EV button - what's the point?
Discussion in 'Gen 3 Prius Main Forum' started by nemrut, Jul 24, 2009.
  1. nemrut
    nemrut New Member
    57
    san francisco
    ..it seems more like a marketing gimmick than serving any useful purpose. As long as there is enough battery power, the Prius is automatically powered solely by the battery at low driving speeds 20mph+/- which is the same threshold when manually engaging the EV button...so what's the point?
  2. Radon
    Radon New Member
    120
    Vancouver
    You can delay the engine starting so silently leave an area if noise is an issue.
  3. wave_slider
    wave_slider New Member
    201
    26
    the aloha state
    When you are in EV mode you can push a little harder on the pedal than you could in non-EV mode. If you aren't in EV mode and you get the Hybrid indicator bar beyond halfway the ICE will kick in. In EV mode you can push beyond halfway and accelerate a little quicker provided your battery charge is sufficient.
  4. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Buyers in North America wanted it. So much so they were adding the switch for it to their Gen II Prius. The function(not a feature) is already built into the operating system and was available to the rest of the world. No gimmick it's just a manual switch to allow fixed ev mode. You can also switch to eco and pwr and the "null" switch for normal. No big deal really and will be rarely used by most people.
  5. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    For the average driver interested in average (for the Prius) fuel economy, there's not too much point in it, other than perhaps to show off to friends how quiet the car is tooling around the parking lot.
    For some of us obsessed with fuel economy, it can make a significant difference when used properly in the right driving conditions. See this for more.
    2 people like this.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    I use EV to keep the ICE off while I get away from my house and my neighbour's bedroom window when leaving for work at 6AM. Also to move quietly through carparks, and my engine never runs in my garage. I don't use EV often but I like having it.
  7. wave_slider
    201
    26
    the aloha state
    Me too.
  8. dsviv
    dsviv Member
    170
    Eastern PA
    I have tried several times to activate the EV mode by pushing the button. Each and every time, I accelerate very slowly and at approx. 12mph it flashes a window that says the EV mode has deactivated. btw, there have been 7 battery bars each time. What's up with that?
  9. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I might be wrong but I the reason it's there is because the 2010 was designed to be a PHEV (Plug-in Hybrid Electric Vehicle) even though they delayed the launch of that functionality. As I recall there are some fleet ones that are equipped as PHEV's being tested around the world. It makes perfect sense to have this button on a plug-in.
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'd call it the "impress your non-hybrid owning friends button" as I think it's biggest draw is pressing it at the airport parking lot as you drive away to impress the friend who's never ridden in a Prius before.
    Functionally, it really has little value. From a marketing standpoint hey 3 modes are better than two.
  11. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I use EV to keep the ICE off while I get away from my neighbour's bedroom window when leaving
    LOL, is this what you guys really meant? That's the only real value I can see in it.
  12. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Mine also cuts out due to excessive speed at 12 mph with a "full" battery but it only does this when the ICE is cold. Once warmed up, I can always get up to 25 mph before it cuts out.
  13. StevieB
    StevieB New Member
    34
    Southern California
    This does not work for me. When I start my Series V after it has been sitting for 8 hours or so (either overnight or after work), it always starts-up in electric mode (or certainly in quiet mode), but then the ICE kicks in after 30 seconds or so. So I don't get the "delay the engine starting" comment.
    Regardless of battery charge level, I cannot get the car into EV mode (via the button) until after the car is driven for a minute or two or more.
  14. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    As people have said, it's a niche use. I mainly think of times on summer vacation when it would have been nice when leaving early or arriving late with lots of tents or open windows around.
    It's not quite as useful as the old days of V-8's though. I can remember starting cars, like an old-school Chevy Malibu, early in the morning and feeling like the whole world could hear you.
  15. Tideland Prius
    16,492
    - moving around underground or enclosed parking lots
    - moving the car in/out of the garage
    - moving the car to another parking spot
    - shutting off the engine on the last stretch home (no need for the engine to keep warm if it's the last run of the night)
  16. billnchristy
    billnchristy Active Member
    924
    123
    GA
    2016 Chevy Volt
    I was personally very impressed by how powerful it is. I use it to cruise in the neighborhood but most of the time use my foot to do it manually instead of hitting the button.
