyota, Honda, Chevy, etc, they all react about the same to braking on washboardy gravel roads, railway crossings, etc
  8. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    This is a normal function of just about every ABS-equipped car on the road. The ABS is looking for wheel lockup while your're braking. If you hit a bump or run over a chuckhole while braking, and if your wheel locks when it looses traction with the road, the ABS will engage because it thinks you might be skidding. Nothing to worry about.
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    Indeed, if you do a lot of driving on washboardy gravel roads, you're better off driving a vehicle without ABS, as it will stop a lot quicker than a modern vehicle with ABS. In that scenario, you hit the brakes, all 4 lock up, and the vehicle digs in and quickly stops.
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    yep and if gravel is loose enough... call a tow truck.
    other than an occasional spooky feeling of "no control" that lasts a split second, there is little downside. you stopping distance might increase a foot or two.
    i can cause ABS to slip on demand because i know when any why it happens, so i either steer around it or ignore the feeling when it happens.
    now, one of these days, that extra few feet of stopping distance maybe the difference in hitting someone or not. but if thats all it takes, it will be a pretty minor accident. so ya, its a trade off.
    on the one hand, i could look at a possibly expensive accident (most likely scenario would have me rear-ending someone so i would be compltetely liable) now, in my entire life, i have only rear-ended someone one time and that had nothing to do with brakes. we were at a busy intersection turning right. he was in front of me, went about 30 feet and the stopped. me being a dummy, simply took my foot off the brake to look right to see if i could follow his gap. i could have easily but he stopped. although the accident happened because he felt the 200 yard gap was not sufficient enough for him to enter traffic AND the fact that i thought a MINIMUM of 8 cars could have made it easily, i rolled into him.
    now, i have been driving a long time and maybe my time is coming
    now the compromise will be to drive a car that will save me a minimum of 2-3 cents per mile which with my driving is $400 a year just in gas.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    If the road is like beach sand, yes, otherwise, no
    The washboardy gravel road to the hobby farm, both my Prius and my FJ at 50 km/h, took about a carlength longer to stop than the old Ford work truck which would lock up the brakes.
    When a deer is spooked and jumps out, that can mean the difference between stopping in time, and hitting it
    Overall, I much prefer ABS on the highway, due to the control it provides. Nothing more exciting than locking up all 4 wheels and sliding sideways. Spair briefs mandatory
    On wet roads, you will usually stop a bit quicker than without ABS. But on dry roads it usually won't help the vehicle stop quicker
  12. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    There's a long winding downhill stretch of road from my home with a certain well-worn asphalt patch that often engages the VSC even though it's sunny and dry.
    The VSC system sometimes seem almost overly cautious....
  13. bredekamp
    bredekamp Member
    569
    I owned an E32 7 series BMW before my Prius. I once stomped on the brakes SO hard a hydraulic hose popped off the reservoir holding the hydraulic fluid for the brakes. Fortunately I was still near my home so returned and fixed it. I can't remember what I braked for...
    "I brake for Elvis, cats, children, nuns and other Prius drivers":rockon:
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    true true which boils down to the fact that ABS was designed in a lab setting with a controlled environment and that is where it works best. in a setting where the coefficient of friction is constant, it works very well.
    now when that coefficient of friction changes suddenly, ABS has more than enough time to recognize that, but momentum and the inability of the mechanical system to react quick enough is what causes the slips.
    so it takes a bit for the system to readjust, but i can live it
  15. jim256
    jim256 Member
    317
    69
    Eastern NC
    I'd counter that there may be occasions and drivers for which that is true, but unless the driver is skilled and can maintain threshold braking to the point of lockup until stopped, irrespective of surface material, I'd go with ABS any time. I took the Accident Avoidance course twice at Summit Point in the days before ABS was common and we spent hours just on threshold braking (modulate with just some press & release movement of your toes), and I doubt the average, or maybe even above average driver (like we all are :rockon:), can duplicate ABS performance and the ability to steer around the obstacle. Once you lock up you're toast, and steering is not an option.
  16. qbee42
    3,081
    Do you really mean VSC? VSC deals with loss of directional control, such as skidding in a corner. This thread is talking about brakes, which are unrelated to VSC other than being used by the VSC system to help regain control.
  17. bredekamp
    bredekamp Member
    569
    I knew that...:rolleyes:
  18. accordingly
    accordingly Member
    268
    63
    Madison, WI
    That's no opinion, it's a fact. Brake pedal halfway down should always apply the same braking force as having break pedal halfway down, and it certainly should not change while the pedal is already depressed just because you drive over a manhole cover.
  19. qbee42
    3,081
    How would it do this when traction has been lost? The hydraulic brakes do come in with the same braking force when regeneration stops, but traction has already been lost on at least one front wheel. The front wheels supply the majority of braking force on any car, so losing traction on a front wheel is going to hurt your braking distance.
    Looking at your statement from another side, would you expect the brakes to stop in the same distance if you are on ice? Without friction brakes are just an ornament.
  20. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    The feature's called brake assist. Besides on the Prius, it's standard on many ABS equipped cars. Even my 02 Nissan Maxima had it (the first ABS equipped car I owned).
