Air conditioner usage
Discussion in 'Gen 3 Prius Fuel Economy' started by bokone, Aug 28, 2009.
  1. bokone
    bokone Junior Member
    25
    Columbus, OH
    Question on A/C usage and mileage. With the "traditional" belt driven car, the common thought was below 40mph it was better to have the windows down because of the power draw on the engine and above 40mph (or so) the aerodynamic drag was far greater with the windows down. So A/C was a better choice. This is just an approximate because drag from the windows is going to be greater, on say a Corvette vs. a Hummer.
    So here is my question: with the belt-less electric A/C compressor on the gen 3 Prius, wouldn't it be ALWAYS more efficient to drive with the A/C on??
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It wouldn't always be more efficient because the a/c runs off the battery at low speeds when the engine is not running and that energy has to be replaced by running the engine to recharge the battery pack.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    but sustaining a constant inside temp Should be more efficient than turning an A/C unit on and off all the time. Humidity control comes to mind too (all the same thing really)...
  4. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    OK, what I'm about to say admittedly is *completely* anecdotal--but my experience, in 2+ months of ownership, is that, in all but the most completely stagnant city driving with lots of (and long) stops and very low speeds (20-25 mph max), I seem to do best with the windows rolled up, the car in ECO mode, AC on and the temp set on Auto at as high as I can find it comfortable (78 feels delightful on a humid, 95-degree day). I think the car is just so aerodynamic that rolling down all the windows really messes with it. Wind noise also suggests this. Plus, it's just a lot more comfy ;)
    Should I descend (further?) into utter geekdom, I'll do some controlled runs and post the results.
    As a (slight) aside, I think the whole idea that the car does it's best in city driving is bunk. My best mileage seems to occur during rolling, slow-but-not-stop rush-hour oozing gridlock.
    Cheers,
    Tim
  5. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I don't how important cooling air is for the traction battery, but I have to think it could cool itself better with 78 degree air than 95 to use your example. I run the air in ECO and recirc
    Oh and I would think any driving that causes you to run about 20 or 25 mph without stopping would return the best mileage. Sounds like city driving to me, but I guess it depends on what the definition of city driving is.
  6. qbee42
    3,082
    It's an issue of speed. The efficiency of the Prius A/C and the good aerodynamics of the Prius will move the break-even point, but it still comes down to speed. Look at the limiting case: standing still. Obviously when standing still it is more efficient to roll down the windows, as there is no aerodynamic drag. As speed increases, so does aerodynamic drag, but not in a linear fashion. At low speeds the extra drag from open windows makes no practical difference. At high speeds it makes a world of difference. Somewhere in between it breaks even.
  7. bokone
    25
    Columbus, OH
    The "break even thing" is kind of my point/question. I know in ANY car that eventually the aero drag is greater than the A/C load, but with an electric compressor wouldn't that speed be really really low?
  8. qbee42
    3,082
    No. The fact that the compressor is electrically driven is irrelevant. The fact that the Prius A/C is fairly efficient lowers the break even speed, but not by a lot. Even if the A/C compressor were 100% efficient, it takes a lot of energy to move heat. Don't lose sight of the fact that work is being done to cool the car.
    Also recall that aerodynamic drag is not linear in respect to speed. Aerodynamic drag is exponentially related to speed, meaning a small increase in speed makes a big difference, but only after you get up to some nominal speed. Below 30 mph aerodynamics have little effect. At highway speeds they make a big difference. Your answer is somewhere in between.
  9. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    I agree about the speed issue. Unfortunately, here in Baltimore, the traffic patterns, for whatever reason, virtually ensure that in the city you spend at least 1/2 the time at a complete and utter dead stop. Rush hour, midnight, it doesn't seem to make that much of a difference. I know the situation is better in some other cities (and worse in some). Now, on our local Interstates on the other hand, that 20-25 is somewhat easier to achieve ;)
  10. anne1965
    anne1965 Gotta love the game...
    131
    Leiden, The Netherlands
    I
    Yes, it is relevant. The fact that the compressor is electrically driven means that it can be driven at exactly the right load.
    A belt driven compressor is much more crude. When not much cooling is necessary, some hot air is mixed in with the cold air from the A/C to keep the interior from cooling too much. The Prius A/C will throttle back and reduce consumption.
    Lower average consumption from A/C use means the break even point will also be lower. But of course the break even speed will never be 0.
  11. qbee42
    3,082
    No, it's not relevant in any shape or form. The central theme of this discussion revolves around the efficiency of the Prius A/C. How the Prius achieves that efficiency is a fascinating tangent, but a tangent none the less. The Prius could use black magic and stardust to achieve the same efficiency curve and the argument would remain exactly the same.
    This is a common trap in discussions. People get lost in the details, even when the details are not relevant, which is why we, as engineers and scientists, often use black box diagrams. The black box hides the distracting detail. In this case, the A/C system is the black box. How the box performs is important. What's inside the box doesn't matter.
  12. anne1965
    131
    I
    That clears it up. Looking at the original post of bokone, I interpreted the 'belt-less electric A/C compressor' to mean 'very efficient A/C'.
  13. qbee42
    3,082
    Which of course it is. The Prius A/C compressor has many advantages: belt-less, variable speed, direct drive, and hermetically sealed with no moving seals. It doesn't get much better than that at this stage of A/C development.
  14. namasteflc
    namasteflc New Member
    47
    Georgetown Md
    Air coonditioning takes horsepower: in the older(non-Prius) sedans, about 5 horsepower. Because we have electric a/c compressors means that we also have more efficiency losses: electric generator: battery: inverter: electric motor, as well as compressor losses that everyone else has. At least we don't have a belt loss.
    I'm not sure if our electric a/c compressor is modulating; there are other efficiency losses if an a/c compressor isn't run at optimum rpm.