  17. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    In my experience, the EV switch is worth something... but just how
    much is highly dependent on driver self-discipline and the particular
    drive/commute route.
    I installed my EV switch because I just couldn't believe something that
    seemed so cool could only produce the limited efficiencies that were
    reported here... call it basic research. I've had the switch installed for
    more than a year, that is to say through both warm summers and cold
    winters.
    Well, everyone was right: the EV switch is not the proverbial FE/MPG
    "silver bullet."
    In warmer times when the ICE and catalytic converter warm up in a
    few minutes, the only use I've found for the EV switch is very short
    runs imediately after the car is started -- backing out, and
    immediately a 90 deg turn all at speeds less than 20 MPH.
    Oh yeah, and the occasional ego-stroking to keep the neighbors in a
    state of confusion as to whether or not the car is hybrid, or PHEV, or
    full EV. Evil... but fun! :D
    But even here, getting into and staying in EV mode at start-up is not a
    gimmie. You have only three or four seconds after you hit the Start
    button to make the transition. So, get all all the little getting-ready-to-
    drive details out of the way before you hit the Start button. This would
    include seat belts, parking brake, wiping windows, whatever. In my
    experience, once you hit the Start button and the Ready light comes
    on, you have but two or three seconds to engage EV mode AND start
    the car moving. If you miss this, the HSD will revert to normal
    operation and the ICE will come on and start the warm-up cycle.
    Colder months are a wholly different matter. At these times the EV
    switch can be a major element in recovering MPGs greatly reduced by
    longer warm-up times/distances. (I do grill blocking, but no block
    heater in colder months.)
    A necessary aside: There are so darn many tricks and kinks to getting
    really good MPGs that I get confused. So I try to distill things to broad
    "rules" that are applicable in my mostly urban driving environment at
    Posted Speed Limits, PSL, up to 40 MPH.
    Some of mine are:
    * Gas burned when the car is standing still is gas wasted.
    * Gas burned to maintain speed, at constant velocity, is acceptable but
    should be minimized consistent with safe driving.
    * Gas burned to accelerate to PSL, or PSL + a little, is gas well spent
    as then I can pulse & glide.
    * Pulse and glide produces ~50 MPGs if the glide is 4 times the
    distance of the pulse (constant acceleration). Pulse and glide at 6x the
    pulse distance gets 70+ MPGs. In my experience, this holds more or
    less true at target speeds between 25 and 40 MPGs.
    Back to EV use in colder months -- well, cold but not really cold -- lets
    say 30-45 degF. (One of the necessary conditions to get into EV mode
    is the HV battery can't be "too cold." Exactly what that means, I'm not
    sure. But I do know that after an overnight "cold soak" at 30 degF
    outside temps, the HV battery is "too cold.")
    The best use of the EV switch/mode is to suppress the HSD trying to
    keep the ICE turning over and using fuel when the car is at a stop, or
    to get into a no arrows glide below 34 MPH (Gen II) in EV mode when
    the HSD won't allow it in the warm-up cycle. But even here this
    practice is conditional; you have to have above ~110 degF ICE block
    temps... the ScanGauge is a very useful tool.
    In summary, Is the EV switch "worth it?" Definitely maybe. Properly
    executed, I can realize 5-8 MPGs with very careful use of the switch in
    my 28 mi. round trip commute. For somebody else... I don't know.
    Also, in colder weather if you want highest FE/MPGs you must
    drive through the entire ICE warm-up cycle without using the cabin heater.
    If you use it you divert heat from heating the block and extend the
    time/distance to fully warmed-up. One benefit of using the EV switch
    is that in keeping track of all the conditions and details you are
    distracted from realizing that your feet, hands, nose, and ears are
    going numb. :eek:
    As is so often the case, beauty, or in this case usefulness, is strictly in
    the eye of the beholder. :rolleyes:
    Hope this helps.
  18. 60MPG
    60MPG Junior Member
    24
    38° 53′ 42.4″ N, 77° 2′ 12″ W
    I prefer my ICE cold ... :rolleyes:
