2010 Is there mouse or mice screening?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nugget, Aug 5, 2009.
  1. nugget
    nugget New Member
    17
    Okanagan, BC
    Thanks to people on this forum, I have taken off the wipers and screened the air con intake, and have screened two air vents off the spare tire area in my 2005 Prius. I hope this is the end to mice trouble. I've caught more than a dozen over the past 14 months. I am sure there is a rodent urine roadmap well established that says, "Come this way guys."
    Anyway, a lot of forum people have criticized Toyota for not spending pennies for screening. I know it has taken me hours to fix what could have easily occured in factory.
    Question: looked under the hood of a 2010, but could not see if there is now screening for the air con intake. Does anyone know if Toyota has improved this problem in the 2004-09 Prius?
  2. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I don't know, but mice will absolutely wreck you electrical system. They chew on wires.
  3. syncmaster
    syncmaster Member
    229
    I just got my 2010 a couple of days ago.
    looking at the front under the wipers it looks like they closed off the side entry point with plastic but I am not sure it is closed off tight enough... I will take it apart in a week and take a closer look.
    The back mouse entrance is still there, both sides behind the battery and on the opposite side. maybe there are no mice in japan or maybe they are so big they couldn't squeeze thru the vent opening.
    Anyways I will have to mouse proof another prius.
    Thanks TOYOTA for giving me something to do.
  4. nugget
    nugget New Member
    17
    Okanagan, BC
    Thanks Syncmaster for taking the time to reply, and understanding the agony of the problem. Doesn't affect every Prius owner, but it has been a major pain for me here in farm country.
    I hope you can let us know if there are improvements at the front end, the pathway into the air cond. intake. That was the biggest pain to do (properly) in my 05. The back vents (right and left of the spare tire) were easier in my opinion.
  5. syncmaster
    syncmaster Member
    229
  6. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    on my 04 impala they got up in my air filter and chewed it up, but gm installed a screen between the air filter and the intake witched prevented costly repairs because it held back all the little peices of filter. Does anybody know if the prius has a screen like this?
  7. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Try to PM Hobbit who has pics of my Gen III front cowl disassembled. It looks like mice could still enter. Good news is that the means to close off the interior from the cowl seems to be an easy fix. Bad news is that cowl really collects crap and could hold an extended mouse family.
    Wayne
  8. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    The 2010 has a single A/C intake opening that is completely
    accessible once the cowl is out. I will try to get that set of
    pictures [mostly concerning EBH installs] dealt with soon, which
    I think shows this. Where sealing up the air intake in an Iconic
    is almost impossible due to the dual-layer way the firewall/cowl
    area is designed and how it feeds out to under the front quarter
    panels, it looks much more doable in the 2010. I haven't looked
    at the rear outlet vents yet but I suspect they're the same simple
    light rubber flaps [that don't do squat to keep out critters].
    _H*
