Where to find a list of "commands" for Voice Recognition?
Discussion in 'Gen 3 Prius Main Forum' started by cmalberto, Aug 29, 2009.
  1. cmalberto
    cmalberto New Member
    95
    Sour Lake, Texas
    I started posting this thread and saw this link proposed.
    http://priuschat.com/forums/file-library/156-list-voice-commands.html
    However the link in the first post wasn't working. So now I am reposting the question. Is there a list somewhere? I need a copy to keep in the car so I can learn some of the more popular/functional ones.
    Thanks in advance.
    --Mickey
  2. IraS
    IraS Member
    165
    Austin, TX
    I went to the end of that thread and found a link to a .pdf version of the file, which works.
    The link is http://priuschat.com/forums/attachm...-voice-commands-prius_navigation_commands.pdf
    Also, the set of commands is stored in the navigation system itself. If you say "Command List", it will display the command list on the screen.
    Have fun with it.
    4 people like this.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Thats a good link IraS, thanks. Another place is in the Navigation System Quick Guide book that came with with your car. The complete command list is in the back.
  4. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
  5. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    This is the first vehicle where I actually looked at the manuals (I didn't on my 05 and totally missed that drawer under the console for 4 months!). Additionally you don't have to listen to all the prompts just hit the voice button a second time to bypass the verbal prompting once you see or otherwise recall your command.
  6. jay_man2
    1,246
    144
    Manassas, VA
    I turned the prompting off.
  7. LoraJ
    LoraJ Active Member
    507
    68
    2018 Prius Prime
    So that's where it is. I was looking in the manual today and could not find it. The reference guide is currently in the glove box.
  8. tumbleweed
    4,067
    692
    Eastern Oregon
    How do you turn off the part that that tells you what to say before you say it? I turned off "Voice Recognition Guidance" but it still wants to coach me. I still want route guidance I just want to get rid of the long winded directions on how to give commands.
  9. tumbleweed
    4,067
    692
    Eastern Oregon
    When did you get your car LoraJ? How do you like it? If you posted that somewhere I missed it.
  10. cmalberto
    95
    Sour Lake, Texas
    Thanks guys - I needed a list(PDF) to store on my laptop and a list to print. I thought it would be in the manual but I can't remember that many commands and I don't want to keep the manual out and open.
  11. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    The PDF file seems to contain more commands than the quick reference and some commands differ in syntax between the two documents.
  12. Tideland Prius
    16,559
    That should do it... not sure why it'll still give guidance. I just keep pressing the button and say a command after the beep. No need to listen if you already know what commands you want.
    go to john1701a.com and find the User Guide. He has a list of commands there.
  13. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    That pdf is dated 2004 (check properties), so it's for the Gen II Prius, and doesn't match the list at the back of the nav quick guide I received with my car.
  14. Tideland Prius
    16,559
    oh... ok. I figured most of them should still work lol.
    Quick guide eh? I'll have to see if I got one. I just got the regular nav manual.
  15. IraS
    IraS Member
    165
    Austin, TX
    Recheck your settings. I just looked at mine and "Voice Recognition Guidance" is turned off, which stopped it from prompting me every time I hit the voice button.
  16. SF Prius
    SF Prius New Member
    San Francisco, CA
    When using the audio commands, do I need to sp[eak through all of the preceeding prompts before I say what I'm interested in? For example, can I just say "Gas Stations" or do I need to say "Destination, Near Here, Point of Interest, Gas Station"?
  17. cmalberto
    95
    Sour Lake, Texas
    Good question. I haven't figured out what works and what doesn't.
    --Mickey
  18. cmalberto
    95
    Sour Lake, Texas
    Someone commented that the PDF listed was from 2004 or at least an earlier model. I tried some of the A/C temp changes and after changing the SAT channels/bands numerous times, I came to the conclusion that this doesn't work, I don't speak clearly enough or I am not using the command correctly. Any of the above could be true.
    Is there an updated list. I looked in my manual this afternoon and I couldn't find mention of so called list that was also mentioned in a previous post. Any ideas to help us out?
    --Mickey
  19. Tideland Prius
    16,559
    Depends I guess. I just said "satellite one" without having to go to "Audio" then saying "satellite one".
    The A/C ones may not work because they're no longer part of the MFD. The radio ones should still work. I used one today (see above)
  20. LoraJ
    LoraJ Active Member
    507
    68
    2018 Prius Prime
    I just scanned in the commands from the reference guide. Hope it works.
    Please let me know if this is not allowed.
    4 people like this.
