2007 Prius Remove FOB From ECU
Discussion in 'Gen 2 Prius Technical Discussion' started by imgodot, Aug 18, 2009.
  1. imgodot
    imgodot New Member
    Camarillo, CA
    Hello,
    We just bought a used 2007 Prius, but it only came with one fob.
    We are planning on buying another SmartKey fob and getting it programmed for our car, but I'm a little worried.
    Based on a VIN check, it appears that the car was repossessed two years ago then the dealer got it through a dealer auction.
    My worry is that if the original, disgruntled owner can track down the car they can steal it from us with no trouble whatsoever.
    My question is: If a Toyota dealer is programming a new fob for the car ($140 from our local dealer - OUCH!), do you think it would be difficult (therefore, expensive) to have the missing fob deleted from the car's (ECU) memory?
    I will be asking the dealer this question as well, but I'd like a sanity check from someone with no monetary stake in the outcome.
    Thanks.
    -- Paul
  2. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    You might try a search for "delete sks fob".
  3. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    But the answer is yes they can. Shouldn't cost you extra if they do it while programming the new fob into the system. It -may- have already been done when the car was repossessed (if the dealer was awake!).
