How to kill your Prius mileage (and your Prius?)
Discussion in 'Gen 2 Prius Main Forum' started by MattFL, Aug 28, 2009.
  1. MattFL
    MattFL Member
    187
    55
    All I can say is WOW. I'm in FL and the Prius tag was CA, he was headed North, I wonder how far he'll get before the poor little Prius melts down? He was sustaining 65mph! Super kudos to the Prius engineers, I'll bet this was way way outside their expected use case! Wonder what this does to your mileage? ;)
  2. essaunders
    essaunders Member
    195
    NH
    I could see towing the very smallest of the uhaul trailers
    but a 5x10 (or is it a 6x12?) is way too big...
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    That's insane! Around here, the U-Haul dealers have a chart of what they allow for towing their trailers.
    There is no effing way I'd risk +$4,000 of inverter/converter and cvt to save a few bucks towing a trailer! I'd rent a pickup, eat the one way charge, and be done with it
  4. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    That looks like a Pennsylvania tag on the trailer. I hope they are going eastern half (Philly) area rather than the western side (Pittsburgh). If going to the west the hills through WV are going to crush that poor little Prius if it isn't in enough pain already.
    Hopefully, the owner of this insanity is a PriusChat member and will report back but I HIGHLY doubt it. I think if they were this probably wouldn't be going on right now, LOL.
    Chris
  5. Tad Moody
    Tad Moody New Member
    35
    Duarte, CA, USA
    I'd love to see what's in the U-haul
  6. qbee42
    3,079
    His SUV.
    2 people like this.
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    OMG...that's just crazy. Watch, they'll be on here whining about how their transaxle blew out at 30k miles and the Prius is a POS.
  8. ganglo
    ganglo New Member
    Franconia, VA
    You have got to send this to failblog.
  9. drees
    drees Senior Member
    1,782
    247
    Whoa - conceivably on flat roads if the guy is really careful they could pull that trailer at low speeds, but I see a number of things wrong:
    1. Hitch/trailer is totally not set up right. Easy to see that the hitch is way too low (even accounting for the sag).
    2. Loaded WAY too much weight in the front of the trailer. There should be just slightly more weight on the front of the trailer. If the vehicle towing sags significantly, you've either loaded too much weight in the front or too much weight total.
    3. Following WAY too close to the vehicle in front (assuming 65mph). That's a marginal follow distance for an empty Prius (probably about 1 second). With the amount of weight that appears to be in that trailer, they should be following at least 2-3 times farther behind.
    4. 65mph is WAY too fast even without considering all the above. Should keep the speeds to 55mph max.
    This pic kinda reminds me of that picture of the Jetta overloaded with plywood and concrete so badly it was scraping in the back. Now this isn't quite that bad, but it's getting close!
  10. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    A picture of a Honda, I believe it was, made the rounds of the 'net a few years ago, It was roof-laoded with lumber and was sitting belly-down on the pavement - the struts had come through the fender tops!
  11. dogfriend
    7,512
    1,189
    Carmichael, CA
    LOL. Uhaul won't rent you a trailer if you have a Ford Explorer (because they got sued once), but they will rent a two axle trailer to a Prius owner. :madgrin:
    Uhaul is Stupidâ„¢.
  12. richard schumacher
    7,664
    1,045
    United States
  13. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    All good points to remember. Is this the picture you were thinking about?
    In addition to the lumber on the roof, he had 10 80-pound bags of concrete on the back seat and a passenger!
  14. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    People have towed reasonably substantial trailers with Priuses
    in the past, and even documented it here. Why does anyone think
    it's that much more stress on the HSD under steady-state running
    that the owner is likely to "blow up" a transaxle? Unless the
    trailer has its own brakes I'd be more worried about stopping
    that rig, not going, and thus agree about the following distance,
    but what's happening there is certainly not mechanically infeasible
    or as unwise as you're making out.
    Torque can be manufactured, you just don't go as fast. Ask yourself
    if any loaded semi chuggin' up a mountainside in WV is about
    to blow its engine...
    _H*
  15. efusco
    19,891
    1,196
    Nixa, MO
    I don't think anyone mentioned the transaxle blowing up, but are you arguing that this puts no more stress on the transaxle than it was designed to sustain?
    Also, while I agree that understeady state conditions it probably adds minimal additional stress, there's no way to achieve steady state without first accelerating up to it. And a duffus going 65mph with a load like that probably didn't carefully accelerate at a constant 1850rpm. And it's fanciful to think that there won't be significant slowing and accellerating in a real-world highway situation.
    finally, what about the MGs, the battery cooling, inverter stresses...those must all be exagerated under such a huge load.
  16. MattFL
    MattFL Member
    187
    55
    Anyone who has towed such a trailer (I have) can tell you that steady state or not, at 65mph you are putting significantly more load on your vehicle than without the trailer. Especially if your tow vehicle isn't large enough to block the wind that hits the trailer. I'm most impressed that he was even able to get up to 65mph, he must have the pedal all the way to the floor!
  17. patsparks
    10,664
    567
    Adelaide South Australia
    Would have been a better idea to hire a ute and get a friend to drive the prius to where ever the person is moving.
  18. KCobby
    KCobby Member
    229
    74
    NYC area
    another motor...
  19. TKY
    TKY Member
    232
    25
    Colorado
    I'm going with the drivers brains.
    Even empty, that trailer has got to be 1,200# to 1,500#. I had a 5X10, single axle, open trailer with 2 foot high sheet metal walls on the sides and front; its empty weight was about 1,000#. --TK
  20. kkayser
    kkayser Junior Member
    49
    Another Prius.:eek:
