Anyone's battery ever go PURPLE?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nan, Jun 1, 2005.
  1. Nan
    Nan New Member
    suburbs of Washington, DC
    THE SCENE: Crawling slowly along in my 2005 Prius in a typical DC traffic jam, outside temp around 72 and sunny, AC on.
    THE HORROR: Suddenly I see something never seen before in four and one-half months of ownership, 5000+ miles: PURPLE LINES.
    What my six year old son calls "the video" shows aux battery apparently nearing drainage point, lines are colored PURPLE, and only 2 lines left.
    THE RESPONSE: Shut down AC thinking this might help. Continue crawling slowly forward as highway crew shuts down 2 of 3 lanes at early rush hour (good thinking, guys!). Aux battery display remains a sickly white with 2 little purple lines, just barely breathing. Engine refuses to give mouth to mouth. Even our little downhill crawls don't help (is 2 mph too slow to create enough friction??). There are NO green arrows. The engine plays dead, or at least asleep.
    Eventually we do reach our destination (brand new Trader Joe's), though in the entire 20 minutes till I pressed "park" I never once saw the engine kick in. When we re-emerge armed with groceries and start up, all is fine once more; the aux battery appears refreshed by its rest period in the parking lot.
    Any similar experiences or insight will be appreciated!
    Nan
  2. Tideland Prius
    16,504
    Well rush hour traffic will burn the battery down to the pink bars. Based on what you wrote, it sounds normal. You'll be surprised how quickly it'll charge back up to half battery
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    [font=Comic Sans MS:d0422cdc7b]Hi Nan. The battery on "the video" is the High Voltage traction battery, not the puny 12 volt auxilliary battery. The 12V battery just runs the lights and the radio (and video) and boots the computers so they can control the ICE and charging. There is no easy way of telling the level of charge of the 12V battery.
    I figure this car is so smart, it will take care of itself; I shouldn't have to worry about coddling it. If it doesn't take care of itself, that's what the Toyota Roadside Assistance and the warranty is for. Next time, keep the AC on. Aren't Trader Joe's great?
    BTW, I think the colors of the battery may be affected by the color screen you choose. I haven't tested to be sure. I changed my day screen to gray from green because I like it better. I think other screen elements may change to match the background theme.[/font:d0422cdc7b]
  4. john1701a
    john1701a Prius Guru
    12,805
    5,291
    57
    This is the very reason Toyota chose not to include much beyond the basics for the Multi-Display. They wanted to empower owners. But brand new knowledge can be scary. It's sometimes better not knowing, because the natural tendency is jump to the wrong conclusion... which you did.
    Even if all the bars disappeared, you'd still have a decent amount of battery-pack power left. The display only actually shows you the middle range, the part most commonly used. There's still more beyond that.
    Prius is smarter than you give it credit for too. It will protect itself from ever deep-discharging (as long as you have gas available). The worst that could actually happen is your MPG will take a dip, since it will simply run the engine more. So you can kick back and enjoy.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Can't tell you how many times people have posted like this. Just leave the car in Drive or Park (depending upon circumstances) and the ICE will charge the battery when it has to.
    Ironicly, if you'd have cranked the AC to MAX COLD it probably would have been enough to turn the ICE on. There was no danger, no problem, and no risk....this is a beautiful feature of your Prius--it created no emissions, at all, while you were crawling along in traffic...while everyone else was spewing away.
    And yes, 2mph is too slow to regenerate. Regeneration stops completely below 8mph...in fact, if you don't have the brake completely depressed below 7mph the car will actually put a little power to the wheels (from MG2) to keep it from rolling backward.
  6. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Refreshed as in blue bars, not pink, as soon as you started the car? That would be VERY odd unless you left the car in Ready mode instead of powering down. The ICE will start at some point to recharge the battery if the computer decides it needs more charge.
    Isn't it great that the Toyoota programmers were able to let the car figure out that 2 MPH wasn't enough of a drag on the battery and instead of polluting (even at the 10% Prius level) by running the ICE to keep you moving, it continued to use the electric motor?
    I guarantee you that if the traffic had magically lifted and you were able to go back up to 40 MPH or whatever, the ICE would have started.
  7. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    It's often hard to tell when ICE kicks in. Sometimes it only runs for 10 or so seconds when it is on the 2 bar threshold.
  8. Nan
    Nan New Member
    Thanks guys! I'll never sweat the battery display again, no matter how anemic it may appear!
    I apologize for writing "aux" battery when I meant hybrid. I plead caffeine deprivation (I posted late at night). 'Twill never happen again.
    Yes I do love not spewing fumes while stuck in traffic. I never before "loved" a car. It was always just a way to get there (OK so maybe the vintage Austin Healey roadster was about the journey). Now I'm a proud if still woefully ignorant enthusiast.
    My only reservation is - can't find any way to run fan without "air conditioning". I've never been enamored of A/C, though I'll admit it has its uses around here in July and August, when the D.C. Wetlands reach 98% humidity. But when the weather is fine I prefer UNconditioned air. Can't keep windows down whilst doing 70 on the Beltway - my wig will fly off. Want a fan. Thoughts? Or, wait for the next major redesign?
