Looking for advice
Discussion in 'Gen 3 Prius Main Forum' started by snoctor, Aug 9, 2009.
  1. snoctor
    snoctor Member
    126
    27
    Davis, CA
    I currently have an '05 Corolla and have gotten 38.5 mpg over the lifetime of the car but want to do better so I'm considering purchasing a 2010 Prius. I have 3 questions about the car and some of the options and was hoping that you might be able to help me out.
    1. Luggage space: What is the actual luggage space in the hatchback with the back seats up in place and not counting the small space under the floor? I can fit two large suitcases and one carryon plus some extras in the trunk of my Corolla. I've read that the Prius has about 2 extra cubic feet of space in the hatch compared to the trunk of the Corolla, but does that figure include the storage space beneath the floor? I haven't found any pics of the Prius hatch loaded with items to give me an idea how much fits back there. This is going to be a family car (wife and 9 month old baby) so we occaisionally need to carry around stroller and all sorts of things. I might take an empty suitcase with me to test drive the Prius to get an idea of how much space it has in comparison to my Corolla.
    2. Navigator: I'm looking into the Navigator option, but from what I can learn (I test drove a model without Nav) the Navigator only shows roads with a map perspective (from above) and not in streetview. I have a TomTom and prefer to use the streetview option. I watched one demo model with the navigator set so that your direction is always pointing up on the screen. It seems that with that option chosen the map swings all over the place (if you're on a curvy road) to keep your direction pointing up. Is that disorienting? Seems it could be if you're not familiar with the roads you're driving on.
    3. iPhone: How do the phone functions work? Is the Nav package the only way to get phone functionality in the car? What about music playback? Do you have to open playlists or podcasts on the phone and then you can listen to them through the speaker system?
    Thanks for you feedback.
  2. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    1) with the seats up and not blocking the view thru the window I would rate the luggage capacities about the same. However if you carry a large stroller check the width. Putting it in at an angle will eat up a lot of space. We carry an unbrella stroller for our grand daughter and it fits nicely towards the rear of the car but would have to go at an angle if pushed back towards the seatback.
    2) I like the driving up mode as it corresponds with what you're seeing as you look out of the front window. Change the scale and the map won't move around so much
    3) I only have an iPod Touch. It works well with bluetooth but I plan to add the new interface soon when I go in for my first service.
    2 people like this.
  3. Holmesman
    Holmesman Junior Member
    63
    Largo, FL
    By the press of a button, you can switch to North Up Mode, which turns the car, not the map. The map is always displayed with North Up so you do not have that disorienting swing.
    My wife prefers the map swing. I hate it and turn it back to North Up when she leaves the car!
    2 people like this.
  4. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Wow! That's pretty impressive mileage. That's almost 25% higher than the EPA numbers for a 2005 Corolla (assuming it is a 5-speed stick). I don't think you can rely on getting 25% higher than EPA numbers for a 2010 Prius; that would get you to 62.5MPGs!
    There will be nothing better for you than to take items you'll usually pack and move them directly from the Corolla's trunk to the Prius. According to the EPA site, the 2005 Corolla has 14cu.ft. of luggage space, while the 2010 Prius has 22cu.ft. I don't believe this includes the space below the floor of the cargo area, but it may include the space above the tonneau cover. They advertise it as large enough for 3 golf bags, but I'd say they'd have to be 3 very large golf bags to use all of the space. I've noted in another thread that I've packed two large golf bags and one small one, while I've also had two large lawn chairs (folded into their rectangular bags) and other assorted items -- all underneath the tonneau cover.
    There is no "streetview" option, but you do not have to have the view so that the direction of your car is always in the "up" position. You can set it that way or with North in the "up" position. I like to use the split screen mode where the left is North "up" with a larger perspective and the right screen has the car's direction "up" and shows only the couple of blocks around the car.
    The iPhone works well with the built-in bluetooth handsfree system. Also, I really like the sound quality and convenience of using the bluetooth system for streaming audio. You need to update the operating system to OS 3.0 for this to work. The only shortcoming is that you cannot use the controls on the steering wheel for the audio (excepting volume and choice of source).
  5. nineinchnail1024
    nineinchnail1024 New Member
    280
    40
    New Orleans
    1. The prius has MUCH more luggage space in the hatch than the corolla has in the trunk. My sister-in-laws corolla can't fit nearly what I fit under the hatch of the prius.
    2. Factory nav sucks (please don't flame). Not just on the prius, but on pretty much every car I've ever driven with nav. For the money, a garmin or tomtom is a MUCH better option.
    3. I don't have an I-Phone, but my blackberry connects perfectly without nav and I use voice controls for pretty much everything.
    P.S. If you average 38mpg in the corolla, then I wouldn't be surprised if you could get close to 65 mpg out of the prius. Go for it!
  6. snoctor
    snoctor Member
    126
    27
    Davis, CA
    Thanks for the feedback, that's helpful. I've been wondering about how the luggage space is calculated. Not that it's that important, but I've read in some reviews that the cargo space is 22 cu.ft, and in others it's listed as 15.7. I suppose what's more important for me at this point is how the space compares to my current car, and from your comments and others it's quite a bit better.
    "According to the EPA site, the 2005 Corolla has 14cu.ft. of luggage space, while the 2010 Prius has 22cu.ft. I don't believe this includes the space below the floor of the cargo area, but it may include the space above the tonneau cover."
  7. LoraJ
    LoraJ Active Member
    507
    68
    2018 Prius Prime
    I have a 2003 Corolla and I was really impressed with the space in the 2010 Prius hatch when I had my test drive. I'll be able to compare better once I transfer all of my crap into our new Prius in a few weeks.
  8. JasonPro
    JasonPro Junior Member
    72
    Rockville MD
    I'm with you on North Up. I think north up promotes learning your way around local roads without the gps. After driving around an area for long enough you'll have the image of the local map in your head. I don't think that'd be as easy if the map was constantly shifting around. At least for me, I think the shifting map would just make me more dependent on the gps.
  9. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    Regarding the luggage space. We just took a 9 hour (one-way) trip last week with our family of 4. Behind the back seats we had: 2 pieces of luggage (that are maximum carry-on size), a duffle bag, 2 laptop backpacks, a pillow, and a medium sized cooler.
    The view out the back was the same as with the cover on, but the luggage was just a bit too high for me to keep the cover attached.
    I managed to pack 2 large (12x15) scrapbooks, a box of photos, a bag of scrapbooking supplies, and 2-12 packs of soda in the compartment below!!
    My family was amazed at how much my new Prius could carry!! :)
  10. smurfpotter624
    smurfpotter624 Junior Member
    29
    17
    Grand Rapids, MI
    The JBL 6-disc, 8-speaker radio that comes standard in the III, IV, and V trim levels includes bluetooth for your phone (note, however, that it does not include the bluetooth streaming audio feature).
    Some advanced functionality is included when upgrading to the Navigation Package.
  11. HolyPotato
    HolyPotato Junior Member
    92
    Toronto, Ontario
    I'm not 100% sure, but I believe that the 15.7 cu.ft. measurement is everything behind the backseat, under the tonneau cover (i.e.: including under the floor, but not blocking visibility). The 22 cu.ft. measurement is everything behind the backseat up to the hatch glass, AFAIK.
