Battery failures
Discussion in 'Gen 2 Prius Technical Discussion' started by KarenBez, Aug 9, 2009.
  1. KarenBez
    KarenBez New Member
    Chicago, IL
    I have a 2005 Prius with 34,000 miles. A few weeks after the 30,000 maintenance, the small regular car battery failed. Now 2 months later, the large hybrid battery has failed. Coincidence or could there be something wrong causing these failures?
    Thanks
  2. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Large hybrid battery failed? You have confirmed this or someone is fooling you around? :eek:
    As for the small 12 Volt battery, the time is now right - being 4 years old, to go bad. There are lots of discussions here on the Prius Chat regarding the latter and how to replace it cheaply and/or efficiently with better designs, like the one from Optima.
    As for the hybrid high voltage battery failure, 30.000 miles is definitely premature. In any case, should be handled inside 8 years of hybrid components warranty.
    Ogo
  3. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    I agree with Ogo in all regards: the 12V is about due to expire (I'll likely replace mine as a preventive maintenance measure before winter), the hybrid battery is not, and if it has it should be replaced under warranty. And I also wonder what led to your conclusion.
  4. spitinuri
    spitinuri Member
    317
    This is very unusual. I assume that this is confirmed by a Toyota Certified Mechanic. If true it is a warranty issue and Toyota should replace it for free.
  5. richard schumacher
    7,686
    1,068
    United States
    Karen, please let us know what diagnostic codes were found by the dealer.
  6. KarenBez
    KarenBez New Member
    Chicago, IL
    The hybrid battery failure was diagnosed by the Toyota dealer repair shop. They have installed a new battery and I will pick it up today. I'll ask about diagnostic codes.
    It is covered by warranty so that's not a problem - it's just odd that both batterys failed in a relatively short time and that the hybrid battery failed at all.
  7. KarenBez
    KarenBez New Member
    Chicago, IL
    I spoke to the dealer and they gave the following diagnostic codes that they used:
    P0880
    C1241
    C1242
    P3000
    He also mentioned B2775
  8. richard schumacher
    7,686
    1,068
    United States
    Hmm, they all indicate battery and voltage related problems. I can only guess at the ultimate cause. You may indeed have had a traction battery failure by sheer coincidence and bad luck, but at least in that case there should be no more trouble.
    Was the car ever in an accident, or driven after running out of gas?
    If there are ever any other problems without obvious causes I would suspect the inverter.
  9. KarenBez
    KarenBez New Member
    Chicago, IL
    No accidents or driving after running out of gas. Thanks for the comments. If I have any other problems, I'll keep you posted.
  10. Patrick Wong
    18,210
    6,526
    Hi Karen,
    Thanks for providing this info. Can you pls look at your repair invoice and list the part numbers and descriptions of all replaced parts? I am wondering whether the traction battery ECU was replaced...
    Looks like you drive your car ~7K miles per year - do you drive the car daily; or do long periods of time pass when the car is not in use?
    Does your commute require significant elevation changes?
    Do you tend to have many short trips (say 3 miles or less)?
  11. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Karen,
    Welcome to PriusChat!
    You've provided very valuable (and rare) data, and I appreciate that you've been so helpful in sharing the entire experience (including the diagnostics).
    Just as valuable to our community will be your continued involvement and periodic reporting on your car's performance. For instance, are you able to compare your fuel economy before and after the HV replacement? Can you (will you) notice other changes in performance -- on any measure you choose?