    Finally - yes, the battery really recovered on its own (without any ICE assist). When I parked at the grocery the Prius was, as I said, down to two stripes (purple on my display). I did indeed power down (I know because it agreed to my remote 'lock' command). So it wasn't sitting there regenerating off the ICE while I was picking up my red pepper hummus. Yet, 20 minutes later, when I came out and hit Power, up came a battery with just over 50% on the display. I have no idea how it regenerated itself at full rest, but that IS what happened. I swear. Why do you think I wrote to you guys in the first place? It seemed sort of Twilight Zone-ish to me!
    Nan
  9. efusco
    19,891
    1,196
    Nixa, MO
    To get the fan without AC takes a bit of Zen...but you can get it.
    I prefer to run the fan at MAX Cold temp setting in summer, MAX Warm in winter...you get some passive heat that way in winter and cooler external air in summer.
    So, go to the Climate screen. Touch the AC button to turn it off. Now scroll the temperture down to MAX Cold. You'll note that the AUTO setting is still on and the fan will crank to the maximum high rate. At any time after you start changing the temperture setting (or when you're done) touch the fan speed button you want.
    Voila! The AUTO button will dim, the fan will be on the speed you set it, the AC will be off. What could be easier?? A single "VENT" button to push you say? ...don't be silly what would be the point of that when you can get the same thing in 8 easy steps?? ;-)
  10. Bill Merchant
    4,096
    85
    [font=Comic Sans MS:122d8c83b3]Hi Nan. To have the fan run without the AC, hit the Climate button by the display and then the AC soft-button on the display. If it has a bright bar (yellow on my display) the AC is on, if the bar is dull, the AC is off. You can also set the fan at a specific level or just let the Auto function try to keep up with the heat.[/font:122d8c83b3]
  11. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Now that it's warmer here, stuck in traffic, 1-3 bars is very normal with the A/C on.
    About the only way to see all bars and green is to move here in January so at -40 the ICE runs constantly. Trust me on this: it's *not* worth it!
  12. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    2 bars is still plenty and the colors just reflect the level of the battery and shouldn't alarm you in any way. I've gotten down to zero bars going up a mountain to a ski resort before, and at that point it's all engine. Once the load is off (no longer going uphill or slowing down on my uphill climb), the battery happily recharges.
  13. Nan
    Nan New Member
    Thanks to all who gave guidance re how to get ventilation w/o A/C. Prius manual wasn't much help. You guys are terrific! So glad I found this forum. Cheers!
    Nan
  14. Tideland Prius
    16,504
    Wow! zero! Never gone below two, or above 7 =).
    Maybe I should try the manual climate control one day. I'm so used to auto. =S
  15. senna4ever
    senna4ever New Member
    78
    Stupid 2010 Olympics
    My battery indicator has never shown a full charge in the week we have owned the car. It's always 2 bars short....is this normal in city driving?
  16. NuShrike
    NuShrike Active Member
    1,378
    I've noticed the battery display sometimes "lags" reality. Like if I come off the freeway and come to the stop, the battery bars are blue. If I flip the display to something else and back, the battery bars are now green.
    I've experienced this a few times, and I believe this is what happened to you.
  17. 8AA
    8AA Active Member
    550
    62
    Maryland
    This is completely normal. If you want to see the battery completly full on the display, you'll have to coast down a long hill. Also, keep in mind what John said about the display; the battery on the screen actually represents the middle range of the battery's state of charge. With all the bars lit, I believe the battery is only 80% full, and when it's totally blank, a 40% charge remains.
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    The only time you may see "full" charge in city driving is here in Winnipeg in January at -40. The ICE will never shut off.
    OTOH temps +75 F or higher with the A/C on, 1-2 pink bars are normal too. Don't worry about it.
  19. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    It is true, I see green more often in the cold depths of winter. Really mentally painful to be sitting at a signal in the morning 2 minutes from my house with 7 green bars and the engine running!
    I know, it wants to be warm. It is a lot harder to get it into electric mode when it is really cold outside so the battery isn't used as much.
    I know what you mean about wanting a 'vent' button. I usually hit A/C button, then the fan speed to cancel auto before I set the temp to max cold so the fan doesn't go way up.
    And why doesn't the nav lady understand MAX COLD??? It is faster to just hit the temp down button on the steering wheel than wait for the voice recog to come up, say 65 degrees, then push the temp down button once.
  20. sacker1177
    sacker1177 New Member
    Walla Walla, WA
    We have had our 2005 Prius for several months now. We recently took a 2,000 mile trip from WA to UT and back. During our trip down, we had been driving all day at highway speeds up to 75 mph. later, we were pulling a hill to a 7300 foot summit and we went down to one battery bar before hitting the summit. We were fully charged by the bottom of the other side. We had no problems the entire trip. We got down to two bars several times but quickly recharged. I'm curious what would happen under these heavy load situations where both motors are employed simultaneously for extended periods of time? The ICE can't charge much when it is trying to maintain speed on a hill. If the battery were too low to maintain the electric motor contribution, I assume the electric motor would stop adding power until the ICE could provide support to charge the battery.
